Totally Tubular
#1201
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
I'm riding my track racing bike after not using it for a few years. I've lost my nerve. I'm afraid my 22mm tires (Continental Sprinter) will slip, even though I know they won't. I'm just nervous, especially when I see a groove in the road. Does anyone have suggestion for rebuilding the confidence? I weigh 170 lbs, and I'm pumping them to 100 psi.
Bill
Semper Fi, USMC, 1975-1977
#1202
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,836 Times
yes, I would agree with any urban rider (especially in 'infrastructure challenged' places) who felt that 23mm and narrower made their riding more hazardous. Bunny hopping, small lateral jumps etc are good skills. But cracks, covers, pavement upheavals are easier on fatties.
#1203
Quoted: 4806 Post(s)
Liked 3,929 Times
My space out. Tubulars aren't "open". Duh! The "Pave" was what I was after.
#1204
Liked 3,929 Times
I love ribbed thread. Mourned it going away many times. Thank you Vittoria for bring it back. It is the all-around tread that is fast, decent grip, no surprises and will get you out of that grove or rut or back on the pavement.
A ribbed tread story. 43 years ago, my first "real' race, 105 miles in pouring rain. 100 riders. Final miles, the pace picking up. Divided highway with a cobbled median set about an inch below the pavement. I was riding decently fast orange treaded tires, ribbed. Fast, ribbed, but the orange tread was famous for being slippery in the wet.
I was on the left edge of the peloton so I could move up. Someone moved toward me and I moved left. Oops! I rode onto the median cobbles. Now I had to get myself back onto the pavement. Steeled my nerves, did as hard a turn into the pavement as I dared riding those smooth wet cobbles. Bike just climbed back up, no big deal. Eventually my heart rate returned to sustainable.
Love that ribbed tread!
Ben
#1205
Quoted: 1361 Post(s)
Liked 423 Times
Interesting range of answers on carrying pre-glued tubular. I'm not overly concerned and have used both pre-glued and non prep. Though if the weather calls for precipitation, I prefer carrying a pre-glued.
Also, the wiser will wrap or use a storage sock. I don't ;")
All things considered, tubulars are not for everyone but without a doubt and for day duty rides on vintage lightweights, I still prefer them over clincher.
Shaking down this Spring a fine Tange Prestige frame, another having R-531c, and yet one with Columbus SL / Falck tubed.... those all on clinchers / new Veloflex Masters and Vittoria Corsa G in mid 20s widths, none of them are as enjoyable as the rest of the fleet and those on tubulars. What I'm saying, each day I pick one bike and tick off 20 miles or so. The ones with tubulars really set nicely in what I expect out of the ride and bike. Those hyped clinchers (call them open tubular whatever) still don't deliver.
#1206
Quoted: 7348 Post(s)
Liked 2,471 Times
I'm not afraid my tires will come off the rims. I'm just afraid, at an irrational level, that they'll lose grip with the ground. It wasn't a problem in 2014, but since then, I gave up 25mm tires and rode 28mm tires a little and 32mm tires a lot. So going back down to 22mm -- as measured with a caliper -- feels scary. It's funny, because I rode tires like this for ages. Maybe the fear will go away in just a few rides.
#1207
Veteran, Pacifist
Liked 4,836 Times
My experience on gluing a spare:
If there isn’t much tacky residue on the rim, you should preglue (or carry a bit of tape). Not because you can’t ride safely but I get tire CREEP, that is where the tire moves on the rim enough to dramatically tilt the valve stem - not a desirable thing, especially for a long ride home or on a new spare. Why not carry a bit of tape to prevent creep? If you glue with a mastik or non-hardenening adhesive, maybe the spare tire holds in place well.
