Just when I thought I had it all figured out
Picked up a new bright red Domane SL 5 last month for my 59th birthday and with the proceeds from selling my Domane ALR 5 I decided to order a Light Bicycle WR45 (32mm width x 45mm depth) carbon wheelset to go along with it because hey... they're carbon. I made sure to buy the tools needed to exchange the cassette and rotors. Wheels and tools arrived today, those carbon rims are beautiful and perfectly round. I just wish I would have given a bit more thought about the inner tubes. Mine only have 42mm stems.
Oh well, Amazon should be delivering some 60mm long ones tomorrow. In the meantime, did I mention these wheels are beautiful AND weigh 1.3lbs less than the stock wheelset? Will they make me faster? Doesn't matter to me, they look awesome and at 6'3" 225lbs I will never be that red mustang passing you up the next rise. I prefer to think of myself as that bright red Peterbilt model 579 gaining on you down the mountain.
Hopefully I can get a picture of the bike with wheels and tires up tomorrow.
Ben
Ben
Likes For BenBoozer:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4365 Post(s)
Liked 3,000 Times
If your tubes have replaceable cores, then...valve extenders
Quoted: 850 Post(s)
Liked 344 Times
Congrats on the new bike. I took a look at the SL5 myself. I was very interested in a "comfort" bike since I already have a performance-oriented road bike (Fuji SL1 Pro).
I am also thinking about the Trek 520 which could my comfort bike and double as a touring bike or even a gravel bike.
I test rode the SL5 and found the steering a bit heavy. The sales person said it was due to the tires (32c), but I must admit it was very comfy. If I did buy it, I would want to keep fat tires on it. What do you think about the bike?
Liked 3,000 Times
Fair enough. I didn't mean to boost any particular brand. I was just highlighting the concept.
Likes For MinnMan:
Quoted: 4717 Post(s)
Liked 1,882 Times
Likes For noodle soup:
Quoted: 1814 Post(s)
Liked 923 Times
This sounded odd, so I measured a bunch (~20) of stems and extensions, and did not get that result. 5.83mm- 5.95mm, w/ threaded stems being the biggest, & Conti extensions on the smaller end.
Quoted: 850 Post(s)
Liked 344 Times
The issue is that if I press the chuck onto the conti valve extension as lightly as I would a regular stem, it leaks or just doesn’t stay on. So I have to press it on super hard. That’s not a massive issue. But pulling the chuck off is a much bigger problem, especially if you have bladed spokes.
I guess it could be that the conti valve extensions require deeper insertion to form a seal? Am I the only one?
Finally got the correct tubes and wheels mounted. I’m loving how it looks! Will follow up after my first ride.
I used tubeless for about 5 years and grew more and more disenchanted with them. They STILL get flats by getting a cut too large for the sealant to seal. You can carry "bacon" or a tubeless "plug" and tool but these are normally so large that it destroys the cord of the tire and the tire is a throw away. If you try to simply put an innertube in them the sealant is really yucky. Also, the latest tubeless tires are EXTREMELY difficult to put on. I broke 2 carbon wheels even with the latest "tire jacks" which are supposed to prevent this and allow you to install even stubborn tires. They don't. I have gone back to clinchers and innertubes and the joy of being able to mount both tires and tubes in 20 minutes was indescribable.
Likes For RiceAWay:
commuter
To add to that: The Schwalbe Pro One I had to plug with a Dynaplug could be patched just fine. Not that I needed to patch it per se, the Dynaplug did its job. But the metal "bullet" of the Dynaplug detached from the cord after a while, and rattled around in my tire and I could not stand that
Likes For swifty:
Quoted: 152 Post(s)
Liked 173 Times
If you want to spend a little more money you might want to look into getting a Bontrager Flare RT taillight and using the mount that goes on the top knuckle on the seatpost (if you don't use a seat mounted bag). It really cleans up the look getting the light off the seatpost and you almost don't know there is a taillight there unless you look closely.
But, I do like to carry a bit more than I could fit in the down tube so if I were to buy the SL5, I would end up with a seat bag anyway.
I already have the multitool, spare tube, co2 and tire lever plus some money stored in the down tube. I love that feature for when I want to travel light. I have a seat bag if I really need to carry additional items. As far as the tail light, that is the original Flare R in the photo, I will get an RT when this one dies but it would block the use of a seat bag and I don‘t think the RT has the amber side flashers that the original has.
Now as far as the bike is concerned, I have never ridden a more comfortable bike than this and with the new wheels, the ride is even better with the same tires. They expand about 2mm wider and I am running at 5psi less pressure which combines for dare I say, a lush ride experience. I don’t need a bike that will leap out of the gate or be as nimble as a deer, not entering any races at 59 years old. It moves when I move and goes where I point it PLUS, it looks good standing still. It holds a straight line, no twitching at all. I can say that the Light Bicycle wheels are amazingly precision made and you really notice the difference once over 15mph, they want to go fast! I predict an even better ride once I put some better tires on it but for less than $3600 total spent, I really feel I got my money’s worth. Your mileage may vary.
Ben
Ben
Liked 1,882 Times
If your technique is weak, you're gonna have a bad time.
Quoted: 152 Post(s)
Liked 173 Times
Likes For August West:
Liked 1,882 Times
Using a tire jack to mount a tire, is like using a prosthetic to please a woman. If you need one to get the job done, you probably need some work on your technique.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Sweet bike. Glad you have the tire logos at the valve stem
On Your Left
Liked 2,433 Times
Likes For GlennR:
Likes For JW in AK:
Liked 923 Times
Ben
Ben
Goes with your screen name.
Likes For woodcraft:
