ESI extra chunky grips less shock/vibration absorbing than expected
Anyone else find the same? Could fit ond of those thicker and softer ESI grips but then they will interfere with shifter levers. Extra chunky barely clears them.
Couldn't find any bad reviews in terms of shock/vibration absorption, so decided to give it a go.
Hands still get tired pretty fast on a recently upgraded 50° back sweep handlebars with them. Seems like only shoulders doesn't hurt anymore compared to flat bars, but palms still get as much painful as with ergo style grips.
Probably will keep the 40c front tyre inflated to 2 bars instead of 2.5 bars, but that might lead to snake bites since the whole system weight is 120-130 kg.
Clark W. Griswold
Quoted: 4361 Post(s)
Liked 4,002 Times
I like the ESI grips I use them for the "bar ends" of my Koga Denham and Velo Orange Crazy Bars. For the actual swept back. bars I use Ergon GC1s and Ergons would be the only grips I use for just about anything aside from those "bar ends".
For me 50˚ bars are way too swept back for me and caused hand pain right away. Generally for me 35˚ is the max I want to go and if no GC1s no thank you!
I have a feeling maybe your bars are a bit too swept back especially all at once. I would start with something a little less and try that first.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
How about a picture?
How are the bars angled relative to the horizontal plane?
How do you place your hands on them? Which part or parts of the hand are bearing the upward reaction force of the top of the bar?
What is the relative height of the saddle and bar where you grip?
How much weight is borne on your hands and how much is on the saddle or shifted to the pedals by your pedal work?
Otto
Otto
Quoted: 1218 Post(s)
Liked 298 Times
On the same note, ive been riding super chunky rough stuff. Over time my wrist have hurt way less, but I definitely don't use my bars as a shelf support anymore!
Sometimes core strength, wrist strength, abdominal muscle strength, lower back strength, will be far superior than any crutch you can use as a grip. Thats for wrist pain. As for vibration dampening, most of it is in tires and tire pressure, tires are not equal! some seem to quite chatter, others amplify the chatter.
Then there are some bike frames (or forks) that tires and grips, and physical strength can't fix! They just suck....
Likes For Metieval:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
You might want to check out post #7 in this thread:
https://www.bikeforums.net/road-cycl...umb-hands.html
It describes how to optimally place your hands to put the weight on parts of the hands that can bear it best. It is focused on drop bars. I have used this as a guide in adjusting how I ride my swept back bars.
There are several illustrations showing the part of the palm that should bear weight and diagrams showing all the nerves in the center of the palm, which is the area that must not bear weight.
I have ridden many, many thousands of miles on 74 degree sweep classic touring bars (much of it single speed) with virtually no hand discomfort throughout that time. I’ve used ordinary Oury grips and either foam tape or cheap bar foam for the more forward sections of the bar.
For a 74 degree sweep, I find tilting the ends down about 10-11 degrees strikes a nice comfort compromise between the seated and standing riding positions. It may be different for 50 degree sweep so you will need to experiment.
With 74 degree sweep, it is also possible to use the grips with the thumb aligned on top of the bar and bearing weight on the pad of the thumb. That area can also bear weight, but avoid using a grip that places weight between thumb and forefinger. Many nerves there.
Actually, I think when I put thumbs aligned on the bars the weight is still mainly on the outer palm region. That just avoids any chance of putting weight between thumb and forefinger.
Otto
Otto
Quoted: 7653 Post(s)
Liked 3,482 Times
I have heard that excessively soft grips cause "pump," that is, your hands continually, tire loosen and re-tighten as you unconsciously seek a firm grip but cannot ever fully achieve it because of the padding. I assume that you will try some of the other excellent advice offered hear .... also consider hand exercises if there is some specific and personal situation where your hands just need a boost.
Hope you enjoy your rides and your life more each time.
Likes For Maelochs:
Otto
Otto
On my mtb I run Esi extra chunky, for pavement flat bar bikes I like the ergon gp grips. I actually liked them on the mtb too for comfort. I just felt like I didn't have as much freedom to throw the bike around on single track with the Ergon GP style grips on the mtb.
Liked 298 Times
Previously used Schwalbe Supreme 37c, now using Continental Contact Urban with supposedly slightly lower rolling resistance and slightly better wet grip. Foldable Supremes seem to be thinner than Contact Urban so that might explain the difference in vibration damping. Wired Contact Urban seem to have softer thicker type of rubber.
