Touring groupsets
Quoted: 595 Post(s)
Liked 281 Times
As we touch upon this subject again, may I ask if anyone has dropped the large coin on the White Industries variable square crank and chainrings?
MR30VBC ? White Industries
With this system you can have a double crankset With an outer gear that ranges from 38-52 in even tooth increments and an inner that ranges from 24-38 in even tooth increments ? In doing my math, I could replace my triple 46-36-24 with a double 42-24, 11 speed cassette, 11-34 or 11-36 and give up almost nothing. Same low or lower and only giving up one unit on the high end which rarely gets used. I would spend 90% of my time in the 42 ring anyway with the 24 being more of a bail out on steeper climbs. 103" to 18" or 19" gear inches without too big steps in between. Hmmmm
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,198 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 595 Post(s)
Liked 281 Times
I don't spend much time at all jumping between my middle and larger ring. I simply stay in my 46 until I need lower than my cross chaining will allow ( I know, I'm a very bad boy) and then drop into my middle ring for a couple lower combinations and if I need lower yet, then I drop it into my little ring for those last couple of combinations which I hope will allow me to not to have to walk my bike (not that there is anything wrong with that ; ) So for me, it would be very normal. My derailleurs can handle a 16 tooth difference, I'm thinking an 18 difference would be no big deal. I don't mind making two shifts simultaneously but I understand your point of view and others tha would rather not.
Quoted: 3451 Post(s)
Liked 1,452 Times
The cranks pictured in post number 8 above are both Campy, but you probably would not want campy because they are ISO taper instead of JIS, thus you won't find a wide choice of spindle lengths for bottom bracket to adjust chainline. But I am assuming that there are other road triples out there that have a 42 middle ring and a 74mm five arm BCD that would work.
I turned a 52T chainring into a bash guard with a saber saw, a big file, and some patience. A 52 would be a bit larger than you want as a bash guard, but would not look too bad.
Or, I have no idea if Spa would ship to USA or not. I do not recall if I ever bought from them before. They do not have the exact chainrings you want as a set, you would likey have to buy a 24T ring.
https://www.spacycles.co.uk/m8b0s109...h-Zicral-Rings
Quoted: 595 Post(s)
Liked 281 Times
MSN, I looked at this before and couldn't find a triple with BCD 4 or 5 bolt pattern that would allow for 24t and 42t rings and be more acceptable for a 10 speed drive train ( I understand there is some leeway here). Would love to hear of a combo that someone could come up with. Btw, I don't have your artistic ability in transforming that large ring into such an attractive bash guard
Quoted: 1079 Post(s)
Liked 1,017 Times
I'm experimenting with a 42/28 and 11-34 on the current rig, I do have a 26t chainring I can substitute but I'm not certain right now I need to. Last tourer I had with a triple was a 32/30 for the low so this is a bit of a drop but I anticipate bigger climbs while carrying less weight.
Also not much of a groupset.
RS405 hydraulic sti levers
4700 rear der
GRX front der
XT 10sp casette
XT 10 sp chain
Sram XO carbon crank- was the only one I could find with the gearing I wanted and at 150.00 each they were worth the cost.
Chris King BB
XT hubset
So not much of a groupset but all bought for budget, XT cassette was 15.00 less then the tiagra and saved 80g. XT hubs are a favorite and were clearance for 60.00 a set. XT chains were 15.00 each.
4700 rear der
GRX front der
XT 10sp casette
XT 10 sp chain
Chris King BB
XT hubset
1. 1x drivetrains (personally not attracted to, because of the very large steps, but 1x are becoming more affordable and, from what I read, the new standard for MTB.) For instance, I read yesterday that 12-speed chains were of a much better quality than 10 and even 11 (twice as many kms before "stretching" more than 0.5%), which raises the spectre of future improvements focusing mostly on this standard. And if considering a 1x, is there any reason to prefer a derailleur system (Shimano or SRAM) vs a Rohloff? Anyone knows if it is possible to customise a 12-speed cassette (ex: instead of 10,12,14,16,18,21,24,28,32,36,42,50 -> 14,15,16,17,18,21,24,28,32,36,42,50)
Also, even if you could do a 14-15-16 etc cassette, wouldnt the smaller chainrings of a 1x or 2x end up with a really small top gear?
anyway, just thinking out loud here.
Quoted: 2594 Post(s)
Liked 1,922 Times
Rene Herse Double Crank – Rene Herse Cycles
But as cheap as I am, I'll probably just stick with a triple.
Bikes: Custom built LHT & Troll
Quoted: 837 Post(s)
Liked 149 Times
isnt it necessary to be able to find the special first cog that takes the lockring into it? I mean, could this be a real technical block for trying to start a cassette with a 13 or 14 when it is designed for the lockring to only work on a 10t?
Liked 1,452 Times
I used a saber saw to cut off the teeth. Used one or two blades that were pretty much destroyed because the aluminum clogged up the teeth of the blade(s). This was about six or seven years ago so do not recall details too much. After the saber sawing, put the bashguard on the crank and turned the crank by hand for maybe 10 or 15 minutes while holding the file on it to file it down smooth. Turning a crank for 10 or 15 minutes is pretty boring, but it would have taken much longer to figure out a different way to smooth it down. Do that BEFORE putting a chain on it, the chain has some lube and the little bits of metal that the file cut off would stick to the chain (don't ask).
Liked 1,452 Times
Found one more good reason to get a 3X system instead of a 2X or 1X.
While out for an exercise ride today, broke a rear shift cable. First time I have broken a shift cable in decades.
Turned one of the limit screws on the rear derailleur to put the chain on the third smallest sprocket instead of the smallest sprocket. And pedaled home on my three speed bike.
A three speed beats a two speed and that beats a single speed bike in my opinion, but had to walk up one hill.
ADDENDUM ADDED NEXT DAY:
I thought that I had only installed stainless cables, but inspecting the broken cable, it appears to be galvanized.
On a different bike I replaced a bar end shifter cable that had several broken strands about 9 years ago, that also appeared to be galvanized. It had not yet failed but was getting close.
At home looking at my spare cables, I had several galvanized cables that were not labeled as galvanized, but they sure looked nice and shiny and were a more expensive cable labeled "slick". I could only tell they were galvanized from the part numbers on the packaging and checking the manufacturer catalog. From these two experiences, I think that bar end shifters where your sweaty hands are close to the cable, you should make sure you only use stainless cables.
Just to muddy the waters, have you considered a Pinion geared bottom bracket? It gives a 600%+ range and 18 separate, unduplicated gears. Then you can also get involved in a lot of arm waving about the strength of an undished rear wheel, maintenance, and the vulnerability of RDs to getting snagged.
Likes For Pratt:
Liked 1,452 Times
But in my opinion the small choice of frames that are specific to the pinion system is a deterrent. Compare that to a Rohloff that can be used on almost any bike if you use a suitable means of dealing with the hub torque. (That said, my Rohloff bike frame was designed specifically to be used with the Rohloff and not a derailleur.)
One advantage I see to a Rohloff over a Pinion is that I use a 44T chainring when riding around near home, there my bike never has more than a pannier of groceries and my gym bag. But when I take that bike on a bike tour, I remove 4 links and change the chainring to 36T for lower gearing for heavy loads on steep hills. Changing the gearing like that on a Pinion bike would be more troublesome.
And of cour$e, we are excluding the i$$ue of co$t$ in thi$ di$cu$$ion.
Liked 4,198 Times
As well as ignoring the 800 lb...um... “gorilla” in the room.
Stuart Black
Stuart Black
Frame choice isa good point. I doubt if Pinion would even sell to an independent frame builder.
One thing I forgot to mention, I find I shift much more often with Pinion set up than I do on my derailleur bike.
I'm curious, why? I certainly remember noticing this big time when I first got trigger shifter and sti shifters after dt shifters, but dt really have a noticeable "will I take the time to reach down again for the millionth time to shift" thing going on.
Liked 1,452 Times
I shift my Rohloff bike a bit more than a derailleur bike, I suspect that Pinion and Rohloff would be about the same for shifting. I mostly notice it when stopping at a red light. I stop, if on my Rohloff I down shift to 7 or 8, derailleur bike I obviously do not shift while stopped and start out in too high a gear. Rohloff bike, when I start I pedal about three or four crank revolutions, upshift, pedal about four or five crank revolutions, up shift again, and a bit further will likely upshift one more time.
An off the wall question for you, do pinion bikes only come as belt or is a chain system available to? Just curious. When I tour on my Rohloff bike, I carry a few spare chain links, but not a full chain. I met a couple in Iceland where both had Rohloffs, one had a belt and one a chain. They said they carried a spare belt because you could not buy one in the entire country. But a chain, no big deal.
Liked 1,452 Times
Quite often I do not shift while slowing for a stop at a red light because I was braking with both hands. Thus, no shift on a derailleur bike. Rohloff, that can be shifted after I stopped.
For me, a rear derailleur shift takes a bit of time when going slow, you have to keep pedaling but at a much lower torque level while you wait for the chain to wrap half way around the cassette to complete the shift. Yeah, that is less than a second, but it is noticeable.
And derailleur bike, front shift, same as rear in that you have to wait for the crank to go a half revolution before you can pedal hard again. I often pedal half a revolution before my chain has started to catch on the other chainring.
Sometimes I just say, I think I will stay in this gear a bit longer instead.
I shift my Rohloff by slowing my pedaling for just a tiny fraction of a second. Some people keep pedaling, but you have to reduce torque when you shift. On an uphill there have been a few times where I tried to shift my Rohloff just as my crank is at that point in the pedal stroke where your torque is lowest,but that takes some mind and hand coordination with feet, which is not always successful.
And of course it has a sequential shifter, you do not have to think about coordinating two shifters.
Liked 4,198 Times
If you are talking about the bike in post 9, the rear rack is Tubus Cargo. I’m not sure whether it’s an Classic or Evo. The front rack is a Tubus Tara.
Stuart Black
Stuart Black
