Ultegra RX Derailleur vs 105 7000
For a bike that I'll be working on, I'm trying to decide between a Ultegra RX 800 Derailleur and a 105 7000 long cage derailleur. Would the chain length be the same for each derailleur? The reason I ask is because I'm leaning towards the 105 derailleur. However, if I change my mind later, I would prefer not to have to lengthen or replace the chain.
Location: western Massachusetts (greater Springfield area)
Bikes: Velosolex St. Tropez, LeMond Zurich (spine bike), Rotator swb recumbent
Quoted: 67 Post(s)
Liked 67 Times
My limited understanding is that as long as you don't change the gearing you should not have to change the chain length.
Method to My Madness
Quoted: 1999 Post(s)
Liked 1,506 Times
SHIMANO 105 Medium Cage Rear Derailleur 11-speed | SHIMANO BIKE-EU
SHIMANO ULTEGRA RX Rear Derailleur 11-speed | SHIMANO BIKE-EU
Given that both derailleurs have the same capacity (see links above), and that each has a pair of 11T jockey wheels, it is likely that the chain length would be the same using one vs. the other. But just in case ...
Be a little conservative when you are sizing your chain; you do not have to shorten the chain to the absolute minimum length which would allow you to shift onto the big chain ring and big sprocket combo. Leave an extra link pair or two, which should give you enough wriggle room in case the path taken by the chain through the other derailleur is a little longer.
Likes For SoSmellyAir:
Expired Member
Quoted: 3711 Post(s)
Liked 5,557 Times
Likes For shelbyfv:
Do they require more maintenance than a regular derailleur?
If the clutch stops working over time due to wear and tear, can it be replaced without having to replace the entire derailleur?
Expired Member
Liked 5,557 Times
Good questions, hopefully someone can answer. I've only ridden with the clutch off and it's like any other derailleur.
For me, that would be a pro of starting with the RX derailleur. I do have a few questions about the RX derailleur:
https://www.singletracks.com/mtb-gea...illeur-clutch/
Assuming you can get the parts, per the diagram included in the article (for a Shimano XTR) it likely should be possible to rebuild a worn-out RD clutch when it's so worn that servicing it no longer helps. But at that point, if you've been regularly servicing the clutch I'd guess the rest of the RD might be pretty well worn also.
Disclaimer: I've never used a clutched RD, so I can't say from personal experience how much additional maintenance is required. I'd suspect that varies greatly with riding conditions, with dry road riding requiring the least service and wet trail riding needing the most.
