Noob Help: I can't find out how to adjust my derailleurs?
Old 02-22-21, 04:10 PM
Jacques Derrida
Jacques Derrida's Avatar
I recently bought a mail-order bike which is *basically* set up except that all the adjustments are wrong and probably whacked out by the postage. The chain sounds like it is opening the gates to Mordor.
I want to know how to set the bike up so it sounds like clockwork; except I can't because all the manuals and YouTube videos I've looked at don't really help with my bike (Which is a Kona Sutra; with MICROshift bar-end shifters; Shimano Deore setup.) The derailleurs seem so different from all the guides I have read. For example, there is not a Barrel Adjuster for indexing. There is the H/L adjustment for front and back, which I have got perfect, but everything is janky still: gear change is more 'ka-thunk-ratata-chunkᶜʰᶦᶜᵏᶜʰᶦᶜᵏᶜʰᶦᶜᵏᶜʰᶦᶜᵏ' rather than 'click.'
Do you know if there are any good resources for me to learn about this assemblage? I am very willing to read and learn to be able to service my own bike, but I am lost for where to look.
Any help would be enormously appreciated.
Jacques Derrida is offline
Old 02-22-21, 04:16 PM
dabac
Quoted: 1000 Post(s)
Liked 196 Times in 147 Posts
If there isnít a BA at the derailer, there should be one at the shifter. Failing that, there should be an inline adjuster smack in the middle of the cable casing somewhere.
I canít imagine a bike like that sold w/o adjustment ability.
If you know what a barrel adjuster looks like, you should be able to find it. They all work pretty much the same anyhow. Once Youíve found your BA, proceed according to the videos.
dabac is offline
Old 02-22-21, 04:22 PM
surak
surak's Avatar
Bikes: Specialized Roubaix, Canyon Inflite AL SLX, Priority Continuum Onyx, Santana Vision, Kent Dual-Drive Tandem
Quoted: 547 Post(s)
Liked 368 Times in 206 Posts
Should also check derailleur alignment if the bike did in fact get whacked in shipment. There are ways to do it on the cheap if you search, although I've only done it with a dedicated hanger alignment gauge tool.
surak is offline
Likes For surak:
Russ Roth
Quoted: 539 Post(s)
Liked 395 Times in 303 Posts
Some of the new rear ders lack adjustment barrels but in those situations there should have been one installed in-line in the housing somewhere near the handlebars. If it isn't there you'll need to install one, getting a rear der adjusted without some form of adjustment barrel is extremely difficult. You might want to start by seeing if the hanger is straight, I find when you put it in a gear in which the pulley are vertical you can stand back and see if it is close to straight or not, if it looks virtually straight it is probably close enough, if the pulleys look like they skew towards the wheel it is probably bent and needs to be straightened. This is the most typical bend due to shipping. Once the H/L screws are right I put the chain on the #2 cog and adjust the cable so the chain comes off the der with the same gap between the side of the chain and cog as the gap at the back and top of the cog; basically the chain off the der should run parallel with the #1 cog all the way around. If it does that then it'll shift smoothly up and down the range through all the gears with only a tiny tweak to get it perfect. If it runs parallel on that cog and doesn't shift perfect up and down the range then usually there's a kink in the cable somewhere that's the issue. But these are the trouble shooting steps I use.
Russ Roth is offline
Old 02-22-21, 04:28 PM
BobbyG
BobbyG's Avatar
Bikes: 2015 Charge Plug, 1997 Nishiki Blazer, 1984 Nishiki International
Quoted: 1122 Post(s)
Liked 885 Times in 425 Posts
These videos helped me last year:
BobbyG is offline
Old 02-22-21, 04:37 PM
HTupolev
Quoted: 1702 Post(s)
Liked 772 Times in 387 Posts
It makes sense that the front derailleur would lack a barrel adjuster. It's a bar-end friction shifter: you just move the shifter as much as necessary whenever you shift.
The rear ought to have a barrel adjuster somewhere, though. Kona's marketing images for the Sutra show an inline barrel adjuster on the rear shift housing, between where it exits the handlebar tape and where it connects to the downtube.
