Freewheel Supply - Any Worries?
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Maybe this is just me, but why, oh why does IRD make a 14-16-19-24-28-34 freewheel? That's a very useful overall range for the kind of riding I do, but that 24-tooth cog makes no sense when using a 23 in the same position would give a perfect 14-16-19-23-28-32 progression. If you chart the resulting ratios, IRD's approach gives a big hiccup in the middle of the range. I've made up a couple of Suntour Perfect freewheels in that exact tooth count, but would consider buying them from IRD if they'd get rid of that wacky 19-to-24 jump.
Am I just too much of a dim bulb to understand why IRD chooses to do it that way?
Some of the cheap new 5-speed 14-28 freewheels go 14-17-21-24-28 which looks fine until you graph it.
feros ferio
Quoted: 1393 Post(s)
Liked 1,326 Times
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
When considering only the major vintage players in the '60s-'70s, Regina, Atom, Maillard, Suntour and Shimano, yes the first two used threaded and they are interchangeable. Maillard used a combination of threaded and notched. Suntour was all over the place with both threaded and notched, and Shimano mostly used splines, but also had notched and threaded cogs.
I've been thinking this through: With the correct kind of press and die cutter, modern SRAM, Shimano, Sunrace, etc., cassette cogs could have the center cut to form compatible freewheel cogs. The same press with different die cutting tools could be employed to make cogs for existing Suntour, Shimano, some Regina, and Sachs freewheel bodies. This might be the ultimate solution, especially for those elusive 23T, 25T, and 26T cogs.
Bob
Bob
Quoted: 1361 Post(s)
Liked 423 Times
I would not hesitate to cold-set a 126 frame to 130. But ... a 40 year old 120 mm spaced racing frame with shorter stays ... (like a 'crit' bike?) — not for me unless I get convinced otherwise.
OK ... flame me and flay me for saying this. I would not do it. And some us have these 120 mm dimensions between the DO's.
Decades ago, I shared shop-space with a guy who rebuilt vintage race car frames — very likely it was Reynolds 531 tubing he was working on. He talked about crystals and stuff. He showed mistakes made by Colin Chapman's 'Lotus' frame builders. I started looking at steel — and indeed other metals in a different way.
So ... maybe I am all wet: but moving a 40+ year old piece of steel tubing 5 mm? Be my guest. I refused the idea and went as far as 126. If it had been a boring piece of Hi-Ten — WTH! The frame builder I had do the set did not seem to be disagreeing with me.
Different story though on race car chassis. All purpose built race cars have limited longevity and for intended use. Then there's the expected crash including how quickly and easy can they be repaired. Even way back and in the case of Chapman, the master of 'cutting' weight, by running coolant water thru the chassis tubes I don't think he cared about corrosion or concerns for the racecraft's many years later survival. As for the tubes change in properties during fabrication, some way back then may or may not have cared. Build them and get them out the out the door to teams. Debateable, but probably one of the reasons Lotus gambled with lightweight but sacrificed dependability.
--- back on topic: My LBS owner mentioned his collection of FW and cogsets is going for decorative art applications in his house. LOL.
As for the topic: in your opinion should I bend my Simplon-Romani — originally 120 — to 130 and then bend the DO's back parallel on the alignment bells. Then I can go bonkers in the free-hub playground and forget the bloodletting hunt for vintage stuff.I welcome more of your opinion. Maybe all of us should just get on with it and bend the stays out. We'll not all of us. Who is going to do that to a late 50's Cellini or a 1938 Bates!?
(BTW — as an aside, my friend found that Chapman's welders were not the most skilled — and showed me the evidence. I was rather shocked! But then it was not a team F-1 machine ... maybe an an F2 and reduced to Formula Junior.)
Vitus 979, Simplon 4 Star, Gazelle Champion Mondial, Woodrup Giro, Dawes Atlantis
feros ferio
Liked 1,326 Times
In the mean time, my recommendation is to increase the life of your current cogs by regularly removing them from the body and cleaning them, keeping the chain clean, and making certain the body is serviced. After all, road grit and dirt along with improper lubrication is the worst enemy to your freewheel's and chain's longevity.
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
If I recall correctly, Colin Chapman was once quoted as saying on the ideal race car everything should break just as it crossed the finish line. Don't think I would have wanted to race for him! Of course, practicality always gets in the way.
But to justify this post by getting back to freewheels, my Motobecane has a conventional 5-speed, 14-28 paired to a somewhat custom compact double crank, 47-34. Most of my other bikes have 6-speeds with compact double cranks. The most radical (for me) is the Masi's 14-34 6-speed with a 47-42 half-step crank. The riding styles are different, but I can live them just fine, thank you. For example, yesterday morning I took the Moto out for 24 quick (at least for me) miles, 16mph, 1550ft of climbing. I used the full gear range, but spent most of the time on the big-24, big-20, and big-17 combinations. Would another cog have made much difference? Probably not. Most of the time I was running at my aerobic limit. When I needed a higher or lower gear I had one available.
At least the bike didn't break, it simply braked, as I reach home.
Real cyclists use toe clips.
jimmuller
jimmuller
Quoted: 834 Post(s)
Liked 2,126 Times
I share Pastor Bob's sentiment that it is well worth overhauling an old freewheel. There are lots of lightly used freewheels that can be salvaged and given new life. It really is not as challenging as Sheldon makes it sound. I do keep my eyes out for those elusive 24t-26t Regina cogs. I'm not overly worried about freewheel supply though, as I have been gathering spare freewheels (have added a few more since this photo was taken).
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
I have spent some more time persuing eBay for 7 speed FWs and my conclusion is I should HTFU and learn to push a 13-21 over any hill, since that flavor of vintage FW is still fairly accessible. Failing that, my alternatives are (1) move to Florida, (2) triplize my bikes, (3) buy a dozen Sunrace 13-25 FWs while they are cheap. Or, (4) insinuate myself into gaucho777's last will and testament.
Too many bikes
Quoted: 5 Post(s)
Sachs FW come up on ebay from time to time. Often they are of the 13-19 or 13-21 variety, but you still see 13-28 or 13-26 go for reasonable prices. They spin fairly quietly, but I have to admit to favoring the Dura Ace ones so I haven't actually run one.
Looking for 24T or 21T Dura Ace uniglide cogs FW. Can trade NOS 12T.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I'm thinking it wouldn't be prohibitive to make threaded FW cogs out of freehub cogs, at least at ultra 6/7 spacing which is par with 8 speed. Making splined ones would be worse in small batches (machining the splined hole more difficult than threading) and better in large ones (stamping splined hole easier than threading)
Quoted: 834 Post(s)
Liked 2,126 Times
I'm glad this thread came up when it did. It prompted me to search and find another back-up 26t Regina cog.
Quoted: 556 Post(s)
Liked 132 Times
OK.
She has 7 more of these. She says. Helluva deal for a very scarce size in a very good freewheel. Keep an eye on her auctions.
Regina 5 Speed Free Wheel Italian Thread Road Racing | eBay
This public service message is brought to you by an unabashed Regina fan who is related to the seller no way, no how.
Quoted: 834 Post(s)
Liked 2,126 Times
Nope. I have 2 bike Co-ops within a few blocks. At any one time, they have bins that are overflowing with 100 pounds of decent old freewheels. And there is our local recycling depot, which 'compresses' 150 old bikes per week. And then there is Ebay, scavenging and creativity.
Creativity: for example, you can replace most of the cogs on 6/7 speed Dura-Ace and Shimano 600 freewheels with cogs from their current inexpensive offerings. This takes some hammering and a little grinding. The transplanted Hyperglide cogs shift better than the old Uniglide ones.
Or if you have an old Sachs freewheel, by grinding off one of the 4 tabs, you can double the life of most of the cogs by flipping them. No apparent deterioration in shifting.
And keep in mind that 90% of the bikes sold to this date still use freewheels. Freewheels will likely be around forever.
Quoted: 392 Post(s)
Liked 49 Times
Quoted: 392 Post(s)
Liked 49 Times
I forgot what enablers you guys are.
Since starting this thread I have bought two Sunrace 13-25 online, a Winner, a Winner Pro, and a Sachs (8 speed!), so my freewheel hoard now looks like this plus a few more in the bin and the in-transit Sunraci.
Two of these are just "weigh-in" freewheels, being aluminum and installed just to weigh the bike. One is a wide range monstrosity that I decline to ride until another decade passes. The rest are 12-17, 13-19, and 13-21 "HTFU" freewheels. And there may be one "reasonable freewheel" for a not over strong, 50 plus guy. Maybe.
I am hoping at some point to take them apart and figure out how I might be able to get a couple more reasonable freewheels from the mess.
Actually, most are notched or come with splines.
No hard tooling required, only an IGES file or similar.
Freewheel Medic
Liked 2,196 Times
Thanks for the great idea.
Bob
Bob
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Zeus was ahead of the game in this area: all the cogs were splined, with the same spline pattern, except the final cog, which was threaded and held the rest in place. No spacers were needed, as the cogs were machined to provide the intended clearance. And the bodies could be removed from the hubs using either the then-ubiquitous Regina 2-prong remover, or the superior splined remover later adopted by Regina, Everest, Atom, etc.
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
Words of the Wise
Duplicating dimensions is very different from conforming to design specifications, which requires material selection, processing, testing, quality control, you get the idea.
So of course one is on their own in terms of first establishing the design specifications, and that's just for starters. Sourcing suitable material and performing needed processing is daunting to the point that it can only be justified for a large production run.
A LOT of hard work goes into manufacturing a decent freewheel, freewheel cog, or almost any other part on a good bicycle.
A well-developed process and production line then may make it look easy!
The real challenge is cogs. Period. There is no reason why a freewheel body if properly maintained can't last for centuries.
Getting back to cogs. The next challenge is the lack of a cog attachment standard. There are threaded cogs (with dozens of different standards), notched cogs, and cogs with splines (with different patterns depending on the manufacturer). I believe if there had been one, or even three or four standards, someone would still just be making cogs.
Quoted: 834 Post(s)
Liked 2,126 Times
As long as this silly trend continues, there will be a bountiful supply of unwanted freewheels.
Quoted: 834 Post(s)
Liked 2,126 Times
Pastor Bob: If you build it, the cog orders will come.
Freewheel Medic
Liked 2,196 Times
This really does give me something to think about.
For a few years now I had wished there was a way to mate a modified freehub outer body to a freewheel inner body in order to use cassette cogs on a freewheel. Of course this could never be done because of the smaller size of the freehub. Why I never thought about adapting cassette cogs to fit a freewheel body until now? Well--- I guess I needed this thread (insert "Smack Yourself In The Head" emoticon here)!
If @jonwvara can find a machine shop to manufacture new 122BCD and 144BCD triplizer chainrings, why can't I find a means to modify cassette cogs? I'll probably start with the spline pattern that fits Shimano and Sunrace bodies. I'm guessing this will also work on the other modern freewheel bodies but will need to verify this at some point. It would seem that 25T and 26T are the most requested, so I'll need to find a source for those cassette cogs.
I think I have found my retirement business. Don't any of you C&Vers go stealing my idea!
Bob
Bob
Quoted: 1608 Post(s)
Liked 2,216 Times
I just started searching for IRD freewheels and was having difficulty finding them. I am concerned they will be discontinued. What is avaialable may be NOS. IRD still has a reference to their freewheels but don't id the tooth count.
@pastorbobnlnh This is a crazy idea but I was wondering if an EDM tool could be made to modify cogs. First step would be to mill out the min ID needed and then EDM the spline configuration. Shouldn't take too long depending on how many cogs you do at once. Registering to the center line of the cogs could be a challenge or not. Just create a fixture with indexed holes for alignment pins for tooth count (cog sizes)The tool could be easy to make but a bit expensive if copper. It been about 20 years since my exposure to this process and I don't know if it is improved or not. I created a tool for placing splines in an AL block machined for a Yamaha Vision handle bar mount. Worked out well! Should take a picture of the tool the next time I run into it.
Other alternative methods might be water jet or lazer. The material is thin enough that it might actually work with enough precision. Been too long and don't really know how viable these from a precision perspective.