Play with your air pressure, the window is much larger than most people think. the High pressure is better myth was a huge mental hurdle for me to get over. We don't ride on a velodrome, we ride in the real world. If you go to low you risk pinch flat, if your tubed, burping if you're tubless. Too low can feel draggy on pavement. Just play with it, and you might be surprised arms the difference it makes.
I have found in my experience that removing the chatter, = faster ride.
Of course in the middle of that is the perceived feel while riding. Which isn't always an accurate representation. I don't care how slow I am as long as I feel fast though. Haha 😄
Quoted: 6198 Post(s)
Liked 4,814 Times
Padding won't do anything if you ride with bent wrists. And it won't give you much more time if any on the bike for bad hand placement that puts you resting on the back half of your palms.
Liked 3,482 Times
I never even think of changing grips on my flat-bar bikes (I might someday try those oversized Ergons,but .... meh.) As @wheelreason and @Iride01, note, comfort on a flat-bar (swept-bar, H-bar, or Jones bar, or Trekker bar, or for that matter drop-bar) is all about hand placement and weight placement. Arm angles, wrist angles, weight distribution, hand placement on the bar ..... I don't care what the next guy does, i will saw off my bar, get a longer or shorter stem, a straighter or more swept bar, and I will play close attention to my physical positioning and weight placement. I have ridden some pretty long rides on flat bars with no hand discomfort, and I have had numbness within half-an-hour. After making sure the bike, including the bar, fit me, .... I was and have been able to do long rides on flat bars.
Likes For Maelochs:
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
The wolf tooth silicone grips are better since their material is slightly firmer. I find the ESI Extra Chunky (and all their foam grips) pack down under pressure too easily.
Finally found vintage style finger pattern grips on amazon, but now they are made with comb like texture on the other side which might become uncomfortable after a while.
Seems like smooth and glossy texture might reduce skin soreness according to experience with the original finger pattern grips.
Decided to go for barrel shaped grips since motorcycle riders consider those comfortable.
There are also Thorn anatomically shaped cork barrel grips and some other cork grips but texture of those might be too rought compared to glossy rubber, since even ESI grips feel too abrasive.
I think the right shape is more important since it encourages you to not hold the the grips too tight.
The only barrel shaped grips I found on Amazon where from Topcabin and those turned out to be too short.
Not sure if 22mm motorcycle grips can be used since on 22.2mm bicycle handlebars. Throttle side is 25 mm so those are out of the question.
I think I can't use ergon style grips nor regular round grips after recent hook of hamate trauma which happened 14 months ago.
Edit.
I think these ones which have the smallest deameter outer size around the edge of the palm even compared to more expensive one might work better.
https://www.amazon.com/VELO-Kork-Lenkergriffe/dp/B07NZZMN8M
Edit.
I used either ODI Rogues or a Specialized ergo grips. Never used a 50° sweep bar. My last bar was only 9° sweep.
Otto
Otto
https://www.amazon.com/VELO-Kork-Len...dp/B07NZZMN8M#
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Is this shape any good for hook of hamate pain/sensitivity due to trauma which happened 14 months ago?
The grips you link look to be nearly cylindrical and I would tend to think not much different from ones with straighter side profile. If you aren’t under treatment and concerned with re-injury, I guess there is no harm in giving them a try. I like soft foam grips on my bars.
Otto
That’s not something I’m familiar with, and I am neither a sports doctor nor physical therapist. If you are under treatment, you should consult such a person.
Otto
Otto
There wasn't any active treatment prescribed by doctors 14 months ago for FOOSH injury, but the hook of hamate area is still sensitive.
Otto
Otto
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
The pad over the thumb metacarpal can also take some weight without bearing on major nerves. In some positions, I have both of those regions bearing some weight.
Otto
I interpret the figure to suggest putting weight on the outer padded part of the palm which is mostly above the outer two metacarpals. But I don’t have hamate sensitivity, so you may need to do things differently if that is also affecting the hamate bone.
Otto
Otto
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
This suggests that I might need handlebars with 90° sweep such as drop, north road, roadster or bull horn to put the weight on thumb metacarpal. On the other hand usually putting too much weight directly on muscles such as Abductor pollicis Brevis usually feels more uncomfortable than on bones.
Could be. For whatever reason, I have no trouble bearing weight on those two larger muscles: abductor pollicis brevis (thumb) and abductor digiti minimi (pinky). I don’t want weight borne where bones aren’t padded by muscles or over main nerves.
Otto
Quoted: 4806 Post(s)
Liked 3,932 Times
