Explain fork rake to me.
モㄥ工匕モ 爪モ爪乃モ尺
Bikes: Custom frame
So, im looking for a fork that will shorten the distance from my front wheel to my rear wheel, trail distance?
My stock offset is 28mm, If i get a higher rake offset does that mean closer to the frame? or farther from the frame?
Can i use a 1inch threadless fork on a 1/18 steering tube?
Shims and other accessories?
Quoted: 3376 Post(s)
Liked 5,525 Times
モㄥ工匕モ 爪モ爪乃モ尺
Bikes: Custom frame
So if i try out a 55mm offset fork at the shop it should reduce the trail correct?
Rake/ offset is the difference between the centerline of the steering axis, and the center of the hub axle.
BUT that is only PART of the steering Geometry.
with the steering axis being at an angle,
the vertical line thru the axle crosses
the angled line of the steering above the ground-plane
so on the ground the tire touches the ground behind the steering axis line..
that is TRAIL.
trail is reduced as the rake is increased, reducing rake, increases trail
because the 2 lines cross
someone elsewhere on this site has graphics showing this
a+b=c but only if you don't change a, or b to another value..
that is TRAIL.
before you can install it ..
Liked 5,525 Times
What problem are you trying to solve?
It sounds like the goal is a shorter wheelbase, which is the wrong reason for going to a fork with a different rake.
More rake -> less trail -> less stability / quicker turning.
Less rake -> more trail -> more stability / slower turning.
BTW There are headsets available to adapt smaller steerers to larger headtubes.
モㄥ工匕モ 爪モ爪乃モ尺
Bikes: Custom frame
I already have aheadset for a headset size reducer, King headset.
Im trying to reduce the wheelbase distance, What would i need to change? All i know off my oem fork is that the rake is 27-28mm
Im going to try a 55mm rake offset because at the shop someone owns one, Im not going to purchase it at the shop.
headtube.
Rake goes forward. a 55mm rake will increase your wheelbase.
Trail goes backward, it's measured back from the imaginary intersection of the steer tube with the ground. More rake = less trail.
Why are you trying to reduce the wheelbase? If you're trying to change the handling, a 1% change in wheelbase is dominated by other factors: head angle, trail, weight distribution.
OP just needs to buy another bike frame and fork to suit the changes they now desire.
Shorter wheel base typically comes off the back of the bike ..
an S bend seat tube is one way to shorten up the chainstays to shorten the wheel base..
Builders have also pressed a dent in the seat tube to make tire clearance.
The Italian RiGi company split the seat tube below the seat post
to 2 side by side tubes to pass the wheel between the 2.
front of the bike is about rider fit,
a steeper head tube can be part of a twitchy steering bike.
Criterium racing and some Track events may favor that .
Liked 7 Times
Changing rake offset will make very very little difference in handling. As said above, increasing the rake offset will make steering quicker and wheel base longer.
モㄥ工匕モ 爪モ爪乃モ尺
Bikes: Custom frame
Im Trying to close shorten the wheelbase for a customer, just wonder what i would need to change to accomplish this,
Oem is 27-28mm
The one he wants is 55mm what will this do, Will it make the length from the rear wheel to the front wheel longer or shorter.
Oem is 27-28mm
Given:Rake bends forward Adds 27mm, a bit more than an inch, 55-28=27
You could just run the existing fork backwards ..
MARGINALS
Bikes: 09 Tarmac Pro SL / Sunday BMX /
In the 13 years I've worked behind the counter I can attest to the fact that people typically don't what the hell they are talking about when it comes to bikes. The ones that do typically will do it themselves.
Quoted: 1529 Post(s)
Liked 718 Times
Yeah, this is total WTF stuff.
Leave the fork that came with the frame on there; it was specced for more important reasons than wheelbase.
Changing the fork would be a dumb way of achieving a shorter wheelbase. You do that with a frame.
モㄥ工匕モ 爪モ爪乃モ尺
Bikes: Custom frame
Well, he insist that he needs a shorter wheelbase, How would i achieve that for him?
I told him such risks. etc.
Liked 718 Times
New frameset.
End of story.
Maybe you should ask him what he's hoping this shorter wheelbase will miraculously do for him.
End of story.
モㄥ工匕モ 爪モ爪乃モ尺
Bikes: Custom frame
Yeah, i'll suggest he get a new frame set. He is trying to shorten his wheelbase so his bike "wont look so funky"
^^ idk...
So, For further reference, If he gets him self a lower rake fork and wants me to install it, it'll put his wheel closer to the rear wheel correct?
^^ idk...
Liked 718 Times
Yeah, but it'll have more trail and handle slower. Depending on the clearance of the old fork, it might even make the head angle slacker, causing even more trail.
I'd tell him the gap between his back tyre and his seat tube looks 'funky'. And if he's just concerned about looks, I'm guessing the old forks are sharply curved at the very bottom in the old style, unlike the yellow bike in your sig. Maybe just a set of modern-looking forks with the same rake will make him happy.
A 28mm offset is highly unusual for a road bike. There is no way to change the wheelbase of a bike significantly, without fouling up the steeering. Changes to fork offset (rake) are usually small, to fine-tune the bike's steering. Changing from 28mm to 55mm would rarely make any sense. The trail would be reduced greatly and the steering would become much quicker. Totally bad idea.
Liked 5,525 Times
As an example of how sensitive handling is to fork rake, I once bought a used tall frame which was afflicted by the lousy geometry which too many mfgrs put into their large frames.
It would go into uncontrollable high-speed shimmy over 30mph.
After consulting Dave Moulton's articles about geometry, I made a bunch of measurements and ordered a custom-made fork.
The change from a fork with 45mm rake to one with 38mm rake cured the high-speed shimmy.
Liked 7 Times
What kind of bike is it and how do you know the rake offset is 28 mm? Seems highly unusual. The road bike fork rake offsets I've seen have been in the 38 to 50 mm range.
My experience has been that a change offset 3 mm will make a significant difference.
If the owner is concerned about appearance perhaps straighter fork legs is what he really wants. Fork rake offset is not dependent on curvature.
モㄥ工匕モ 爪モ爪乃モ尺
Bikes: Custom frame
He is going to get a new fork in the same demonsions.. He is looking for a straight fork, no curves...
Well i know that the for is a 28 because the demsions are on the fork.
They want a shorter wheel base sell them a frameset with a shorter wheel base,
the whole thing.
steep seat and head tube short chainstays the whole ball of wax .. a track frame
rear facing dropouts are needed , verticals would work, but i suspect this is a Fixie gear type guy..
the whole thing.
Quoted: 23 Post(s)
Looks to me that bike already has too little rake for a road bike unless he's only doing urban riding.
Maybe you should shop around for a more suitable frame, and get some sizing help from a LBS.
