Airfoil aero bars vs traditional bars
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
After a crash into a car last week, in the rain, completely attributable to riding my road bike to work...and then it rained all afternoon, and carbon rims with rim brakes don't stop so good when wet....I decided it might be time to seriously consider a new road bike with discs. I'm currently on a Tarmac SL6, and I quite like how the bike rides. So went to local shop, they had an SL7 in my size, and it is apparently the last one in Belgium in that size also. But, it is a bit lower in the spec range than I was originally looking at. We discussed upgrading the drivetrain from mechanical Ultegra to UDi2, done. The shop also suggested, since they'll have to disassemble the cockpit, considering a bar upgrade. Specialized has a "wing" style aero drop bar that allows hiding the brake hoses and shift wires inside the bar all the way into the frame to fully conceal all hosing and cabling...
I've never ridden a handlebar like that. Thoughts? I've always been on "round" bars, how different would this be? Am I overthinking it? Or, am I going to trade off a bit of the versatility with a traditional round bar that I am currently used to having?
Quoted: 18883 Post(s)
Liked 10,646 Times
Completely hidden cables are a nice, clean look.
The wing shape bars can be more or less comfortable on the tops depending who you talk to and probably the size of your hands and the bar, and how you hold it. I find traditional round bars more comfortable in the tops. But don't use that position very often. Riding in the hoods and drops is the same.
The foil shape is more aerodynamic, but your handlebar isn't a big part of your overall frontal area so that's a marginal gain at best.
Quoted: 532 Post(s)
Liked 621 Times
Look, man, I'm a realist, I'm gonna gain exactly 0 seconds over any distance with the airfoil. So, it's not about that at all...the idea is intriguing for the cleaned up look, and spec'ing the bike closer to the specification I was hoping to buy, until I realized COVID has caused a run on bicycles that is nearly as dramatic as toilet paper. But, I can work with the shop and get the upgrades necessary to get the specs I want.
Likes For Badger6:
Quoted: 20801 Post(s)
Liked 9,448 Times
I have some aero handlebars (Easton EC70) and I love 'em - they're a clean, kick-ass look and I find the flat tops to be comfortable, even bare-handed (it's a position that I use quite a bit when riding solo, but I don't put a lot of weight on my hands, so YMMV). The only bad thing about them was the install - getting hydro lines and shift cable housings through them was a pain in the ass. If you don't have to deal with that, all the better.
Likes For WhyFi:
Quoted: 532 Post(s)
Liked 621 Times
How are they climbing? Thats really when the tops matter to me (I'm not an accomplished climber). Not like I have monster climbs here in Flanders...but, I do plan to go back to the Alps/Dolomites to ride with my mates there.
Liked 9,448 Times
I have very little climbing in my area and I'm not the climber-type, either. That said, when I do place my hands on the tops during a (short) climb, they're fine. My hands are either resting lightly or pulling slightly and neither is uncomfortable (the leading edge is rounded enough that it doesn't dig in or anything).
Bikes: State Bicycle Co. Undefeated Track SS/FG, Lynskey Helix-Bronze
Quoted: 115 Post(s)
Liked 204 Times
Those airfoil bars are very wide on the tops and it isn't for everyone. I'm like you and favor "round" bars; in my case, more so round bars with deep drops as I spend the majority of my riding with my hands in the drops. Over the years, I tried several bars that had aero or ergo tops with semi-deep drops and always ended up going back to round bars. When I first built up my Storck, I opted for a 3T Tornova because it had the traditional bend and drop with an ergo top. I replaced it with the 3T Superleggera Stealth and haven't looked back; I even bought another 3T Superleggera Team for my newest build because the constant taper from the drops all the way up to the tops/stem feels so comfortable for my hands.
Likes For primov8:
I have a 2021 Cervelo S Series with Di2, and it has the aero bar with fully integrated cabling. It's a clean, nice look and *slightly* more aero. I mainly just like the look of not seeing any cables.
I have around 500 miles on it now, and there are a few practical considerations to consider. Do you actually ride on your tops? I don't, so I don't care about the flat shape, although I do find it comfortable the few times I've used it. But if you do like to ride on your tops, you may want to lay your hands on the bar to make sure you like it.
The other big thing is if you ever want to change your stem. At least with my bike, I'd have to disconnect the brake cables and rebleed the system afterwards with a stem change. But you have a lot of time on a very similar bike, so I think you should be able to get the right length stem now. Unless of course you like to constantly tinker with your fit.
