One brake pad wearing noticeably faster
Hi all- I've been having problems with my front rim brakes being noisy- rubbing sounds, sometimes almost grating. I've lightly sanded the rim braking surface with 400 sandpaper. It helps for the first couple of stops, then it's back. Today I removed the front wheel and took a good look, half expecting to find something on the pads, but nothing. The pads were both smooth, evenly worn, and free of debris . The only off thing is the non-drive side is noticeably more worn than the drive side. Anyone have any idea why, and what to do about it? Its not been dragging. (I check regularly) The rim is not showing any real wear, and they are both aligned correctly. I realize this may be a simple thing, and I have done a search, but really couldn't find anything useful.
The bike is a 2014 Lapierre with a complete Tiagra Groupset -4600 I think, dual pivot rim brakes.
Thanks!
Thanks!
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
Thanks!
Thanks!
Sorry, I didn't do enough proofreading, . Should have said they each wore smoothly, but one was worn much more than the other. Yes, you center the brakes by pivoting the brake assembly. I did mention I checked that they were aligned. Probably an unclear term- align meaning centered. Checking the centering was one of the first things I did.
Thanks for taking the time
Likes For decosse:
Quoted: 194 Post(s)
Liked 204 Times
If the bike is six years old it might have been through a little or a lot, so being able to see the rim, calliper and pads might help us see something. When I was a mechanic the hardest jobs were always the squeaks the owner lacked the time to demonstrate
Likes For Geepig:
Quoted: 254 Post(s)
Liked 182 Times
If you watch the brakes while pulling the lever, does one side move a lot more than the other at first? Could be one of the pivots is stiff so one pad is contacting much sooner and you’re braking with one pad a lot.
Likes For AeroGut:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Pull the lever and watch the center of the tire. Is it being pushed a little to one side? If so there's your answer.
Likes For cxwrench:
Quoted: 4211 Post(s)
Liked 3,881 Times
Agree with the "centering" AFTER pad contact with the rim. Since the two caliper arms have differing leverage their arc of movement that the pads goes through are also different. The gap between rim and pad will be slightly different, side to side, when the lever is not being pulled. Andy
AndrewRStewart
AndrewRStewart
Do you have pictures?
AeroGut , cxwrench , thanks for the help!
Near as I can guess, the bike has at least 5000 miles on it. I have over 4000 recorded, but there were quite a few times I didn't bother or forgot the app-or it didn't work. There were also a couple of 6 month periods I didn't ride due to injuries.
Some Weirdo
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times
If you want improved braking and reduced noise (read: no scraping sounds), get pad holders/cartridges and use kool stop salmons inserts. Your rims will thank you.
Somewhere, a village is missing its idiot.
Likes For Ferrouscious:
Liked 3,881 Times
When the pads are centered, at the moment they contact the rim, there can be a soft whack sound sometimes. That is what I aim for.
When one pad contacts first the wheel has to warp over to the other pad a bit. This can make the feel at the lever mushier. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 194 Post(s)
Liked 204 Times
Well, you have certainly given those pads a workout!
I am interested in the glazing on the pads, as they maybe trying to handle more heat than they are capable of. When you cleaned up the rim, did you do the same for the pads? It is a very long time since I last deglazed any kind of pads, probably when I was karting in the 80s, but if you remove them, place a sheet of fine abrasive sheet on a flat surface and then carefully and lightly caress the pads across the sheet. If you have a nail file you might just take off a tiny bit of the edges, especially the leading edge.
Or just try a different type of pad.
Likes For Geepig:
Likes For cjenrick:
Quoted: 6198 Post(s)
Liked 4,814 Times
How long did these pads last you? If these are original pads on your six year old bike, then maybe not worry too much. Though if you do find an obvious issue, fix it.
But will the cost of new pads every six years be a budget buster?
Likes For Iride01:
Thank you all
