KMC quick link question
Recently disconnected my chain's quick link by slipping an old cable through a link on either side and twisting it with locking pliers. Seemed like it popped and was free. Put the link together by itself and it went together with no effort. Then bought a new chain and the quick link is the same way, slides into position with no effort, chain tension pulls it together. Expected to feel a little resistance that would make me confident that it is locked. Hoping to hear people's experiences with their's. Thanks
Bikes: 2017 Co-op ADV 1.1; ~1991 Novara Arriba; 1990 Fuji Palisade; mid-90's Moots Tandem; 1985 Performance Superbe
Quoted: 390 Post(s)
Liked 574 Times
Sounds consistent with my experience.
aged to perfection
Quoted: 844 Post(s)
Liked 1,275 Times
the shimano links really "snap" into the locked position and you know it is locked.
I modified a set of Park chain pliers for just this purpose
As you say chain tension should keep it locked but if its that easy - I would be less than confident that it is locked
I have not messed with the KMC ones and probably won't.
/markp
/markp
Likes For mpetry912:
Quoted: 2026 Post(s)
Liked 1,096 Times
I have used numerous KMC quick links on their own and on Shimano chains. Have never had a problem, with any of them.
Likes For HillRider:
Mad bike riding scientist
Quoted: 6228 Post(s)
Liked 4,231 Times
Stuart Black
Stuart Black
Thanks for the replies. Flangehead, any issues ever with a chain staying connected using that link? This is my first time with this chain.
Thanks for all the replies. Morning ride tomorrow, from my house. Fingers crossed for a trouble free holiday ride.
Quoted: 114 Post(s)
Liked 119 Times
I've been using KMC (10 spd) chain and it does take some effort to connect and lock the link into place. I have to place the link on the upper run, then hold the rear wheel and turn the crank, until it snaps into place with a definite click. It doesn't take a huge force to lock it in as I do this while the bike is on the stand and I'm just using my hands.
Note, the link will hold itself together a bit before it's locked, but in this pre-lock state, the link will not travel thru the derailleur smoothly since it is slightly shorter. You can see it the link is not locked by visual inspection. In fact, I usually assemble the link on the chain's lower rung, then pedal the chain until it's on the upper run, then lock it by holding the rear wheel and operating the crank.
Liked 4,231 Times
than this type. I can’t believe that Shimano has gone back to this kind of link. This style is from more than 20 years and did fail occasionally. The link has to be bent to lock it in place and reuse can cause the link to crack. It’s a bad design.
Stuart Black
Stuart Black
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,906 Times
There shouldn’t be. They don’t rattle loose nor can they really be opened without squeezing the link together. That’s difficult to do with any movement on the chain that you’d normally put the chain through. The one caveat that I would add is that the Sram type link is far less prone to failure (like, never in my experience)
Quoted: 1084 Post(s)
Liked 688 Times
Maybe an unpopular opinion, but I still fail to see the advantage of Quick Links. If they're (technically) single use, and if it still requires a tool, I'll stick with chain pins.
Quoted: 982 Post(s)
Liked 585 Times
I've been using KMC chains on my folding commuter bike for several years. I take the chain off a couple times a year for cleaning and re-use the quick-link. I've not had any problems with the link staying connected. I need a quick-link pliers to remove it even after several openings. This is a bike with IGH, so a simple 2-sprocket chain system... with a derailleur-based drivetrain might have different concerns.
Quoted: 979 Post(s)
Liked 1,642 Times
Yep... A statement quite important to remember. I used quick links both ChiCom knock off and Brand Name consistently using them over and over and thought nothing of it. Then one day I was taking one off and dropped it on the ground and it came apart. I then went back and checked all my other bicycle quick links and found another that was loose. I don't think the brand really matters. I just don't reuse them unless I have to.
