Handlebar riser for Canyon Commuter
Hi. I was thinking of getting a nukeproof neutron V2 riser either 25mm or 38mm. I bought Canyon commuter sport 8.0 with a flat bar. Frame is a bit too aggressive for my body profile and my arms end up being too stretched. Uncomfortable after a while on my hands. Looking for a more relaxed ride without comprising too much the feel of the bike. Given that the stem is bespoke and Canyon made I'm not able to adjust height/reach through that. Wondering if the 25mm is sufficient or should I go straight with the 38mm?
The bike is intended for short commutes to work and family rides on the weekend. Comfort is important to me.
Thanks
Thanks
Quoted: 6193 Post(s)
Liked 4,808 Times
Hard to say without knowing anything else about you. The Canyon Commuter Sport 8.0 is perhaps one of the most aggressive of the bikes marketed as commuter. It's going to be a sporty handling bike and if you don't ride it like a sporty handling bike you won't be comfortable on it. Is it too late to send it back?
Otherwise, did you get the frame size that they recommended for you? Or is it too big and you are really stretched out? Personally I don't like flat bars because to me they put your hands and wrists in the wrong position for the entire ride. If I didn't have drops, I'd at least go for a cruiser style bar. Bullhorn bars or butterfly bars might be a better choice still or even a mustache bar. Anything would be better than the simple flat bar to me whether it has a rise or not.
But you are correct, the stem and design of the Canyon might hamper your choices with doing much. So that's another reason I suggest send it back if you can.
Have you considered a riser flatbar instead? i.e. one with the correct stem/clamp diameter.
e.g. KCNC does a few alu options in 1.5" and 2". You can cut down the ends to suit, if you like.
A carbon riser bar will have more compliance/comfort for the hand though.
Likes For tangerineowl:
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
there are a two main things that you can do to make the bike feel less "aggressive":
considering the proprietary nature of that cockpit, I would contact Canyon and as them for options. it looks like that stem is specific to the frame and it might be difficult to put a different one on it, which is friggin stupid! Canyon makes cool looking bikes that can't be adjusted to fit their customers' individual fit preferences.
- handlebar with more back sweep. typical flat bar has 8–10° of back sweep, but there are TONS alternative handlebar designs on the market that have a lot more back sweep. this will bring your hands closer to your hips so you can sit more upright. these handlebars also usually have a bit of rise. whatbars.com has a pretty extensive list with a graphic comparison.
- shorter length/ taller rise stem. pretty cheap change that might do the same thing. if you want to get really nerdy about it, you can find out how two stems will compare using this stem comparison tool.
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
edit: just noticed the way that bike it built. yikes! the stem advice above does not apply here, but I'll leave it in case it's useful to someone else.
If OP can find the right riser bars might be OK but I suspect this bike is not in any way what he needs or wants. Might be time to move on with this one.
