34t cassette and a medium cage road RD??
Quoted: 453 Post(s)
Liked 112 Times
Wondering if anyone has run a 34t with a Shimano 5701 road RD? I know it "says" 32t max but can I make it work??
TThanks!!
TThanks!!
Quoted: 1935 Post(s)
Liked 2,148 Times
I have not run that combination, but I have run 2 teeth over on multiple Shimano RD’s without any issues.
John
John
Likes For sch:
LR÷P=HR
Quoted: 848 Post(s)
Liked 1,161 Times
SS = Max Cog=30T Max Capacity=34T
GS (when used on a Front Triple)= Max Cog=30T Max Capacity=40T
GS (when used on a Front Double)= Max Cog=32T Max Capacity=40T
So assuming you're running the GS version on a Front Double, the published Cog limit is 32T
Where are you currently regarding the 40T capacity?
Are you also looking to push Max Capacity over the limit also?
Barry
Quoted: 453 Post(s)
Liked 112 Times
I installed a 5701 with a 34t large on the cassette and it works great!
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 173 Post(s)
Liked 143 Times
Most likely fine
I am two teeth over spec. (36 vs. 34) on a 9 speed Sora RD, and it is fine. Shifts beautifully. I think I could go even more over spec. If I wanted, as the B screw is not close to limit. YMMV.
