Rear V-brake not working properly
My rear V-brake isn't working properly, it feels loose and barely creates any friction when I pull on it. I tried adjusting the caliper and brake pad position but this didn't fix it. Here is a video showing the problem: https :// youtu.be/i9pf4nP9yjM (remove spaces)
Blamester
Look it up on youtube.
Likes For blamester:
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 669 Post(s)
Liked 725 Times
One of the caliper springs isn't working. It could be damaged, corroded, badly misadjusted, or missing. No way to tell from the video. I would start by removing the cable and getting the calipers to work freely. Then check the cable for corrosion and fraying, and if it's serviceable, adjust it correctly.
Likes For andrewclaus:
