Trek Marlin 7 too slow???
I just got my 2021 Trek Marlin 7 after ordering it back in March. My only issue is that I feel like it doesn’t have enough gears. I easily max out the gears on trails and want to go faster. On the street this happens almost instantly. Anyone else notice this? Any ideas what to do? Other than that the bikes great.
Expired Member
Quoted: 3678 Post(s)
Liked 5,442 Times
It's geared for more difficult trails than you are riding. Your shop can probably change the gearing for you if you are going to ride mostly flatter terrain.
Quoted: 6973 Post(s)
Liked 10,975 Times
Looks like it takes a 34t maximum chainring, unless you go to a triple crankset. It seems like you bought the wrong bike for your preferences.
Quoted: 823 Post(s)
Liked 1,961 Times
Specs indicate you have a 28T single crankset. This bike was not meant for speed on the road but to coast downhill on trails.
I have a 2014 Trek Marlin 6 with a triple 42/34/24 crankset and the fastest I have managed on road downhill is 40 mph.
Quoted: 1944 Post(s)
Liked 2,164 Times
Cheapest change is to go to a 34t 82mm bcd chainring, AlliExpress offers a 36t, and see if the gearing works.
Should be a pretty simple swap if it can be done without pulling the crank. You’ll need a longer chain.
If you like the bike, it’s not the wrong bike, just the wrong drivetrain. Worst case is swapping out the crank and going with a 38t or 40t.
John
John
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Ignore the haters.
Keep in mind that an mtb with a 1x drivetrain is usually going to be quite under geared for many pavement situations.
That said, a 28t ring seems on the small side to me for a cassette with a 46t cog in the back. Running that with a 32t or 34t ring is not unreasonable. Do you find you currently need the lowest gear on that bike?
Going from a 28t ring to a 34t ring will make a big difference. Keep in mind that you will almost certainly need a longer chain as well.
Liked 10,975 Times
I didn't notice that it's got a 28t chainring as stock. OP should have the shop put on a 34t chainring - max that will fit. That will give noticeably higher gearing, and won't cost much money.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 324 Times
Yup, that's the most useless road bike on the planet. LOL. Only slightly faster than a Vietnam SS. Slower than my SA 3 speed.
But a 34T will get you 90 GI, a fast granny bike. Close to my Nexus 7i IGH, at 38 to 92.5.
Likes For GamblerGORD53:
Quoted: 18424 Post(s)
Liked 15,582 Times
IKR. My Surly LHT has a middle ring of 36. If I’m traveling fully loaded I’ll often use that on unpaved, flat trails. On flat roads I’m usually in the 46 ring.
Likes For indyfabz:
Quoted: 6198 Post(s)
Liked 4,814 Times
Are the trails paved or well packed dirt or gravel. Probably the wrong bike.
If loose gravel, dirt or otherwise soft surface, then you must be a strong rider.
Quoted: 1088 Post(s)
Liked 1,026 Times
John
John
I would however go to a 34t. I run a 34t with 11-42 cassette and find my gearing perfectly fine for MTBing around me, I only went to a single ring because my bike is only used for MTBing. I'll ride it paved with my youngest kid but he's 6 and slow, my older two are 9 and 11, and it can't easily keep up with them on pavement nor can it do the paved or even gravel rail trail paths I like to do at a speed I would consider acceptable for more then short bursts without pedaling a ridiculous cadence for a more relaxing ride. But for those kinds of rides and speed I'd use a gravel bike, cross bike, or a flat bar equivalent as they're meant for being able to commute, exercise, and travel at a reasonable speed for reasonable effort in most places. Most MTBs are now really only designed for MTBing with the equipment they have and the gear range they come with.
I don’t have the bike knowledge that you guys have so it would make the most sense for me to just sell it and grab another bike. I called the bike shop about upgrading it and they pushed hard against it. Any recommendations for a decent quality bike around $800-900 that will have more gears? I like the large 29” also if there’s any someone could recommend. Thanks again.
Liked 4,814 Times
It's not necessarily more gears that you need need. You need to figure out what the lowest gear is on the current bike that you have to have for the conditions you are riding and then make sure that your next bike has at least that low a gearing and then a higher ratio gear than what your current bike has.
How many gears are between that is up to you.
You are in smallest rear cog during these times it's not going fast enough aren't you?
Liked 324 Times
Those kind of bikes just aren't made for all round riding. IMO, forget the steep trail option and get a road + gravel type bike.
For starters, NO road bike should have those crazy steep slope top tubes. I call them half frames. LOL. They're a ludicrous fad now. Zero all round capability.
1x is a really dumb fad now.
I never did like dirt, so I only have roadster IGH bikes. I ride all of them on 100+ mile day sightseeing rides. YMMV.
Liked 15,582 Times
Liked 10,975 Times
Likes For Koyote:
Liked 15,582 Times
I have nothing against 1x per se. I’ve often thought of getting a SS for riding around town. It just wouldn’t work for me on loaded tours. I much prefer smaller steps between gears.
Quoted: 768 Post(s)
Liked 1,747 Times
I think the 1x setup works for certain people and certain situations. My wife loves her 1x setup for the road, always hated having to deal with 2 chain rings, so 1x works for her.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 272 Post(s)
Liked 448 Times
I’d suggest looking at Sheldon Browns Gearing calculator. It can be configured so you can compare your speed at a few set rpm’s to get an idea of the gearing you want. I think going with the 34T will get you 20 mph at 80 rpm in the 11T. While a 28T in front only gets you 16.7 mph. This is a good excercise. I ride an old 26er 3X. I’ve been looking to upgrade and FS bikes are pretty much 1X.
https://www.sheldonbrown.com/gear-calc.html
Liked 10,975 Times
A while back, the rear wheel on my SS had a broken spoke, so for a couple weeks I was commuting on a geared bike. It was very pleasant, actually. But at this point in my life, my only hipster cred comes from commuting on a SS, so I'm now back to flogging the bike up the hills around here and sweating like a pig.
Liked 2,164 Times
I don’t know the frame differences between 2020 and 2021, (with the pandemic and no 2020 bikes it is hard to say if mfgs are making geometry changes), but the 2020 Marlin 7 offered a 2x9 with 22/36 chainrings. Hard to say if the extra 2.5mm outboard of the outer ring made it possible or not.
The 36t 82mm bcd is only found from sources on AlliExpress and the like.
John