#1208
Quoted: 2338 Post(s)
Liked 2,824 Times
OK here is my ride report on the CHALLENGE ELITE PRO tubies @Wileyone
I was looking for tubies to put on my team myata....which i didn't anticipate riding a a lot and keeping it for eroica/jheroica type rides so didn't want to go totally high end (will be posting team miyata report, but it is going to get more miles than i thought)
I have used the tufo s33 and tape and decided I wanted to try a bit more supple tire and gluing
This seemed on paper any way a good compromise decent specs 220 tpi and removable stem at ~$30) (now sold out at probikekit
Using the yellow jersey description puting the tube on was easy Tubular Tire Mounting Cement Gluing Adhesion by Yellow Jersey; Thoughts on a Front Wheel
They are mounted on mavic 330 rims the bike is an 84 team miyata
Ok so the ride (limited miles 5 mile commute this mornign) so ride so far
I pumped them up to 130 psi (I am 267) (note I had pumped them to 120 and they only sent down to about 115 after 5 days....butyl tubes)
Immediately the first and lasting impression was smooth...... these are noticeably smoother that my comparisons. Handling felt good, but don have much curvyness in my commute other than dodging speed bumps in the parking lot and they felt totally at ease there
My comparisons:
Same bike, but Bontrager 25 mm (not fat 25s but skinny 25s) on Mavic Ma40 rims..... night and day difference the clinchers were way more rough and I didn't have them pumped up to where they should be
De Rosa 90/91 Open pro rims and the super regarded Corsa G clinchers (with thin "high performance" butly tires) pumped to 115psi
the corsas are great tires, very smooth, but the challenge felt even smoother.
clearly I need more time to to tell better and durability is over time, but at first impressions I am quite happy with the purchase update down the line
- Use: Road Training
- Tire Width: 25 mm
- Internal Rim Width: 13-15 mm
- Weight: 295 gr
- TPI: 220
- Casing: Poly
- Flat protection: PPS
- BAR: 7-12
- PSI: 100-175
- Inner tube: butyl
My comparisons:
#1209
Liked 2,471 Times
I rode 15 miles in the city today. It was treacherous on my back. (I wore a backpack.) A track bike is not made for comfort, and at least a few people have characterized Continental Sprinter tires as riding like rocks. I'm also not used to narrow tires now.
I'm not buying new tires any time soon.
But the bike is still fun, and I love the handling.
Likes For noglider:
#1210
Liked 2,824 Times
#1211
Liked 2,471 Times
Hey, at least I have a front brake, cuz I'm not stoopid.
Fixed gear is fading out of style, but I rode for a block or two with a courier on a fixie today. Nowadays, couriers here can scarcely afford NOT to ride e-bikes.
#1212
Long time lurker, first time C & Ver, but that's a beautiful bike, if you wanted to make it more ridable have you considered riser bars? Most trendy urban bike shops should be able to help you out, or at least fitting a more compact handlebar with dummy hoods should give you a better perch. Have a surf at some of the images on the Fixed gear and singe speed forum, there should be some nice bikes with risers on there for inspiration.
That bike looks awesome in a pure track kind of way, but the bikes are built to be stable at speed, the handling can be jack for street riding which may be why it feels scary. I couriered for 6 years, 2 on a street fixed and have raced track since I was a tacker and I don't really like riding the track bike on the street that much.
I always feel like with C & V folk I might just be telling people stuff they already have considered, but it'd be a shame to stop riding a bike like that when it could be a lot more fun.
#1213
Quoted: 1858 Post(s)
Liked 606 Times
Thanks for the update @squirtdad. As you say unfortunately they are out of stock. So I ordered a set of Veloflex Vlaanderen from Merlin Cycles. First time ordering from them. Didn't realize they shipped from Spain...
Anyone tried these?
Anyone tried these?
#1214
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
OK here is my ride report on the CHALLENGE ELITE PRO tubies @Wileyone . . . I pumped them up to 130 psi (I am 267) (note I had pumped them to 120 and they only sent down to about 115 after 5 days....butyl tubes)
Immediately the first and lasting impression was smooth...... these are noticeably smoother that my comparisons . . . but at first impressions I am quite happy with the purchase update down the line
Currently I have mounted a set of conti sprinters that I love, a set of Challenge Paris-Roubaix (no real miles yet) a set of Spech Espoir (very nice ride but had a flat the first 100 KM) and a set of old Michelins that seem ok. All of these are on very different bikes so it is hard to compare the ride quality.
Were you riding them at 130 psi? What Bonty tires were they? My go to is the AW3 for this time of year and for touring.(I find them a bit rough as well) I need a set for another bike I am building and I am thinking hard about these, especially with the tan walls.
#1215
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
I've been riding Veloflex Criteriums 23mm. Haven't ordered any for a year or so. FWIW, when I get mastic on my fingers, water does not prevent them from sticking to things!
