Dented Seat Stay (Aluminum)
#51
Quoted: 10250 Post(s)
Liked 5,211 Times
Bike shop deems it safe to ride. Looks like i’ll ride it until I can afford to replace it. Not really happy about it but this whole situation just sucks.
#52
Quoted: 4539 Post(s)
Liked 1,676 Times
Requested touch up paint, not sure how that is going to work out. The frame is grey but the paint is called Dnester black. Trek has about 4 shades of black and 3 shades of grey for touch up paint. Have not gotten a clear answer on if that can be repaired. Filler and paint? Manager comes back today so hopefully I can get some answers.
If you want to make it look nice without spending a lot of money, fill it with epoxy putty, then apply touch up paint, let dry, sand, reapply, let dry, sand, polish.
It really depends whether you have the skill and patience to try this or if you don't have that sort of inclination.
#53
Liked 5,211 Times
Bike shops don't do body work. They will apply some touch up paint for you, but nothing special.
#54
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1300 Post(s)
Liked 742 Times
Leave the paint alone or suffer tyour mistake..
Metallic paint is VERY DIFFICULT, if not Impossible, to blend into existing paint .
that's why auto body shops paint entire fenders, entire doors,or entire quarter panels.
good luck...
i'd leave it as it is.
good luck...
#56
Liked 5,211 Times
how bout if I just use some nail polish to fill in the chips?
#57
Quoted: 5885 Post(s)
Liked 2,728 Times
Now you have it. Use the closest color match and just dab it on the bare metal to camouflage the damage and put it out of your mind.
FWIW - I stopped fretting over damage like this 50 years ago, when I realized that it was impossible to enjoy riding if I worried about the bike. These days, I look at dings on my bikes the same way as those on my body. They're not scars, they're memories.
FB
Chain-L site
FB
Chain-L site
#58
Quoted: 3576 Post(s)
Liked 2,997 Times
The frame color is so dark that even if you didn’t match it exactly, you probably wouldn’t be able to tell from two feet away. Get some Testors model paint colors from Michael’s and let your wife have a go at mixing.
#59
Quoted: 993 Post(s)
Liked 1,659 Times
Bike Shop.... Ha...
Put away the crying towel. Take the dam thing apart. Replace whats bent and broken. Check your frame alignment. Bondo that dent and cover it with reflective tape. And get to ridding...
Of course... You know this and have probably already started... Fun, Fun, FUN...
#60
Liked 5,211 Times
I do appreciate the responses and the advice. I guess as much as I was looking for answers I was also wanting to vent. Rode it 62 miles today. Handled great. The chips honestly don’t look that bad, and the dent is what it is. Mechanic straightened the chain ring (i think). It’s not as bent as I remember it, but I am going to replace it. Sounds weird in some gears, and I would imagine it would cause the chain to wear as well.
#61
Liked 2,728 Times
However, if the ring is bent enough that the chain rubs the FD cage more than very occasionally, it will cause FD cage wear. Also, warped chainrings make it harder to adjust FD trim, so while replacement probably isn't necessary, it may be desirable.
That said, try to move past the notion of keeping everything perfect. Over time, well used bikes accumulate all kinds of minor damage. That's part of riding, and worrying about it will keep you from fully enjoying the ride.
#62
Liked 5,211 Times
The chain won't suffer because of the bent chainring. So no worries there.
It’s not about me trying to keep everything perfect. I have 4 other bikes. This isn’t my first bike or first crash. What upset me was that it was less than 5 days old. I think I do have a right to be upset about that. What’s done is done, just happy to have it back.
#63
Liked 742 Times
go for it.
what i do at times is find a rattle can of a similar color/tone/finish, then shoot some into a can cap and dab it on with a flat toothpick, q-tip, or small artist paint brush... i've also clipped the end off of a round toothpick and used that.
Large auto parts stores sometimes have a wide range of touch-up paints too.
not surprisingly, sometimes the big cans of paint cost less than the touch up bottles.
if you have a workstand, set the seat tube/line of chips at a horizontal, top position to limit sagging of the touch-up paint.
#64
Liked 2,728 Times
I was trying to give you a basis for a decision about the chainring. Specifically pointing out how to decide whether it was bad enough to replace for mechanical considerations, ie. rubbing or trimming, or purely from choice.
#65
Liked 5,211 Times
Sorry if my post wasn't clear. I wasn't challenging your legitimate beef.
Only other issue. The barrallel adjuster was knocked out of the RD. It was to the side of RD when I got home after the crash. When I touched it, the tension on the cable snapped it back to where the threads are, but it doesn’t appear to be attached anymore. I tried to screw if in but appears broken. Cable tension is the only thing holding it in place. At the moment it’s shifting fine, so not really an a big deal. Don’t know if this will lead to problems down the road.
#66
Liked 2,728 Times
....Only other issue. The barrel adjuster was knocked out of the RD. ...but it doesn’t appear to be attached anymore. I tried to screw if in but appears broken. Cable tension is the only thing holding it in place. At the moment it’s shifting fine, so not really an a big deal Don’t know if this will lead to problems down the road.
OK to put off replacing it, but start looking for a replacement. Maybe let your mechanic know to save you one from a crashed bike.
When comes to replace, you can possibly turn it out by the section showing below the arm (do not Mar the threads by squeezing hard with pliers), or tapping a small jewelers screwdriver into it to get a bite on the ID and backing out.
Having the replacement in hand in advance means no lost time later.
FB
Chain-L site
FB
Chain-L site
#67
Quoted: 2544 Post(s)
Liked 3,024 Times
It’s relatively flat where I live. 60 mile ride equals about 2000 feet of elevation. The gears that I am most commonly in, I didn’t notice any rubbing. In the event of a hill, and using larger gears rubbing took place. Rubbing doesn’t bother me as much as the noise the chain was making. Shop has a 52T chain ring in stock so I’ll just swap it.
#68
Liked 5,211 Times
Won't lead to problems, but may cause inconvenience if/when the RD wants the trim fine tuned.
#69
Liked 2,728 Times
I'm a cheapskate and wouldn't replace a good RD over a broken adjuster, but that's just me.
If you do replace the RD save yours in case a friend ever needs a cage or other small part.
Since you have time, getting the RD is only a matter of a few $$$ postage.
BTW I didn't follow the entire thread. Sounds like you must have gone down, so how did you come out of it?
FB
Chain-L site
FB
Chain-L site
#70
Liked 5,211 Times
Hit my head pretty good. Cracked my helmet. Pretty decent gouge in my arm. Other than that I was fine. Didn’t have concussion symptoms. Felt like I was hit by a truck the second and third day. Back to normal now.
#71
Clark W. Griswold
Quoted: 4437 Post(s)
Liked 4,089 Times
I don't get involved with insurance but it would probably be on the other person since you are claiming they caused the damage. I am simply talking about getting a potential new frame under crash replacement. Do not take any of what I say for legal or insurance advice.
#72
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
This is one reason I prefer to ride alone.
#73
Quoted: 682 Post(s)
Liked 455 Times
Fortunately clowns like this are rare and riding in groups with people you know is very safe and usually more fun than soloing. You get to know their typical reactions to things and body language etc so can predict what they're going to do.
People just randomly joining a group are rare. Doing it without asking is unheard of around here. Someone doing it and then plowing into the other riders is like something from Jackass.
Likes For choddo:
#74
Liked 5,211 Times
From what I am hearing he races Cat 1 which is even more depressing. I would hope someone at that level would have better handling skills as well as better judgement.
