Disc brakes are now the default on road bikes and no one cares
#501
I have a Cinelli Supercorsa that I put a Brooks Swift saddle on. It was like breaking in a cinder block, but finally we have become compatible.
#502
I'd have to disagree on that one. As a shop I can tell you that without a doubt I can't remember a single situation where any regular rider/enthusiast ever actually came to me to adjust their brakes. All seemed comfortable with turning a barrel adjuster and opening them up if you had a problem.
Since the switch to disc I see every single one of those guys. "I'm sure its easy but I don't have the tools and I don't know the first thing about bleeding brakes. I don't want to mess with it". Its one of the things I mentioned I like about disc. It has absolutely put more money into my pocket.
Also - worked on 4 BSO's today. These are "Bicycle Shaped Objects". Big box cheap bikes with no quality of components, assembly, adjustment or maintenance. All had been sitting for many years as well so rust, dust, dirt cobwebs and dead insect carcasses everywhere. All 4 had cable brakes and all worked just fine.
Though the apocalypse and leave of absence from work changes the equation slightly. So I'll probably bring the bike, cables lost inside the frame, and a puddle of the wrong hydraulic fluid to the shop lol.
#503
Quoted: 3948 Post(s)
Liked 7,291 Times
#504
Quoted: 20810 Post(s)
Liked 9,456 Times
I can attest to this...I need to recable my cross bike. I've torn apart bikes to the frame, repainted and rebuilt them for fun in my garage. I dont know the first thing about hydro brakes. That combined with interna routing means I'll bring it to the shop just for new cables.
Hydro brakes are easy, too. Most of the time, you just need to replace pads - pull the pads (there's one screw that you need to remove), carefully push the pistons back in to the calipers (use a tire lever or something flattish and wide-ish), put the new pads in (don't forget the screw) and you're done. It's literally 3 min per wheel.
Likes For WhyFi:
#505
Liked 7,291 Times
Something I find amusing is that there are cyclists who:
1. Think disc brakes are too much work, but wax their chain every week and love tubeless tires.
2. Think tubeless tires are too much hassle, but wax their chain every week and love disc brakes.
3. Think waxing a chain every week is too much hassle, but love tubeless tires and disc brakes.
53. Think tubeless tires, disc brakes, and chain waxing are all too much hassle, but use tubulars.
N. Wax their chain every week, run tubeless or tubular tires, and use disc brakes, but they can't be bothered to replace their bar tape more than once a decade.
#506
#507
By the way, My wife and I flew on the Concorde with Air France from Paris to New York many years ago. The trip took about 2-1/2 hours; with the time zone difference, we arrived well before we left. It was a pretty fancy ride, they were pouring Dom Perignon champagne freely and serving beluga caviar and pate de foie gras before we took off. The plane was quite small, two seats on either side of a narrow aisle. They had a large speedometer on the front bulkhead that told you how fast you were going in terms of Mach. Most of the time the sky outside was not blue; it was black because we were so far above most of the earth's air. When I flew, the one way price was $4,000.00 per person. Someone else paid for it.
#508
About direct mount rim brakes: https://www.bikeradar.com/features/w...s-are-awesome/
#509
Quoted: 4802 Post(s)
Liked 3,922 Times
I rode tubulars for decades and am going back to them. I've had the clincher nightmare; the tire coming off the rim at ~25mph after a blowout. I never want to do that again. I don't even like thinking about it. I've blown tubulars downhill at 40+. No big deal. I'm going back to keep it that way (and to fully enjoy descents).
A lifetime of tubular hassle vs that one crash - easy choice.
Now, waxing chains, dealing with discs and tubeless tires, naw. Not one of those exercises will help me sleep better at night.
Ben
Ben
Last edited by 79pmooney; 04-19-20 at 03:27 PM. Reason: Edit to correct poor paste
#510
Quoted: 741 Post(s)
Liked 412 Times
OMG, you must be right!!!
Likes For colnago62:
#511
Just from the outside the Concorde always just looked small. You could always tell when one was taking off from JFK from the sound. The environmentalists all complained about it and they were right. Half of NYC knew when they took off.
#512
Bikes: 2015 Lynskey R-265, 1980 Fuji America Touring Bike, Surly Straggler, 1983 Fuji Espree Urban Bike Conversion
I quite agree. Here in the arid Southwest rim brakes are just fine & disc brakes tend to pick up dust & grit. But I do like the disc brakes on my gravel bike.
So...guess Ill go go with the flow & see what the industry feeds us.
#513
Liked 9,456 Times
Are you saying that hard metal and resin compounds pick up more grit and dust than soft rubber compounds?
#514
Liked 9,456 Times
I think that your premise is off, frankly. When discs pick up grit, you know that they pick up grit - they howl terribly - and that really only happens in the wet. What are you seeing that makes you think that discs are picking up a lot of grit and grime?
#516
Quoted: 1814 Post(s)
Liked 923 Times
The nose gives more to control the bike with your thigh when off the saddle,
but the main reason I think is so that the cut-out can run all the way front and still have something to connect the two sides.
