Ideas for a great, unforgettable, no worry bike locks.
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
We all hate bike locks. They're heavy. You need a way to carry them, you need to remember your keys, etc. What are some ideas for better bike locks that don't exist yet.
Obviously cables suck, so anything involving a cable as the main lock is useless. Chains and U locks are much more durable.
This may be an eyesore, but I was thinking of a retractable chain attached to the water bottle cage bosses. Obviously the bolts would be hidden and security bitted. The chain doesn't have to go around the bike anywhere, since it's already securely attached to the bike. Basically reach out with the chain, wrap it around something and lock it to itself. For more security wrap it around something and your rear wheel, then lock it to the bike or itself.
Would it be more annoying to use than a normal U lock? You wouldn't need to carry anything, so that'd be nice.. However, I think the entire device would have to be heavy, as to protect against attack on the retractable mechanism itself. Actually, not really. Think of it this way. The two bolts that go into the frame in the water bottle bosses go through a relatively thick, bent piece of steel. The chain is threaded through that piece of steel before the bolts are put in so that it's trapped. The retractable mechanism can come after that and doesn't have to be secure at all, since it doesn't matter if it's destroyed, the chain is still attached to the bike. Any attempt to remove the chain from the bike would likely result in destroying the bike. (Chains are usually stronger than the water bottle bosses/aluminum/carbon frames.)
Obviously won't protect against bolt cutters, but neither will almost any lock.
I don't know how well it'd work. I'm in an inventive mood today. Please excuse my ramblings.
Bikes: '09 Felt F55, '84 Masi Cran Criterium, (2)'86 Schwinn Pelotons, '86 Look Equippe Hinault, '09 Globe Live 3 (dogtaxi), '94 Greg Lemond, '99 GT Pulse Kinesis
Quoted: 389 Post(s)
Liked 270 Times
I'm a pretty big fan of the Dutch-made Axa locks. I've got an older, all-steel one on my Opafiets, and a newer one with a plastic shell and a cable lock.
The key remains in the frame-mounted lock while the bike is rolling, and the rear wheel will not turn unless the key is in it; like a car's ignition.
Fortunately my Globe Live 3 & Live 2 came with the bosses to mount the lock (which are hidden/protected by the lock's shells), and I was able to order them from the NL.
I don't have any pictures of the lock with the cable inserted, but it works great for locking two bikes to any bike rack. I wouldn't leave it overnight, and without the cable, anyone can still grab the bike and throw it in the back of a pickup, but it won't roll, so I employ it whenever running into the supermarket or restaurant.
Here's a Googled image of the cable I have for mine. It's long enough to loop through the frame & wheel, but they have other lengths and chains available too:
Nothing is foolproof, but I've been pretty happy with it so far. Of course it also helps that these Globe bikes are very rare, so hiding or selling them anywhere without getting caught is going to be difficult.
Quoted: 389 Post(s)
Liked 270 Times
And here's what the old 80's Opafiets looks like with the Axa frame lock. This older one doesn't have the cable, but the bike is easily over 50 pounds (I suspect the frame tubes are not tubes at all, but actually solid steel rods), so no one's strutting quickly away with that thing.
Quoted: 389 Post(s)
Liked 270 Times
If you Google Axa frame locks and look them up on Youtube, they can probably demonstrate more easily than I can describe it.
Steel Boxes that the bike Goes into and you secure with a Heavy Padlock ..
[I have an Axa Ringlock and a 1,4M chain, that is long enough to go around my front wheel and the Bike Rack I lock up-to.]
You Ride with the key in and take it out to lock Up , so Dont Lose the Key ..
Quoted: 4560 Post(s)
Liked 2,804 Times
For the past several weeks I've used a fairly stout cable long enough to wind through both wheels, the frame and around a utility pole, along with a heavy disc padlock of the type used on storage building doors - very short shackle.
It's probably as secure as any single system, but takes too long to use. I don't mind when I'm by myself, but a few times when I'm riding with a friend who uses a much simpler, quicker security rig, I'm aware of how cumbersome my cable and padlock are.
So I'm considering something similar to the Axa system pictured above for the front and rear. It'll add a little weight but my Globe Carmel is already around 30+ lbs, and I use it a lot for groceries and errands, so a little more weight for a quicker lock won't matter.
That Globe Live with the belt drive looks nearly perfect as a utility bike, although I'd prefer the sloping top tube to make it easier to hoist my leg over on days when my hips and back are aching.
Incidentally, after accompanying my mom on several hospital visits the past year I've noticed several really crappy bikes locked in racks or on trees and utility poles... but one in particular had as good a compromise as I've seen between security and utility: It was a typical compact frame bike that looked like hell but actually had decent components and tires (mismatched but good quality all terrain Continental tires). Looked like something nobody would bother to steal, but was probably a good transportation bike. If I had to use my Globe Carmel for daily transportation to that area I'd probably ugly it up a bit to make it look like a cheap pawn shop bike, while retaining the stuff that makes it a pleasure to ride.
Quoted: 389 Post(s)
Liked 270 Times
The Globe does have a compact frame--any more compact and you're entering mixte territory, but good luck finding one; Globe made great bikes, so Specialized bought them and promptly discontinue the great models like the Live series.
and once tightly securing the lock to the frame the head of the screw that tightens the band around the frame (made of Zn it seems)
is made to break off locking the lock to the frame . *[ it wraps the band around a post some what like what you use to wind up the
top of a can of Kippered Herring or sardines..]
frames which plan on installing them have a braze on or riv-nut to screw into ..
placed ahead of the seat stays it seems the ring lock even if gotten loose, is still going to not let the wheel come out,
because of the ring lock's width.
These guys claim that the AXA can be opened with a blank key. I cannot vouch for truthfulness.
Open an AXA bike lock with a blank key (Doh) | Hackaday
EDIT: Looks like AXA may have fixed the problem subsequently. Pitchforks may be safely stowed.
Liked 2,804 Times
Yeah, Globe offered some sensible utilitarian bikes at very reasonable prices. Seems like several manufacturers went through that phase in the mid-2000s, including some fairly innovative twists like the comfy cruisers using the Shimano Coasting system auto shifters. But that phase didn't seem to last and now it's pretty much just Electra's market with the Townies, at least among the better made bikes that are mass produced and reasonably priced. Everything else is road bikes, hybrids and mountain bikes. The handful of manufacturers still making good quality utility bikes are extremely expensive low production or custom jobs.
The most common hassle I encounter with my 7' cable and lock is getting it around a fat utility pole, through both wheels and, in some cases, the saddle too (silly quick release seat post). None of my neighborhood stores has a bike rack, which pretty much leaves metal light posts with those concrete pads, and the cable won't quite reach around everything. The Carmel has a tall handlebar stem so I may wrap a second cable and lock around it just for the front wheel.
A crappy bike can be its own best theft-deterrent.
Bikes: Cervelo Prodigy
Quoted: 479 Post(s)
Liked 88 Times
How about something else? What if your group of riders find a home or business location that is practically next to that coffee shop or lunch place and it is advertised as a type of AIRBNB? A bike thief would have to break and enter a building with someone in it. Just buy your coffee and food next door and bring it into the building.
Formerly Known as Newbie
They're not crazy-light--between a pound to a pound-and-a-half, and you don't have to have the forward-facing seatstay mounting bosses like my Globes have (sorry, don't have a photo.) The Axa locks also come with steel band mounts which can be tightened around the seatstays, and that is then hidden beneath the plastic lock body. The bosses are more secure and cleaner looking IMO.
--J
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
Quoted: 1572 Post(s)
Liked 644 Times
Today is Thanksgiving.
One of the things that I'm most thankful for is that I have so little to contribute to bicycle lock threads. I have all but zero experience and all but zero need. My life is good.
Advocatus Diaboli
Quoted: 4760 Post(s)
Liked 1,542 Times
Juggy_Gales
General Cycling Discussion
47
01-22-18 03:12 PM
jaslynn
15
02-08-12 04:36 AM
