ok i was given 5 junk bikes last night, and i am not sure what one of them is
i was going by a local church last night and they were throwing away some bikes and i took them home it was dark so i didn't get a chance to check them out until today,
the first 4 were nothing interesting 2 roadmasters and some painted steel frame mountain bike, and a walmart next 18 speed,
however one of them is an aluminum frame with no markings at all, except the handle bars which are also aluminum say "horizon sport component" and it has some little rubber end caps that say kalin,
it has a serial number on the bottom of the frame and it has some shimano shifters on it,
the whole thing is really light 26' wheels and knobby tires
i will try to post some pictures later but does anyone have any idea? i googled horizon sport component and kalin and didn't come up with much
any help appreciated
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
in case you can't read it it says horizon sport component on the handlebars and it says nothing anywhere else, except for the serial number?!
magnets won't stick to anyplace on the frame so it must be aluminum i'm guessing, its doesn't look it but its light as a feather too
Quoted: 70 Post(s)
Liked 15 Times
MTB, components look to be lower end. Hard telling what it is, has the frame been stripped of paint and polished?
Aaron
Aaron
i was thinking of maybe making a single fixed gear puddle jumper out of it,
what do you think?
Insane Bicycle Mechanic
Quoted: 812 Post(s)
Liked 731 Times
I'd rather make a single-speed than a fixed gear out of it, but whatever turns your crank. It won't be the most elegant piece of machinery, but it beats turning it into a wind chime.
Jeff Wills
Jeff Wills
thanks
huh?! i googled the serial number and a huffy website came up, maybe it was an old cast aluminum huffy at one time
Quoted: 70 Post(s)
Liked 15 Times
Fix it up and ride it, can't go wrong for the price. On most low end bikes the frame is usually the best component.
Aaron
Just a guess... But one of those generic frames that Nashbar sells? You can either buy the frame or buy one that's built-up already. They are sold as "bargain" bikes that are a cut or two above the typical box-store items.
