Saddle Fittment
Fricklefrack
Saddle Fittment
I have my saddle height and angle set. What im trying to figure out is how to measure a saddle to fit my boney butt. How do I figure the right width of a saddle to fit my butt correctly?
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
Go to a Specialized dealer and use their body geometry sit bone measurer thingy.
Or a piece of tinfoil on a carpeted stair works pretty well.
Fixie Infamous
Quoted: 54 Post(s)
Place the tinfoil on one of the steps, sit down on it, lift your feet and rock back and forth a little. Try and find the center of each divot made by your sitbones, and measure the length between the two. Use the narrowest seat you can, while still being wider than that measurement. Make sure not to wear jeans, or something thick.
So if you measure 125mm, use a 133, if you measure a 136, use a 143, etc.
You could also find a dealer that does the fizik test saddle program. At first I thought the spine concept thing was extremely stupid but to my surprise it's actually pretty acurate, for me at least. Found out i'm a chameleon and haven't thought about changing my Antares VS since.
Fresh Garbage
Riding posture also matters. Generally, if you sit more upright as you would on a touring bike you will want something wider vs. a narrower saddle with a forward racey posture.
Fixie Infamous
Quoted: 54 Post(s)
This is true. I prefer a 133 on my track bike, my usual road 143 just wasn't feeling quite right. Same saddles btw, just different sizes. And the 143 is a goddam sofa on the road.
Fricklefrack
I guess i would be in more of a mountain bike posture when riding. I tried the foil trick and if im measuring right im seeing around 140mm.
Winfried
Touring
25
08-14-14 02:52 PM
wstandis
23
04-29-10 09:01 PM