Quoted: 1814 Post(s)
Liked 923 Times
They look cool and concealing the cables is nice but could be a hassle with hydro brakes.
Make sure that if there is no round real estate to mount lights, etc. that you are OK with fussy and expensive special mounts.
Likes For woodcraft:
Quoted: 479 Post(s)
Liked 277 Times
I have the Scott one-piece aero bar and love it. That flat top is really comfortable. Most (all?) aero bars accommodate out-front mounts for computers and lights - nets a very clean setup.
Likes For Zaskar:
Liked 9,448 Times
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
The comfort difference is real. I'm actually thinking of putting the widest aero drop bars I can find on my cross/gravel bike. The hand positions are great. Forget aero. That palm resting and reduced pressure is nice.
Some of the aero bars you also "gain" a "virtual" hoods position. The reach may be a hair more at the actual hoods, but the flattish comfortable area of the bar starts right behind the hoods and has a hand area for less reach. Like the 3T ones. It's tough to describe, but I notice it.
Liked 923 Times
If it works for you, great- just a heads up for the OP.
Another obscure point is that some computer mounts don't have room to plug in a cable for back up battery, if needed for long distance.
Liked 9,448 Times
Plus buying mounting adapters for the lights you use and what if those are also used on other bikes, no place to mount back up light or other bits, and no ability to adjust the computer for glare.
They have adjustable models for a small increase in price, but glare hasn't remotely been an issue with either a Wahoo or a Garmin (plus, it just looks better when it's in-line with the stem). The GoPro-type mount is one of the most popular out there - many lights/cameras come with them, otherwise they're a pretty inexpensive accessory. Many head units have more than adequate battery life for 99.9% of the rides and riders out there; if you're the odd-ball that occasionally spends 16+ hours in the saddle at a time, that's probably a requirement that you lead with as opposed to an oh-by-the-way...
I put aero bars on my R3 and I love them. Super comfortable when up on the bars. I like it a lot better than standard bars.
www.mp-aviation.com
www.mp-aviation.com
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
Dunno if there's a version for fully concealed cables, but I'll take this opportunity to pimp 3T's Aeronova shape again. Such awesome.
Aside from looking the tits, the way the tops curve down towards a hump behind the hoods is extremely ergonomic, and even better, enhances safety by catching your hand if it slips off the side; it's perfect for the virtual aero bar position. Also, the way the wing flares out at the stem provides really good ergonomics and security for when you're riding with one hand.
And again, they look frikkin' badass.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4361 Post(s)
Liked 3,000 Times
I have bars like that- Easton EC90. But I pretty much never put my hands the aero part (or their equivalent on regular bars). When it's safe, I do lean my forearms on them in something approaching the praying mantis style, and the flat area helps make that work. Otherwise, my hands stay in various positions around the hoods or in the drops. I love the bars- they are comfortable and I like how they look. I have no inkling if they have any effect on speed. The biggest inconvenience, already mentioned, is that you can't slap on any old light - you need the right mount. I have the mount that WhyFi suggested and I've got an adaptor to bolt my light to that underside Gopro mount. I
Likes For MinnMan:
Liked 923 Times
Don't throw your back out with all that reachin' on your double-down.
Careful of your own back as well.
Quoted: 4788 Post(s)
Liked 3,914 Times
How hard is it to run new cables and housing? Is that a concern for you? Do you do your own work or have the shop do it? I have heard nightmares from mechanics changing cables on some hidden cable bikes.
Packers Fan
I ride on the tops pretty often when cruising along, as it allows me to sit upright and relieve pressure on my arms and hands. I still haven't figured out how to eliminate hand numbness, despite getting fitted for my bike and doing core exercises daily.
I have thought that the aero bars would offer a wider surface area for me, and that alone might be a big benefit.
Quoted: 532 Post(s)
Liked 621 Times
Likes For Badger6:
Quoted: 532 Post(s)
Liked 621 Times
The shop will set it all up, since it is a new bike, and this is being upgraded before I take the bike home. I normally do my own work, and I am fine with running cables and hosing, I do it now...understanding that the turns and bends will be tighter and will take longer in this particular case.
Quoted: 532 Post(s)
Liked 621 Times
Plenty of cobbles and pavé here...already put a clutched derailleur on my existing road bike because I kept dropping chains. So this is good news!
Likes For Badger6:
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
