Hi Mod Carbon
Hi Mod Carbon
I have a Cannondale carbon frame mountain bike, I am considering upgrading to the Hi Modulus frame as it is lighter, stiffer and has better damping/shock absorption.
I know how much lighter it is, but I don't how much stiffer or how much more shock absorbing the Hi-Mod frame would be.
Does anyone know how much better a Hi-Mod frame would be than a standard carbon frame?
Thanks.
Thanks.
Quoted: 1218 Post(s)
Liked 298 Times
on a mtb no idea,
on a road bike the hi-mod is the only reason I went to a supersix, otherwise I would have stayed on Caad 10/12 etc.... That is for stiffness reasons.
I have no idea on vibration dampening between the frames. road surfaces vary so much and i run so many different tires. plus it is too easy to acclimatize to whatever you are riding.
If you have the money, buy the hi-mod
Bikes: Salsa Fargo Ti, Cannondale CAAD9, Carbonello Fixed Gear, Specialized Epic Disc
Quoted: 39 Post(s)
Liked 16 Times
The way Cannondale describes it is that there is no difference in ride qualities. They are designed to ride the same in all respects. The only difference is weight. I have never ridden hi-mod and regular back to back in the same configuration so I can't say for sure. YMMV
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
If true, I'm glad I have a plain jane Six, although it looks just like a SuperSix.