HTupolev is offline
Old 02-22-21, 04:53 PM
Koyote
Quoted: 2594 Post(s)
Liked 3,377 Times in 1,522 Posts
After you find the barrel adjuster for the RD and get both derailleurs adjusted, if you are still having problems then the culprit may be a bent derailleur hanger. This could have happened during shipping -- but also, some new bikes come with bent hangers. Shouldn't happen, but it does.
If you suspect the der hanger is misaligned, best to take it to a shop; any shop will have the dedicated tool and know how to use it. It won't cost you much money.
And let me add this: thank you for a very reasonable first post. I appreciate that you asked to be pointed toward the right resources, rather than pretending that they don't exist and expecting people here to walk you through the whole thing. And though you'll get good responses here, we also have a subforum for Bike Mechanics, which will be useful if you have any more issues.
Welcome to BF!
Koyote is online now
Old 02-22-21, 06:26 PM
shelbyfv
Quoted: 2151 Post(s)
Liked 1,971 Times in 1,064 Posts
You were lucky to find a Sutra. I heard they were sold out everywhere.
shelbyfv is offline
Old 02-24-21, 09:55 AM
Phil_gretz
Journeyman Bike Commuter
Phil_gretz's Avatar
Bikes: '71 Jeunet 640, '79 Peugeot PXN10LE, '88 Fuji Saratoga, '13 Motobecane Fantom29 HT, '16 Motobecane Turino Pro Disc, '16 Motobecane Gran Premio Elite, '18 Velobuild VB-R-022
Quoted: 1206 Post(s)
Liked 1,010 Times in 548 Posts
Where are you located. Maybe we can refer you to a bicycle coop local to you so that they can show you how to check derailleur (hanger) alignment and how to start the adjustment from slack or disconnected cables onward. Barring damage from misalignment, this will be straightforward.
Phil_gretz is offline
Old 02-24-21, 09:49 PM
veganbikes
Clark W. Griswold
Quoted: 2126 Post(s)
Liked 1,047 Times in 735 Posts
Bikes are almost never adjusted before they hit the box. Just FYI, online bikes can be some of the worst offenders but most bikes need adjustment of most things on it. It is not a postal thing.
For rear derailleurs you want to make sure you have checked your hanger first and make sure that isn't damaged (which could be postal) and then of course make sure the cable tension is correct and then adjust high and low gears. The Park Tool videos are excellent Truman and Calvin are excellent at what they do.
For front derailleurs make sure the derailleur is aligned properly with the chainrings and then same thing with the rear derailleur (minus the hanger).
If you are adjusting derailleurs make sure you are using the proper screwdriver. Phillips head and JIS are somewhat similar but only one is actually used on Shimano and other derailleurs and that is JIS. If you are having to adjust derailleurs a bunch stripping a screw will suck plus JIS works better in most cross head screws anyway including a lot of Phillips head screws.
veganbikes is online now
Old 02-25-21, 12:54 PM
Phil_gretz
Phil_gretz's Avatar
For rear derailleurs you want to make sure you have checked your hanger first and make sure that isn't damaged (which could be postal) and then of course make sure the cable tension is correct and then adjust high and low gears...
Um, no. Here, I'll fix it for you:
For rear derailleurs you want to make sure you have checked your hanger first and make sure that isn't damaged (which could be postal) and then of course make sure the cable tension is slack or fully disconnected and then adjust high and low limit screws to properly set the derailleur travel.QUOTE]
^ this is 100% correct, here.
Likes For Phil_gretz:
Old 02-26-21, 08:10 AM
Greyhounds
Quoted: 13 Post(s)
Liked 3 Times in 2 Posts
Since you didn't support your LBS with your purchase, take your bike to your LBS, tell them you bought the bike on-line, and kindly ask them to show you how to adjust your ders. It will be money well spent, and, you'll be supporting your LBS. Additionally, if you are not competent to thoroughly check every part of your bike to proper adjustment, please also ask your LBS to thoroughly go over your bike for safety. Again, money well spent.
Greyhounds is offline
Old 02-26-21, 10:03 AM
Phil_gretz
Phil_gretz's Avatar
^ I agree with this. Unless you have a derailleur mount alignment tool, you won't be able to eliminate this primary error source. Take the bike to a pro. Again, where do you live?