Real cyclists use toe clips.
jimmuller
jimmuller
#1216
Liked 2,471 Times
Street fixie:
#1217
Liked 2,471 Times
@daviddavieboy, you don't find the Sprinters to ride harshly? Perhaps my problem is either 1. I'm not used to narrow tires any more, or 2. my bike is the harsh thing. It could be both, primarily number 2.
#1218
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
@daviddavieboy, you don't find the Sprinters to ride harshly?.
#1219
Liked 2,471 Times
OK, that situation is different enough from mine that is not a comparison. Thank you, though! I guess I could try another wheel set in my track bike for comparison. I am not about to change the tires on my tubular wheels, because (1) too much trouble, (2) too much expense, (3) it's not that important. I can try the wheels from my street fixie which are 25mm clinchers, and I could even try 28mm clinchers as an experiment.
#1220
Ellensburg, WA
Bikes: See my signature
Quoted: 313 Post(s)
Liked 458 Times
I ride mostly chip seal pavement around here.
1984 Gitane Tour de France; 1968 Peugeot PL8; 1982 Nishiki Marina 12; 1984 Peugeot PSV; 1993 Trek 950 mtb; 1983 Vitus 979; Colnago Super, mid-80's Bianchi Veloce, 1984 or 85 Vitus 979
#1221
Quoted: 1951 Post(s)
Liked 2,012 Times
I like new to me rims to be clean before I mount tires. One before and one after processing: Scrape off most of the old red crusty stuff with a small screwdriver and then paint on Citristrip. Wait a few minutes, wipe off with paper towel. Repeat. Works well. Always amazed. Replaced my lost valve remover which makes adding Stan's a piece of cake.
Araya Aero 4
Cool Tool
Araya Aero 4
Cool Tool
#1222
Very Slow Rider
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times
The Tubular Tire gluing process is simple.
Vittoria Mastik One adhesive is preferred and proven.
Use a Plumber's Flux Brush(.25 cents) to brush the glue onto the Rim and Tire.
Let dry to a tack(about 20 minutes)
Assemble the tire and rim.
The glue should be applied to the carried spare tubular tire so that it will be ready if needed.
No Mess. . .
I have never in many years had a tire seperate from the rim during recreational/club riding.
Consider This:
https://draco.acs.uci.edu/rbfaq/FAQ/8b.19.html
No Mess. . .
Consider This:
I have also heard that if they dry a little out of center it's not a big deal. Can you opine?
#1223
Liked 2,012 Times
Install with the glue wet is fine but can be messy with tight tires. Your fine. CX tires? For CX racing? Low pressure? Generally, that requires multiple layers of glue. So if that is the case, and you only went one and one, I suggest that you remove the tires and add 2 more coats. You can make adjustments after you mount them before they’re inflated to max.
#1224
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
track bike in the city...
I
I
All those things are probably contributing causes. To me the streets would be the biggest. Out here in the burbs, It's the rough stretches of road, right where I need to be riding, sharing the roads with cars, that get me swearing. Most of the roads in Bergen/ Rockland that I ride are not awful. I switch between tubulars and clinchers, based on the age of the bikes, post '87 mostly clincher, pre '87 mostly tubular. I still don't have any tires over 23. I really like riding supple tires that feel good, so I do. A corollary of the belief that fatter is faster, is that skinnier is cheaper. Oh, the deals I've seen on tubular 21s . I'm 155. I typically ride all my tires between 85-100. I tend to be more careful about the clinchers and ride them harder, due to fear of pinch flats. My guess is that back soreness and a jarring ride, have more to do with tire brand, width, and pressure, than the bike or even than the wheels, unless you ride really extreme wheels.
Bitd the only place/time I ever rode 130 psi was in competition on a clean smooth track surface. I imagine on city roads that would be pretty harsh, even if the tires and wheels can handle it.
My punishment for being cheap, and sometimes riding those old panaracer 18s is occasionally having my teeth rattling in my skull on bumpy roads. But ahhhh, those smooth sections.
Cheers, Eric
I've said it before, that is one gorgeous bike!
#1225
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
I actually will not be racing but I thought I was going to be when I bought the wheel set, the tubular thing came about because I got a really good deal on the rims and I was also very curious and I love to learn. Now I just have a recreational gravel bike with a really cool tires
Likes For davei1980:
