Seat post keeps sliding down while riding
Bikes: '72 Raleigh Super Course; '90 Cannondale ST1000; '98/99 Cannondale T700; 2002 Cannondale CAAD5 R700; 2022 Cannondale Topstone 2L
Quoted: 163 Post(s)
Liked 338 Times
I replaced the seat post on my 84 Schwinn Voyageur SP recently, and now it frequently slides down while riding. I've made sure the bolt is tight, but it doesn't seem to ever hold completely. The seat post is 26.6, which should be correct for the year and model. I'm wondering if the bolt is a replacement, and isn't able to tighten properly due to being too long, or if the Voyageur's cable hanger could be the culprit. Has anyone else with a Voyageur (or similar cable hanger) had this problem before?
I've attached some cell phone shots of the seat post bolt — boosted the shadows a bit to try showing it more clearly.
Quoted: 4172 Post(s)
Liked 3,793 Times
Simple experiment is to remove the brake hanger/stop and then ride the bike and see what happens. Or sub a different bolt that isn't an Allen wrench one. In the as imaged condition can you pivot the cable hanger about (with the cable tension released)? If not then the hanger's thickness is possibly the reason the lug won't clamp the post fully. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Looks like the cable hanger. If you cannot loose the hanger, then get a 26.7/26.8 seat post. Adapter sleeves may work.
Also make sure that everything is squeaky clean, use alcohol to make sure there are no oils and such
Quoted: 163 Post(s)
Liked 338 Times
EDIT: Measured the seat post with a caliper and got anywhere from 26.492 to 26.516. Are seat posts typically smaller than marked? Fully tightened (hanger in-place), the seat post opening measured 26.67 with the calipers.
Quoted: 2350 Post(s)
Liked 1,729 Times
The old seat post probably is marked, but with 30+ year old seat posts, I often have to use both a bright LED task light and a magnifier to find it.
Are the bolt/nut bottoming out?
Is the cable hanger original?
Also, if you have it, there's nothing wrong with trying some carbon assembly paste in there.
Quoted: 1438 Post(s)
Liked 1,092 Times
There you go, the opening is larger than the post, so it will not clamp tightly. I would suggest moving the cable hanger to one side as suggested and see if you get different results.
Half way there
Quoted: 985 Post(s)
Liked 879 Times
I would recommend first to file the hanger a bit thinner at the clamp end. Half a mm make make all the difference.
Likes For Moe Zhoost:
Liked 3,793 Times
It's late enough I'm not going to ride again tonight, but tomorrow I'll try tightening with the hanger removed to see what happens. The hanger can't be moved so that may be the problem, but it's original to the bike so I feel like it shouldn't be the cause, right? I'll try a different bolt as well.
I hadn't thought of an adapter sleeve, thanks! I guess it's worth noting, this didn't happen until the seat post changed. Maybe this new one isn't as truly 26.6 as the last (if the last even was — no markings of any kind). I'll also be sure to give everything a good cleaning before doing anything else.
Here's a link to a seat post size thread from a few years ago. I decided to actually measure the various posts I had on hand with a nice micrometer. Scroll down to post 8 https://www.bikeforums.net/bicycle-m...post-size.html Andy
Then check oy post 12. This last one is the key IMO. Andy
AndrewRStewart
AndrewRStewart
Liked 1,092 Times
Measuring a seat tube with calipers will give you inconsistent measurements. The insert type of gauge is best. I'd say that from your measurements, the 26.6 spec is probably accurate. It's clear that the cable hanger is interfering with the clamping, and this is easy to check. To fix, you can move it to the side as others have recommended, mount a different hanger (like the one in the picture below).
I'm on the side of the >rear brake hanger is interfering with the seat post clamp squeezing the post sufficiently..< team.
& it looks like the post is chromed steel too..
Quoted: 163 Post(s)
Liked 338 Times
I'm learning quite a bit from these responses, thank you! I have a background in woodworking so I'm familiar with listed dimensions not being a true representation. I wasn't sure if that also applied here — now I've got my answer. I tried moving the hanger to the side but still had slippage. It actually seemed less secure. I'm gonna see if the bike shop has some carbon grip since so many people have suggested it.
What's the significance of it being chromed steel? More likely to slide???
Friendship is Magic
Bikes: old ones
Quoted: 26251 Post(s)
Liked 10,232 Times
...I don't know about the newest ones, but over the years they vary as much as .1 mm from the diameter marked on the post. It's best practice when replacing a post to measure the old one with calipers, and try to replace it with a new one you measure with calipers to make certain they are close. The best measure of a post to seat tube fit is sliding it in and feeling it make contact with the seat tube as it slides down, which is often not possible when you are buying a new one off the internet. You want to feel just the slightest bit of resistance as it slides down into the greased tube, ideally.
Quoted: 1936 Post(s)
Liked 2,150 Times
So I’ll give you some bad advice. Take a thin file and remove a little thickness off the ears and see if it helps. If we are really talking about .2mm (.008”) I doubt the bike will fall apart. Mine didn’t... at least not yet.
John
John
Liked 1,729 Times
So with the brake hanger out of the way, you were still unable to get the ears to come together enough to grip the post tightly enough? Did the ears come all the way together with the brake hanger no longer between them? If not, then you need to check (still no answer) if the bolt and nut are bottoming out.
Quoted: 163 Post(s)
Liked 338 Times
I definitely should have checked the old seat post more carefully. It was pretty trashed when I bought the bike and wouldn't maintain the seat angle. I'd start riding with a nice level saddle, and 20 minutes later it'd be pointed towards the sky, applying lots of unwanted pressure. There were no markings to be found. The 26.6 was obscured enough that I checked the old Schwinn catalogs to make sure it was 26.6 and not 26.8. I tossed it as soon as the new one arrived, trusting the numbers a little too much it appears. Live and learn!
I ran out (in some stupid hot heat) and grabbed a tube of Park Tool Supergrip Carbon and Alloy Assembly Compound yada-yada — what a name! Applied it to the seat post, installed it (noticed more resistance even at this stage), and gave it a weight test in the apartment. The seat post seems to be unmoved. It's still stupidly hot, so I'll wait until this evening to give a test ride, but I'm feeling cautiously optimistic right now.
At this point, I don't believe the bolt is bottoming out. The ears definitely came together more tightly but the post still slid pretty easily with pressure applied. The carbon grip seems to have made a difference. I'll find out later tonight.
Quoted: 172 Post(s)
Liked 304 Times
Posted to Rooney just now in the C&V forum that my 1984 has a 27.2mm SR Foursir seatpost, so the catalog and PDF are incorrect for the SP at least.
72+76 Super Course, 74 P-10+ 79 Tandem Paramounts, 84 Raleigh Alyeska, 84 Voyageur SP, 85 Miyata Sport 10 mixte and a queue
Liked 1,729 Times
^^^^^ Wow, HUGE difference. That means that with a 26.2 post, the seat lug ears are being squeezed too close together. OP should definitely go for a larger post. Fortunately, 27.2 is a very common size and easily found.
Quoted: 172 Post(s)
Liked 304 Times
Double-checked this morning and it is 27.2. I don't know much about different tubesets, but perhaps 26.6 is correct for the Tenax tubeset used on the Voyageur, but incorrect for the SP/SLX tubset on the Voyageur SP. Both the 1984 and 1985 catalogs show 26.6 for both variants..
Quoted: 163 Post(s)
Liked 338 Times
I went for a ride today without any problems. The carbon grip seems to have solved the issue for now. I'll continue keeping an eye on things. I am still interested to hear what either of the other 84/85 SP owners in the Voyageur thread have to say about their seatpost diameter.
Quoted: 163 Post(s)
Liked 338 Times
UPDATE:
I posted this in the Voyageur thread, but I'll post it here as well in case anyone comes across this later. This thread has three more 84/85 VSP owners, in addition to Schreck, saying their seatposts are marked 27.2. So, it would seem I do have the wrong size on my bike currently. The carbon grip has been holding, but I think I'll be looking for a 27.2 seatpost now.
