What frames were made with Ishiwata 019?
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,844 Times
I have had 2 with Ishi022. Like/liked them both a lot.
Just thought a racier tubeset from them would be a good starting point for a performance vintage bike.
Any help appreciated in a low key, winter hunt.
FWIW =Size 60cm +/-1 (ctc)
Edumacator
Quoted: 2441 Post(s)
Liked 3,137 Times
I want to say Giant, maybe Nishiki or Bridgestone, but I remember that being more reserved for track bikes maybe?
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
I had a 62cm 3Rensho Athlete in blue that was made of 019
Likes For Dylansbob:
Veteran, Pacifist
Liked 4,844 Times
@Dylansbob has identified 3Rensho = Wondering how it rode in the large size?
With a quick search, Benotto had a model.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
Wouldn't any of these Ishiwata 019 bikes have brifters? Or maybe 9 or 10 speed?
This thread doesn't belong here.
Reported.
Reported.
Commence to jigglin’ huh?!?!
Quoted: 3811 Post(s)
Liked 6,717 Times
I’m waiting for the “show us your Ishiwata 015 bike” thread.
Likes For nlerner:
Señor Member
Quoted: 1492 Post(s)
Liked 1,096 Times
This is tubing produced in the 1980's and possibly earlier. Might you be thinking of something else?
https://bikeretrogrouch.blogspot.com...-ishiwata.html
IMO the discussion is perfectly apropos for C&V. The material apparently has been used for approaching 50 years in bike frames.
Likes For Hondo6:
Quoted: 399 Post(s)
Liked 274 Times
Sure would like to see an 015 or 017 frame in person. Anyway, if anyone is interested - here's an Ishiwata tubing catalog I found when this thread got me to googling around on the interwebz:
https://www.equusbicycle.com/bike/is...og2/index.html
Likes For IAmSam:
Liked 1,703 Times
According to this link, as far back as the 1970s.
Doesn't belong in C&V. Send this thread to the other forum. Where 3 people will see it and maybe one will answer.
Such frames were made 40+ years ago, in the 70s. Seems to me that such a frame would qualify as "C&V".
Also, last time I checked it's possible to put 10-speed or later "brifters" on pretty much any bike using drop bars. So I hardly see how the objection that, "You could put 10-speed 'brifters' on that bike" is particularly relevant. You can do that to pretty much any vintage bike if you want.
Would it be "period correct" if you did? No - just like putting early Shimano 7-speed brifters on a 1970s frame wouldn't be period correct. But it would still be using a vintage frame, as well as possibly mostly other vintage components, with a more modern drivetrain.
Just my $0.02 worth. YMMV, and apparently does.
Last edited by Hondo6; 09-21-21 at 08:17 AM. Reason: Correct grammatical error and minor wording change..
Likes For Hondo6:
Liked 1,703 Times
I don't seem to remember the OP asking about any specific frame. The question was, quoting: "What frames were made with Ishiwata019?". The OP then went on to say they were looking for such a frame in 60cm +/1 1cm, ctc.
The OP's "suggestion" removed 1/3 of the users' bikes from C&V and sent them to a forum no one wanted except the OP.
Quoted: 5888 Post(s)
Liked 3,471 Times
I dislike the Early Brifter Forum as well. If it had been put up to a vote, I would have voted against it. I think it did long term damage to C&V by dividing posters into groups that don't make a lot of sense. I'm not sure where the MTB to drop bar thread went but the majority of those bikes involve indexing. I really liked the long thread showing all the brifter conversions on old bikes. That has disappeared from this forum.
Likes For bikemig:
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,480 Times
https://www.bikeforums.net/classic-v...esent-you.html
Brent
Liked 3,471 Times
Here is a post discussing the different Ishiwata tubing sets:
Señor Member
Liked 1,096 Times
Likes For USAZorro:
https://www.udemy.com/topic/reading-comprehension/
If you have a problem with someone posting a photo of a "brifter"-equipped bike above, take it up with them. It wasn't the OP who did that. Nor did I. Rather, I responded to the OP's original question. You did not.
My reply to you above was to point out the fact that your objection was to something that wasn't related whatsoever to the OP's original question, and were instead objecting to something totally unrelated to that original question. I also pointed out the fact that your original objection that brifters could be installed was, IMO, frankly rather illogical since "brifters" can be mounted on ANY bike with drop bars - regardless of that bike's age. One purpose of downtube shifter boss covers having cable adjusters is to allow exactly that - e.g, to allow "brifters" to be installed on bikes not originally designed with them in mind.
The fact that a separate "Early Brifter Bike" subforum exists is nice, but is also irrelevant to the question the OP asked. The OP's original question didn't address shifting mechanisms at all. Rather, the OP merely asked a question about a particular frame tubing that dates to the 1970s. Thus, the OP's original question - What frames were made with Ishiwata 019? - indeed appears to be relevant for C&V, as frames made with Ishiwata 019 may also date back to the 1970s.
That's substantially before the introduction of "brifters". So no - ALL bike frames made from Ishiwata 019 cannot automatically be assumed to be "brifter"-equipped.
You also apparently further missed the reference (and link) to a previous Ishiwata 019 frame discussion in the C&V forum above.
You seem to have missed all of that. Hence my link recommendation.
Liked 3,471 Times
My bad if you posted this earlier. I was trying to move the thread back on topic.
Liked 1,703 Times
Thanks for the "present". In turn, I have a suggestion for you:
Likes For The Golden Boy:
To each is own.
Pedal to the medal
Okay, I'll join, yea the Early Brifter forum sucks. I don't understand why the mods felt it was necessary to create a separate forum for something that's mostly C&V. It did take me a while a understand what GB was referring to, but since I've been around these parts for a bit, I eventually figured it out. Sounds like there's a digital grudge here as it was WW's idea for the early brifter forum, apparently? I'm confident it wasn't done with malice and the mods were probably just trying to be nice and cater to the great community, but you know what they say about good deeds...
At the end of the proverbial day, I am here to learn more about what frames were built with this light tubing. I was surprised to see people mention Fuji, as I thought Fuji mostly used their own tubing for their bikes. If you got em, post em.
Likes For romperrr:
