Proper tool for 3-notch headset ring?
Quoted: 3809 Post(s)
Liked 6,684 Times
Anyone have an idea of what the proper tool is to remove this three-notch lock ring from an early 80s Japanese headset? I could use lock-jaw pliers and some padding, of course, but wondered what shop tool would have been in use back in the day.
Untitled
Untitled
Maybe a bottom bracket lock ring wrench is what you need. This tool has an outer diamter of 46mm and 40mm at the ends of the teeth. If yours measures the same then it might work.
Park Tool HCW-5
https://www.parktool.com/product/cra...t-wrench-hcw-5
Park Tool HCW-5
Serviced an identical headset yesterday. I've seen these headsets several times (less than a bunch) and have never had one that didn't unscrew by hand with just a rag to protect my hand from the edges. Putting them together doesn't require much tightness of that nut because the of the indexing feature of the threaded top cup and the indexing washer it meshes with. If you do end up using pliers, you wouldn't have to squeeze very hard -- the nut probably won't be very tight -- an it should be easy to do without damaging anything.
Liked 6,684 Times
Oh, I got it off with a small plumber's wrench, so that wasn't a problem. I was more interested to know what tool was specifically designed for its removal. It's actually the second one I've had to deal with in a couple of weeks.
I saw references to the Hozan's wrench on various Google searches, so good to know it works. Seems I can order it via Amazon shipped from Japan.
Disraeli Gears
It's the rare thread that has Neal Lerner seeking wrenching advice. I feel like I've seen a comet. Even more exhilarating: I pretty much knew the answer, and have one of those lockring tools.
Quoted: 4803 Post(s)
Liked 3,924 Times
I'll bet the Pedros fix gear tool (the Trixie) would work. (It's spanner grabs fix gear lockrings far better than my lesser Park spanner and especially the 12t lockrings where the cog is not there as a shoulder. That headset lockring spanner notch looks a lot like the 12 tooth ones.)
It seems Pedros changed the plate stock of the Trixie to a thinner one. I have only the older ones which are very good tools. (I coveted the second one for years as it hung on a bikeshop display. Set up the Mooney fixed and finally had justification to "liberate" it. (The shop owner expressed surprise that a tool that good marked at $30 would sit there that many years. Was happy to see it go to a good home.)
Ben
Ben
Liked 6,684 Times
here is what i use
This one was ground down to use on BB adjustable cups lock rings as well. old VAR tool maybe(?)
Quoted: 4722 Post(s)
Liked 3,036 Times
Park had a headset spanner, HCW10, with one end designed for notched headset lockrings. There were also several inexpensive, spanner style, multi-tools with this feature. A company called KAL had a hinged, hook spanner that was supposed to work for both headset and BB lockrings but I found it tended to slip. As previously mentioned, you can also use lockring pliers, available from companies like Hozan and VAR.
Quoted: 443 Post(s)
Liked 27 Times
Liked 6,684 Times
Well, I ordered three different tools (I'm a sucker for new bike tools) and will report back on effectiveness.
Quoted: 7348 Post(s)
Liked 2,463 Times
There's nothing wrong with using those wrenches, of course, but when I don't have one nearby, I just use a big channel lock, and there's nothing wrong with that, either.
I have even been known to use a hammer and a flat bladed screwdriver to start the ring spinning in the right direction.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Quoted: 443 Post(s)
Liked 27 Times
I replace headsets that have wrench marks or chipped chrome.
Is my OCD showing?
Liked 3,036 Times
Pliers only work on lockrings with an even number of notches. For a 3-notch ring like this, you need a hook spanner. The Hozan lockring tool is a double-ended hook spanner; the large radius end fits bottom bracket lockrings, while the smaller radius end fits these headset lockrings.
With lots of filing, I made an insert for my Sugino fixed cup wrench out of large washer. Lay the nut on the washer and mark for the slots, and hacksaw beside the teeth. Then file away for clearance around the nut. File flats on the outside so washer fits in the fixed cup wrench.
