How to clean wet sealant off inner tube so patch will stick?
Old 10-17-19, 11:16 AM
JeffOYB
JeffOYB's Avatar
Bikes: Uh... road, mtb, tour, CX (kludged), 3spd, 'bent, tandem, folder (the fam has another, what, 8)
Quoted: 147 Post(s)
Liked 5 Times in 4 Posts
I put sealant inside a tubular tire. Now I need to patch it. But the inner tube is wet with sealant. I tried wiping it off and patching but the patch didn't stick.
The inner tube might be latex. Typical patches have worked for me before.
The sealant is a combination of Stan's, Bontrager and Orange Endurance!
It's crazy but there was somehow a 1/2" hole in the tube but no injury in the sidewall. A lump of sealant TRIED to plug it up and worked for awhile. It doesn't even seem to be a puncture. It's like a hole -- old tube is missing. Strange...
Well, I want to try to patch it... But this wet sealant stuff is messing me up. I've never used sealant before. How do you clean it off?
I see info on cleaning DRY OLD sealant. I suppose it's just water soluble. I also see some bits of info saying warm soapy water. I'll try that... Any other tips appreciated.
JeffOYB is offline
Old 10-17-19, 11:54 AM
63rickert
Quoted: 1090 Post(s)
Liked 331 Times in 247 Posts
Patching a 1/2" hole is going to be hard regardless. Agree it seems mysterious.
More warm water would be my first choice. If that doesn't work hang it up and let it dry for a week or six or whatever it takes. Try to close off rest of tube so it doesn't all dry and so humidity from rest of tire is not feeding towards the hole.
63rickert is offline
Old 10-17-19, 12:08 PM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 1152 Post(s)
Liked 341 Times in 251 Posts
For a tubular tire its gonna be difficult to get a clean dry surface if the sealant keeps leaking out. You may have to suck out the sealant with a syringe and rinse the inside. Or just pump water into the tube and let it drain out the hole in the tube - its big enough! Expel all remaining liquid in the tube. Then wash and dry the outside. Then patch.
I think adding sealant to a tubular tire, while perhaps offering benefits, has this very fatal weakness: it may make the tire impossible or very difficult to repair.
WizardOfBoz is online now
Old 10-17-19, 12:12 PM
masi61
masi61's Avatar
Quoted: 1163 Post(s)
Liked 442 Times in 315 Posts
Is there any possibility that the chemicals in the sealant softened the latex inner tube contributing to the flat? Repairing a tubular tire with a latex inner tube containing tubeless sealant sounds daunting to me.
masi61 is offline
Old 10-17-19, 12:53 PM
sch
Quoted: 303 Post(s)
Liked 136 Times in 104 Posts
Even without the sealant it will be hard to get an air tight patch on that large a hole. Back in the '70s when a good tubular was $8-15
I repaired them but it was a PITA.
sch is offline
