Garmin or Strava?
Garmin or Strava?
I’m just getting back into riding after a long time off So I was thinking about getting a Garmin 830. But I see lots of people using Strava so my question is Strava as good as a garmin
Sr Member on Sr bikes
bigd -- Seriously...you are sort of asking about a comparison between apples and...Sharpie markers. Think of it this way. A Garmin device is a GPS receiver that will tell you where you have been, and where you are. It'll measure speed and distance for you. And, depending on the specific device...may give you all sorts of other data for analysis. Things like average speed, RPM, Watts, calories, etc. Now...Strava, as a web service, has been described as like a "Facebook for athletes." You can have "friends" and "follow" other athletes just like on Facebook. On the actual Facebook, you can upload pictures from cameras, other devices, "check-in status," etc. So, in that same vein, you can use the Garmin device to upload a workout you recorded to Strava. OR...you can use your smartphone and the Strava app. Your smartphone has a GPS receiver. One thing to keep in mind...Strava has a 'free' version, and an upgraded version ("Summit") that requires a monthly fee. But...you have access to more of their services.
Hope that helps.
Dan
Hope that helps.
Dan
Registered User
Quoted: 188 Post(s)
Liked 276 Times
I use both. Garmin for a basic logging tool. I see some features there but not enough to drive me away from the social fun of Strava.
Strava as a logging tool but also as a way to keep in touch with friends and fellow local cyclists.
Likes For TheDudeIsHere:
Bikes: Moots Routt
Quoted: 94 Post(s)
Liked 22 Times
Hope that helps.
Dan
Hope that helps.
Dan
I think he means garmin Online, the fitness tracking route thing
Quoted: 741 Post(s)
Liked 818 Times
I use my Garmin 810 to upload ride data to Strava. My phone battery isn't too trustworthy on long rides, so I save it's battery, and use the Garmin for ride info. I'm a fairly recent Strava convert, just over a year, and I still use Garmin Connect to keep track of lifetime mileage on several bikes. As far as I can tell, Strava only allows mileage data from the start date, and doesn't allow you to back load previous data.
Quoted: 440 Post(s)
Liked 264 Times
Get a Garmin it does not need your phone until the ride is done. Strava will use your battery the whole ride. I like to save my phone for emergency use and would not like to have a depleated battery when I need it.
Likes For Bmach:
Bikes: 50/34, 11-40, 11 Speed
Quoted: 142 Post(s)
Liked 73 Times
For what you need they are a tandem. The Garmin is a computer/recorder and with its paired sensors it records and logs all the info. THEN the info is uploaded by you to Garmin Connect/Strava. You then see all that you are seeking on Strava.
I would suggest looking at garmins watches(unless you need the bigger screen for navigation). I have a fenIx 5 and am very pleased with it. As the previous poster said the garmin device will upload to garmin connect and strava after you complete a ride. They actually really work good together. Basically Garmin is the hamburger and strava is the fries.
I sometimes rely on a separate GPS device too. But, the GPS in your phone is a receive-only function and is pretty much always operating (for emergency services). Receive-only apps don't use that much power IF the screen is off. When the workout is completed that is when the recorded GPS data is uploaded to your account via cell or wifi/internet (I think if you use the Summit version of Strava, with the live monitoring, it uploads as the workout is happening.) Turning off all other apps while you're in a workout using Strava will help lessen battery drain. If you have any wifi-dependant apps open during a ride or run...and you're not in range, or logged into a wifi network...those apps will deplete more energy searching for a wifi network. So in other words...Strava (or and GPS app) doesn't require a lot of battery power until you're back home and complete your workout (or unless you leave the screen on constantly). With only the Strava app running, and the screen off...I have been on rides of six hours and still have plenty of battery life.
Dan
I think I lost 1 in 4 rides and runs when I was using Strava for recording and it often had me doing 125 mph jumping around town. Maybe it was Strava or just my phone's GPS but I never had that problem using the Polar Beat app on the same phone. I think Strava gave up and removed external sensors to combat the crashing and stuck with the core business of just collecting data from other ride recording things instead. I haven't used Strava in 3 years during a ride so maybe they figured it out. I use an Elemnt device for rides and no issues and use Polar Beat for recording everything else.
Quoted: 1819 Post(s)
Liked 1,693 Times
My Garmin 820 is able to connect to WiFi. When my ride is finished, it connects to my home wifi and automatically sends the ride data to Garmin connect. My Garmin connect account then sends the date to Strava. A Garmin 830 would have the same functionality
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times
I have a Garmin, I like the watch far better than carrying a phone with me on rides. There's really something nice about being away 4-10 hours with no way to reach or be reached.
The Garmin app is OK for simple tracking of distances, steps, or sleep. For riding though, I prefer the format of Strava. I keep it private, have no friends, and don't follow anyone. Used this way, it's not a ton different than the Garmin app but it works a little better and has a nicer interface.
So to answer your question, get a Garmin and link it to Strava. Private if you like.
Liked 1,693 Times
Please pay attention.
I replied to they guy that posted "Get a Garmin it does not need your phone until the ride is done." A Garmin does not need your phone when the ride is done.
My last two Garmins have been able to connect to wifi and connect to my phone via bluetooth. Neither of them need my phone because the data can be uploaded via USB.
Key word throughout: "need."
Quoted: 440 Post(s)
Liked 264 Times
yes, but all I do is hit save when I finish my ride. By the time I put the bike in the house the ride is saved and already uploaded. No need to plug into usb after the ride, much easier. And I don’t need something to plug the usb cable into, what you use.
Quoted: 440 Post(s)
Liked 264 Times
Dan
Dan
