ca. 1976 Windsor Carrera Sport
Bikes: 1966 Paramount | 1971 Raleigh International | ca. 1970 Bernard Carre | 1989 Waterford Paramount | 2012 Boulder Brevet | 2019 Specialized Diverge
Quoted: 129 Post(s)
Liked 77 Times
Whoa. Two posts in one day after a years-long absence!
I recently picked up several frames for my earn-a-bike club, one of which was this ca. 1976 Windsor Carrera Sport. I've seen a few photos of these but this is the first time one has crossed the threshold of my studio. Anyway, I thought some of you might be interested in seeing this little thing.
Quoted: 3803 Post(s)
Liked 3,324 Times
two oddities which may be present here for you to be aware of -
a) the Carrera Sport of the 1973-74 time came through with an Italian threaded shell of 68mm diameter
b) it came through with a steerer/stem size of .833 (an artifact of the Japanese tubeset employed)
your '76 appears identical to the '73-'74 examples have owned and worked on so it may be the same
Quoted: 129 Post(s)
Liked 77 Times
I'll have to check the steerer diameter before putting this little frame to use anywhere. I'm going to rejuvenate the BB this weekend, check the spindle and bearings, and clean old/add fresh grease. I'll check the threading and width then. Thanks for those insights, I hadn't considered either.
Liked 3,324 Times
suspect you shall find that the "Maxy/TypeII" spindle in the bottom bracket is marked model 3S or 3(S) because the shell is 68mm. normally one would expect a model 5S spindle with an Italian threaded shell.
if you will be doing a build you may need to source an .833 stem for the machine. the factory original was a Gran Compe.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3870 Post(s)
Liked 6,461 Times
Liked 3,324 Times
here is an image of the frameset's Agrati lugset as loose pieces
the seat lug in the image is Malaguti style, it could be ordered either Malaguti or with regular binder ears as seen on subject frameset
the frameset's fork crown is from the Agrati "BRIANZA" lug set and is item nr. 000.8038
Likes For juvela:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2193 Post(s)
Liked 4,587 Times
Nice little frame, indeed! Thanks for sharing it here.
What's with the "upcycled" brake wheel guides? And what happened to the headbadge?
Liked 3,324 Times
Shifting is fun!
Bikes: Yes, please.
Liked 4,587 Times
Had to look up "sandow". Got this:
Somewhat surprised I looked up "sandow bike" and got this:
OK, so how does he attach?
Likes For non-fixie:
Quoted: 129 Post(s)
Liked 77 Times
I can’t say for certain because this came to me as a frame and parts only, and the guy who donated to us thought it was an Italian frame. So I’m thinking he probably got it from somebody else to begin with. That said, I am guessing there was a piece of reflective tape that went across the head badge at one time.
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,047 Times
Improvised pannier loop attachments. I've bought similar.
Quoted: 7346 Post(s)
Liked 2,453 Times
In the 70s some of us used the word "sandow" for "bungie."
