Strong Wheel build with Ryde and shimano STX
Off grid off road
Hi all
I am about to begin my on-a-budget 26” wheel build for beating up and down our track plus some long distance touring in the near future, and I would like to know your thoughts and opinions: (because I am a masochist)
I have brand new 36 spoke Ryde Andra 30 rims, and have just found and hit on a set NOS 7sp Shimano STX hubs for a low price.
Next up is to order the spokes now that I can calculate lengths. These will ideally be DTSwiss plain steel.
Time to get out Robert Wrights’ “Building Bicycle Wheels” once again...
That is the plan, now that I have committed to the Ryde rims and STX hubs, there’s no turning back.
Ryde Andra are really nice for heavy duty touring. If it were me I would spend the extra for double butted spokes, at least on the NDS of the rear wheel. Butteds spokes have more than enough tensile strength and are more resistant to fatigue failure at the elbow. Only reason to use straight gauge spokes is cost.
Likes For cpach:
Quoted: 4198 Post(s)
Liked 3,850 Times
I'll add that a 7-spd freehub body will limit future options. Not a bad thing but perhaps regretted in a few years... Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Off grid off road
There is another steed with more gears that could also use new wheels, so once these wheels are tried and tested I shall likely be building further sets.
Off grid off road
Perhaps I could stretch to DB up front too.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
I recently built up a tandem wheel with the Andra 40. Amazingly strong rims. Nearly impossible to twist them by hand.
Quoted: 1188 Post(s)
Liked 1,154 Times
You'll actually build a stronger wheel with butted spokes. The stretch in butted spokes helps kept nipples tight, especially on the NDS. If you really want the gold standard then use DT Swiss Alpine III.
Incidentally there is a lot of interchangeability between various 7/8/9 speed Shimano freehubs, mostly the difference are in the dust caps, so if you can get them out without munting them you can swap away.
Off grid off road
Great advice chaps, thank you.
Quoted: 1943 Post(s)
Liked 2,164 Times
I’m trying to figure out what rider out there that can push a 46-11 wants the gaps of a 7 speed.
I still ride 7 and 8 speed and feel fortunate to have some 13-34 cassettes (with the 29t) stashed away for my mountain bikes.
I also have a few Sunrace 12-34 8 speed that has decently gapping. That has been a surprisingly nice cassette.
John
Off grid off road
I forgot to follow up with this post; here is the newly built front, plain gauge spokes, (the rear has plain gauge and butted), since heavily used last winter and showing no signs of fatigue. I have had to re-tension a little as when I built them I did not use a tensioner, which I since added to my tool kit.
As it happens I was not too far out when I initially trued the wheels by feel.
The rear cassette was converted to 9 speeds without a problem 👍
Thank you all for your input.
Likes For Deepcherry:
