Upgrade classic Carbon or buy new?
Bikes: Look KG386
Quoted: 5 Post(s)
Hello,
I currently have a 2003 Look KG386 Carbon bike with Record 10s groupset (updated Ultra Torque Crank). I have been debating on whether or not to upgrade the groupset or just buy a new bike. Not sure which is a better move. The bike is really light, more so than the about 2kg lighter than the new one I am looking at. Based on my current research it seems like I can upgrade to a Record 12s for about $2K. On the other hand, I have been looking at the Trek Domane SL5 with Shimano 105 for about $2,800. Not sure how the 03' Record compares to the current year 105 groupset, but like the look and features of the new bike. Essentially, I bought the Look second hand and can spend money ensuring proper fit, or start with a bike that fits me from the get go. Any thoughts?
Hello,
I looked at the Domane with 105 and its obvious why the entire group-set is less than $500.
Once you have Campy there is no looking back. When shifters go on Shimano its 200 bucks and up. When Campy shifters need attention its $12 for springs and $10 for the spring carrier and its brand new.
You won’t be happy with 105.
Bikes: Look KG386
Quoted: 5 Post(s)
I don’t think you can compare 105 to even old Campy components. I have 2008 Chorus components and can’t get myself to buy Shimano for a second bike. I would keep your components but have the shifters rebuilt and get a new frame. A Campy pro shop will completely refresh your group set for $100. There are lots of great frames.
I have read a lot of post that have similar thoughts on Campy groupsets. Just haven't seen anything that addresses modern low/mid tear shimano to 20 year old Campy. This is the first and only road bike I have ridden, so dont have experience. Have been considering the aspect of just building, but seems intimidating.
Klaatu..Verata..Necktie?
Quoted: 10421 Post(s)
Liked 11,882 Times
So, you might like the 105. Probably easier to get a wide range of gears with that than with 17 year old Campy. Not sure about new 12 speed Record, of course.
Likes For genejockey:
Quoted: 3948 Post(s)
Liked 7,291 Times
Likes For tomato coupe:
Liked 11,882 Times
Shimano vs Campy is mostly a matter of preferred ergonomics. Both work very, very well.
Likes For HTupolev:
Quoted: 6958 Post(s)
Liked 10,959 Times
A 105 brifter tends to be around $100 new. Ultegra-series are around $140, it's really only with Dura-Ace that you start to crack $200. Furthermore, it's not really that common for Shimano brifters to irreparably go out. Campy does have the edge on shifter serviceability, but you're massively exaggerating the issue.
(Oh, shoot, now I jinxed myself. A shifter will fail tomorrow, for sure.)
Quoted: 645 Post(s)
Liked 797 Times
Likes For Litespud:
Le Crocodile
Quoted: 369 Post(s)
Liked 787 Times
I have always run the top shelf Campagnolo on my bikes, but decided to build a "beater" with an Ultegra groupset a few years back. Wow! It's absolutely fantastic!
If 105 is anything close, it should work great.
Quoted: 237 Post(s)
Liked 177 Times
105s got much better in recent years. I have them on a Roubaix and it is surprisingly good.
I am also wondering about 'cheap Campy gruppo refreshes.' I live in Albuquerque. These days, any wrench capable of doing such work will avoid it (bcos pandemic bike rush = other, less problematic work backed up out the door), and there aren't that many here.
To OP: Updating an old bike expensively could be the way to go; but if you're willing to drop a couple thousand, what about looking at a used upper-echelon bike that could share the same platform? I'm bringing a small herd of road bikes around (slowly) to Ultegra 2x11's, and it's nowhere near as pricey as my going out and getting a single new bike. I've spent a total of $3,900 and now have a late 00's Giant TCR-1 Comp, 2013 Roubaix Elite, and 2018 Emonda SL6 Pro with multiple upgrades across all three bikes for that money. Prior to that I was riding 2-4k miles / year on a Novara Trionfo (6-series aluminum, lovely bike but too small for me).
Counterpoint is that if you're in love with the new bike and can afford it, buy it for crying out loud. If you're filled with regret you can sell it easily these days.
Hello,
Right now I'm putting together a Look 595 and putting the Record 10 spd back on it. Oddly enough I'm installing a Campy Centaur square taper ISO crank on it. The difference in weight over a Record Ultradrive iis only 4 ounces and it is a quarter of the price. And it never wears out. I'm even back to 52-39. So it makes me a little slower on the climbs. You need an hourglass now to time me climbing. Also, unless the frame is perfectly aligned one side to the other, the bearings wear out rapidly and you have added friction. With the spindle drive, it works absolutely perfect. It's like watching a Hambini video where the only friction on the cranks is the water seals. You give them a spin and it rolls around 5 times before coming to a halt. Sometimes the old ways are the better ways.
The BB just got here so back to work.
OK, 20 minutes later and the BB is installed and the cranks are on. I can't find the long countersunk connector for the brake so I can't finish installing them. One of the wire guides is damaged so I will have to contact Look for a new one. I have also ordered a dog fang which I use on all of my bikes now so that if the bike derails to the inside that I don't screw up the carbon frame. Also new Campy cable kit should be here shortly. I have sworn off tubeless tires for life. If you have to put a tube in them out on the road you might as well start walking now. It is IMPOSSIBLE to put a tubeless tire back on without flatting a tube. And believe me, you WILL get a flat on tubeless. I went that way for three years and if I even think about tubeless again please someone shoot me.
If you think that the there could be ANY improvement with a Domaine or 105 you're wrong. I suppose you could get better braking with disks if you ride in the rain. But if you don't I wouldn't worry. The Cheap Chinese carbon aero wheels are now as good as anything you can get for a quarter of the price. I just got a new one yesterday and I was EXTREMELY impressed.
If the American carbon aero manufacturers think that charging $2000 for a set of wheels vs. the $400 of the Chinese is going to be offset by "Buy American" they are wrong. The Chinese have fully automated the wheel building now so after the rim is made it takes less than 3 minutes to build a wheel. This wheel I just got looks to me like they have now automated the rim building process. There is definitely something wrong with the claim that they use balloon molds. This wheels is simply too good for that. They have some way of making rims that I haven't seen before. So I guess I'll have to look at Enve and Zipp. Hambini said that his Chinese wheels were as good as his American wheels. I can believe that judging from my latest wheel. It is so good that I will buy its mate (I really should have bought a set in the first place. But I still have a good rear wheel and just needed a front since I have over-inflated the old front which causes the rims to delaminate.
I have a 60 cm Trek Madone 2012 6.9 - like the one that Lance used in his last victory. It has a manual Dura Ace group. It shifts better than the Campy. So what? The difference is nearly undetectable when you have the Campy perfectly adjusted.
So after I've run on and on - the ONLY thing you would gain by getting another bike is bike envy from your riding group. And then they'll go out and get something better than that and then where are you?
Likes For RiceAWay:
If I were building a beater now, I would use 105 and BST bottom bracket. I HATE Italian threads. Even my Colnago is Taiwanese, I think, because it has BST bottom bracket The construction of my CLX 3.0 is better than a C64 in my book.
Easy: New bike. You never know when your bike might be out of commission for something like a flat tire or scuffed bar tape. Answer: more than one bike.
Expired Member
Quoted: 3662 Post(s)
Liked 5,408 Times
The fit is key. If the Look doesn't fit, move on. If it does fit and you feel the need to change the entire group, you don't need to pay $2000 for 12 speed Record. You can get either a Chorus or an Ultegra group for $800+/-. Either would be an improvement over your 17 year old stuff, plus give you wider gearing which most new riders appreciate.
Quoted: 1851 Post(s)
Liked 678 Times
I say new bike, but I am basing that decision on the fact that your Look KG386 frame is going to be like riding a wet noodle compared to modern carbon frames. It's not really a "classic" bike. It's just old, and carbon bike frame building has advanced a ton since that KG was made.
Regarding your components, yes, 10S record was nice, but pretty much any current groupset from 105/ Rival / Chorus up is going to perform as well or better. And while I agree that having the Record set refreshed and overhauled is a great idea, I think you are going to be very hard pressed to find a shop with mechanics competent enough to do that.
Likes For topflightpro:
Liked 10,959 Times
A side note: While there are plenty of "classic" steel bike frames, old cf frames are just old.
Likes For Koyote:
Quoted: 2604 Post(s)
Liked 1,926 Times
Only if you can (a) find the parts (they're not making them any more) and (b) you do the work yourself. I think I paid $40 for a new spring carrier last spring, and the one time I had a shop do it, the labor was $75, IIRC. For a single brifter.
Likes For pdlamb:
Expired Member
Liked 5,408 Times
^^Yep. Also if the Campy is from the past decade springs won't do it, have to replace the entire shifter innards. This is an old saw that won't die.
Likes For shelbyfv:
Quoted: 942 Post(s)
Liked 526 Times
Interested in this as well. What does a complete "refresh" for $100 mean? The cost of parts and labor makes me think this is refresh is mostly an inspection.
Likes For jadocs:
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
As a guy who runs Campag on both his bikes, I would not agree with this. Shimano 105 is excellent and honestly shifts very similar to a chorus level campag system and is miles ahead of something like Centaur.
Likes For vespasianus:
Sunshine
Quoted: 10954 Post(s)
Liked 7,483 Times
I dont plan my builds based on the small chance a shifter will break. But if I did, I dont think I would be willing to pay over 2x the cost up front(Chorus vs 105) just for the small chance that a 105 STI breaks years from now.
Its cool that you like Campy. Your reasoning is just funny to me as it isnt applicable to my(or others) situation or experience.
Likes For mstateglfr:
I had Campy Chorus on a Pinarello F 4:13 around 2012 and it was truly exceptional. I would not hesitate to keep that. But I am now enjoying an Ultegra Di2 group and it is sooo incredibly sweet!
