Removing Dura Ace handle bars
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times
It doesn't look like it takes a hex head wrench and the bolt doesn't go straight down the
head tube like my other bikes .It's at an angle.
Quoted: 2337 Post(s)
Liked 2,818 Times
sounds like your dura-ace AX again (case you have not guessed the AX group with all of it's aero design is an odd duck)
it seems they have and internal clamp..
guessing that you pop the dust cap and use long 6mm hex thru the stem to a bolt
Velo base is your friend
VeloBase.com - Component: Shimano HS-7300, Dura-Ace AX
came with a long 6mm allen key as clamping of both the bars and quill were performed internally.
The quill clamp bolt has 2 different threads so the tapered wedge was tightened or loosened depending which way it was turned and did not require hitting with a hammer to release. I know of 9,10,11,12, & 13cm. Shorter may have been made...
Likes For squirtdad:
Quoted: 677 Post(s)
Liked 459 Times
Liked 2,818 Times
again no hands on i just found these because i saw them a while back when looking up same period not ax dura-ace
Quoted: 677 Post(s)
Liked 459 Times
my best guess is yes that is the dust cap there was a comment in the velobase suggesting that comment: "hi i'm looking for Replacment for Dura Ace AX aero stem metal dust cap Alloy, anyone could say me where to find it?"
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
Quoted: 677 Post(s)
Liked 459 Times
SE Wis
Liked 3,390 Times
Quoted: 677 Post(s)
Liked 459 Times
Maybe you should strip it down to the frame & rebuild with more common components ..
Probably why the seller got rid of it, maybe bought and flipped it.. promptly..
Quoted: 677 Post(s)
Liked 459 Times
the seller didn't know much about what he had. I paid $190 for it and he found it
at a thrift store for $20
I think its angled because its just a cap.. unscrewing it, lets you access the handle bar clamp bolt forward
and the quill wedge bolt downward, , 2 separate things...
SE Wis
Liked 3,390 Times
Quoted: 1324 Post(s)
Liked 927 Times
Dura Ace AX stuff was only made for about three years. Thus it's fairly rare to see new old stock parts for it and that increases the prices of those parts.
Btw, the spindle of the bottom bracket is NOT compatible with a lot of newer stuff. Here's a reply I got about that about five years ago.
"The taper is the same. The sections of that taper are different.
All quality spindles from the first aluminum square tyaper
systems in the 1930s shared one format, rightmost here:
https://www.yellowjersey.org/photosfr...t/3SPINDLE.JPG
Your Dura Ace FC7300 takes that style and fortunately
interchanges with classic Record/N.Record 1960 though 1986
which is an asymmetric spindle (as are most classic designs).
Compatible sealed units are Phil Wood #2 , Stronglight sealed
Piste, Mavic (model? 1980s) and others, not by Shimano nor
Campagnolo."
Good luck and cheers
