Show Us Your Vintage Cannondale!
#152
Bikes: Some bike from late 70s to early 80s, a Cannondale, and a Raliegh
Coda Mavic x223 off a newer Dale, 13t cog/50t sprocket on Truativ crank, Clark hydro on Homemade Bracket in the rear/ Hayes up front, Oury grip on 4za bar and stem, carbon OG Evkin saddle on Truativ seatpost, 1" Threaded Frankensteined Manitou forks
#154
Death fork? Naaaah!!
#155
Quoted: 293 Post(s)
Liked 218 Times
@top506 Is that a '94 R600? I have the same year and love that bike.
#158
600 looks better, but as far as performance I can't tell a difference.
Semper fi
Semper fi
#159
Still learning
#160
Yes, it's a '94 R600, and no, it didn't come out of the dump. The frame and fork were sourced from a BF member and the rest of the build was from the parts bin. I'm still tweeking the cockpit for the correct stem reach and rise.
Top
Top
#161
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
This story starts several months ago, looking for framesets on CL and Ebay in the 66-68cm range. I already had a host of 64/65cm frames built into wonderful bikes along with a recent (last autumn) 68cm Nishiki rain/touring/winter/apocalypse build that, by the way, has performed flawlessly with minimal upkeep in a record-setting winter for Seattle (read: SO. MUCH. RAIN.), which I think we are clear of. Thank God.
A month ago or so, I came across this huge Cannondale frame, but was initially put off by the cantilevered stays, "high BB crit geometry" and steep tube angles. And I didn't really need to build up another bike. Well, the frameset never sold and I got curious. The Cannondale name of course is a good one, and heck, it has the word cannon in it; it sounds strong. I peruse the catalog after confirming year and size via the serial number, and it's a 1989 3.0, in the frameset-only 66cm size. Seller lists a properly tall standover height. Good. I calculate a 66mm BB drop, which is not bad at all, and wonder about a 74.75° head tube angle, but think here's my shot to own one of these. 7400 headset and BB and I have the basis for a build, planning on 10-speed Dura-Ace smartly sourced from CL etc as best as possible.
I snagged a gorgeous 180mm 7400 DA crankset off ebay and we were off to the races, waiting for it all to arrive. 7800 DA brakes from a guy in Portland, a killer deal on 7800 STIs, FD, and RD (FD was clamp on, so sourced a 5700 braze-on style FD). Wheels and cassette (both newer 105) I had as well as bars. Odds and ends obtained with a temporarily-borrowed (from another bike) Prologo saddle being exchanged after a day's test riding for a Brooks B17, which not only completed the look, but perfected the ride. And oh what a ride. Aluminum for the power transfer, and the long frame tubes, B17, folding tires, and low section rims for the impact absorption.
Gorgeous "vintage" bicycle--I love the cantilevered stays, red paint, geometry, and clean decals. The steep HT is dynamite in turns and is stable in descents (maxed out at 53-11)--simply sublime. 7800 DA is the business and you can feel the 180mm cranks (over the 175s I normally run) work in your favor. 22 lbs with SPD pedals. The bike wants to run. RiddleOfSteel just built himself the perfect bike for him as he pursued the fleshing out of the theory of saddle height = bar height (or super close) = extremely nice long range comfort for years to come, and it's made out of aluminum (which he never had a problem with before--the frames were too small). Who knew? Anyway, I love it, and I hope to get better pictures of it, but this will have to do for now. Rider context: 6'5" @ 210 lbs with bike at 36.0" stand-over height.
#162
ROS, Nice build.
My '89 was my intro to Cannondales, way back when. It took me awhile to become accustomed to the cantilevered seat stays, but then I looked at them as a signature design, so much so that when Cannondale returned to non cantilevered seat stays I thought they were odd looking, for a Cannondale. Now-a-days my '89 is generally rode when I want to rail some turns, which from the 'filthyness' of it's present state must have been fairly often last year!
On a side note, I have some 32 hole CXP22 rims for an '88 build that I used for awhile on my '99. While they will not win a weight weenie award, they've proven to be a reliable rim after quite a few miles on less than ideal roads.
Brad
Brad
#163
Quoted: 1872 Post(s)
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
#164
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,402 Times
Very nice. Three thumbs up!
#165
Still learning
#168
Liked 2,024 Times
Thanks, guys!
I know I could lop two pounds off pretty quickly so as to duck under 20 lbs with a Specialized Romin Evo saddle and Vuelta Corsa Lite wheelset that are on my Peloton, but I'd be back to reeeally feeling the road's imperfections. And I don't want to play the weight weenie game (again), though I always could if I was bored/in the mood. For now though I am enjoying the ride quality I have tuned (a nice 'taut' feeling) and am an immediate fan of these bikes, especially in the larger sizes. Made sure to ride it on a very rough and chewed up several block stretch of road on my way home tonight and it did as well as the best of my (humble) steel steeds--I would say better, even, but will have to try again at a higher speed.
The cantilevered stays are indeed a signature look and it didn't take me long to go, "these are cool." Dropout spacing was 127mm measured, and a 130m axle popped in with very little effort, almost laughably easy. Obviously newer aluminum at the high end is much lighter than this 3.0, and especially against same-sized steel frames, but there's less material to soak up vibration. So I'm more than happy to have the best of both worlds with little compromise (to me) in a heavier aluminum frame (yet lighter than steel) that doesn't turn into a Ryobi tiller (the ones with the motors mounted midway up the stalk) over crummy surfaces.
#169
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
Or they turn into dead feeling hunks of aluminum after a couple thousand work cycles -- then the thrill is gone and a person is re-considering steel
#170
Liked 2,024 Times
Well, then I shall certainly have quite the number of eligible backup rides should the C'dale fatigue during my stewardship of it.
#174
Bikes: '17 Access Old Turnpike Gravel bike, '14 Trek 1.1, '13 Cannondale CAAD 10, '98 CAD 2, R300
Quoted: 1571 Post(s)
Liked 12 Times
#175
Aluminum riding "lively" is a myth all it's own. Every one I've had beats the crap out of you and gets the job done by stiffness. Its the main reason I only ride C'dale mountain bikes for the most part. Fatter tires = smoother ride.,,,,BD
