Road Rash Tattooing?
Hi all!
Two years ago I had an accident that left me with a hyperpigmented scar right under my eye.
I've seen this is a common event, but the wound was not cleaned properly (the nurse believed it was dried blood/ bits of skin) and actually tiny bits of asphalt healed underneath the skin. A few sources online say it's a phenomenon called road rash tattooing.
I tried some heavy chemical peels as that's what a doctor recommended, but not much success (at all really - the hyperpigmantation lightened up a bit but did nothing as to help eliminate those asphalt bits).
Now I am in a place where I can afford laser - but I don't know if it's going to waste my income as the chemical peels did.
I really want to get rid of it as it's right on my face, I would like your advice.
Has anyone been through this "roadrash tattooing" ?
Thank you!
Thank you!
Liked 2,966 Times
I don't have it on the face, however, I can relate.
IMO, seeing a dermatologist/osteopathic doctor for their recommendation might be best in finding a possible treatment.
I've tried some topical creams recommended by a general doctor without success. After visiting a specialist, it was determined that if time/diet change was not beneficial, then the damage would be likely permanent.
-Oh Hey!
-Oh Hey!
With a mighty wind
Quoted: 1086 Post(s)
Liked 859 Times
Tattoo the scar. Maybe a spider web and teardrop.
Has the doc injected steroids into it yet? Seems to work well for keloids. As for the remaining grit, talk to a plastic surgeon but the scarring for removal might be greater than what you're dealing with.
Quoted: 174 Post(s)
Liked 177 Times
Hi all!
Thank you!
Thank you!
Did it get infected before it closed up?
Sr Member on Sr bikes
The PRP suggested above could very possibly aide is scar healing. But I'm not so sure that it would remove the hyperpigmentation if it is caused dy asphalt chunks, or dried blood. I had PRP for a torn meniscus. The blood withdraw isn't so bad...they took it from my arm. I was concerned about the big needle the doc had to use to re-introduce the PRP into my knee. But, he used a local anesthesia that work really well. I couldn't even feel it. So...if they can use this process in your case...I can't say how the re-introduction on your face would be.
Dan
Dan
Bikes: 2014 Cannondale Supersix EVO 3, 2015 Trek 520, 2017 Bike Friday Pocket Rocket, 2022 Moots Vamoots Disc RSL
Quoted: 285 Post(s)
Liked 267 Times
This exact same thing happened to me just under my right eye. It’s about the size of a quarter, but mine is grey. I immediately saw a plastic surgeon, who explained that it was a tattoo. He told me to come back in three months to see how it developed. We didn’t discuss what he would do at that time. Three months would have been January. As it turns out, I plan to see him this coming January/ February.
As to the PRP suggestion, the last I heard about PRP was that a number of doctors that were using PRP have stopped using it. It doesn’t seem to work consistently enough to keep using it. I know that many doctors continue to use it. I guess the jury is still out on that.
Quoted: 451 Post(s)
Liked 364 Times
I used to do this sort of lasering for a living. I recommend you find the name of the most respected laser person within striking distance of where you live and go talk to them. It's possible they might do a small test area to see how you respond. There's a bunch that goes into this, so you want the best person you can locate. Good luck!
Liked 2,966 Times
-Oh Hey!
-Oh Hey!
Quoted: 741 Post(s)
Liked 818 Times
I did a faceplant on pavement several years ago, concussion, facial lacerations, one, a 1/4" from my eye socket, requiring several stitches. chipped a tooth veneer, broken arm and compound wrist fracture. I now have a souvenir plate and screws in my arm, and a cool road tattoo, a black line about an inch long, high on my cheek bone. Depending on lighting, sometimes it doesn't even show, at other times, I kind if enjoy the street cred. The arm is fixed, fixed the dental problem, but I'm leaving the road tattoo alone.