Quoted: 904 Post(s)
Liked 1,906 Times
Likes For jadmt:
Cyccommute is correct. There are two types of KMC Quick links, one is single-use and the other you can use a few times. If the link went together without a clear snap, then it's probably a single-use link. It's probably ok to use (as long as it's not a fixed gear bike) but if it were me, I'd get a 3-pack of Quick links and change it out soon. They are cheap enough to do that. FWIW, I get mine straight from KMC's web site.
For me, they are cheap enough that it's not worth the risk of a chain disconnecting, for whatever reason, while riding.
Quoted: 390 Post(s)
Liked 574 Times
I buy KMC chains, both X-10 and 8 speed. I use hot wax immersion for lubrication and I reuse the quick link, only replacing it when I replace the entire chain.
I’ve never had a link that I installed fail, and my only failure was the infant mortality cited above.
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
I won't try to persuade you on the merits of quick links, but the Connex brand link needs no tools to open or close, and it can be used multiple times. I don't know how many, because I see no wear or degradation on the one I'm using. It's a clever design.
Defective KMC quick link
I used SRAM links prior to discovering the Connex, never a problem.
aged to perfection
Quoted: 844 Post(s)
Liked 1,275 Times
I just replaced a shimano 11 speed link and it is really tight ! I had to modify a Park chain plier to spread it and it really snaps in with a very positive click.
I would much rather use a link than have to "peen over" the pin using a chain press or use that "snap off" pin. Don't trust those at all.
/markp
/markp
Quoted: 982 Post(s)
Liked 585 Times
I seem to remember a discussion about whether "single use" meant "not to be opened and then used again", or "use only during the life of this single chain". I don't remember if there was a resolution.
Wippermann "Connex" links are pretty clearly intended to be opened and closed more than once; not sure about other kinds like KMC.
I erred when I said my commuter bike uses the KMC quick links; it actually uses a quick link, but it's the kind that's three-piece with a "keeper" clip, and not designed for derailleur drivetrains... but can be re-used virtually indefinitely. What I was thinking about was my mountain bike, which has a 3x8 drivetrain. I have opened and re-closed the KMC link on that bike several times during the life of the chain without problems shifting or chain separation. But I always use a new quick link with a new chain. Same for the Wippermann Connex link on my road bike (3x9). Perhaps there's a difference with the links for 10-speeds and up.
It would seem that with these quick links as long as the chain is under tension there should be no problem. But when the chain flexes laterally, as when shifting, one side of the quick link could be disengaged, resulting in chain separation. This is an interesting question...
EDIT: Wippermann Connex links can be used with other brands of chain...
Likes For sweeks:
Quoted: 982 Post(s)
Liked 585 Times
Jeff,
Here's a demonstration video. It's 35 seconds, he opens and closes it twice.
I'll follow directions next time, but unless I've managed to unwittingly install it correctly every time, it doesn't seem to matter.
Likes For sweeks:
Quoted: 904 Post(s)
Liked 1,906 Times
don't try this at home.
Quoted: 982 Post(s)
Liked 517 Times
/markp
/markp
Then stand over the bike, and push down on the pedal until I hear the "Click!"
Connex
The Connex links worked great on my older 10 speed Campagnolo chains. Extremely easy to install or remove without tools, and never any problems or failures. I would have kept using them, but they were $30 for 11 speed (I have no idea why so expensive.) They still are $20 or $25, I see.
I just use the Shimano links that now come with the chain, and will remove and reconnect them a couple of times during the life of the chain.
I had an improvised tool, made from a bent spoke, to remove a quick link. But it was too flexy for the tighter 11-speed Shimano or Sram links.
MLP-1.2
I now have the Park Tool MLP-1.2, which work great for installing (pull the handles apart) or for removing the link (squeeze the handles together).
Liked 4,231 Times
Pins require a tool as well. If you are using replacement pins from Shimano, you are probably okay. If you are pushing the pin out and re-installing the pin on just about any modern chain, you are risking the chain pulling apart. Even a single use quick link that has been use more than once won’t pull apart resulting in a broken chain. The link may be easy to pull apart and can be done without tools but it won’t pull apart under load like a pin that has had the peen removed can.
Stuart Black
Stuart Black
