(New design) Quick Release pedals for the Speedplay mount
Quoted: 11 Post(s)
Liked 7 Times
Hey guys,
Ive been working on this design for a few months and just finished it, and milled in Titanium for testing.
So far so good and very convenient and sturdy!
Is there any need for this?
- Quick release for Speedplay pedals
I am a pilot and fly my folding bike with me in a small general aviation plane.
On some of my trips to the mountains, I enjoy clipping in using speedplay pedals and monitoring the wattage through a Stages custom Ultegra arm.
I wanted a quick release speedplay pedal, so it would store against the frame like the MKS brand does, and fit neatly into the baggage compartment of the aircraft.
Swap between bikes and quick, with no tools needed.
I spent some time designing this part and testing it in aluminum before finishing last week and cutting from Titanium. The result is very satisfying.
Not sure if a speedplay quick release has been done before, so Ill post here and see if anyone is interested in these titanium axles too.
I can make it for SPD-SL also, but only need the speedplay on my bikes here
Pics here
https://switchboxcontrol.com/speedplay
Let me know if anyone is interested, and maybe I can make a bigger run next time
Pics here
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
Likes For datlas:
Quoted: 11 Post(s)
Liked 7 Times
Same Q factor as stock.. 53mm.
But, an added benefit is... I can make any axle length now. 59mm seems popular for gravel/MTB.
Any size really now
Also if people are using the SPD-SL style, which pedal has the most "axle" stick out? A lot of them are flush to the crank and no room to add this custom part.
I found the R8000 pedal has enough to work with, but not sure if this is popular with the SL guys.
Any size really now
Quoted: 768 Post(s)
Liked 1,744 Times
That is pretty cool and I can see where that could come in real handy on the folding bike. Also, with it not screwing with the Q factor, that is that is a bonus. I could see having some wider axles where some people use pedal extenders to help with knee issues or certain types of bikes like bents. When I was getting back into the sport, and I weighed a lot more, I had some extenders to help get a better pedal motion as I worked off my gut.
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Quoted: 11 Post(s)
Liked 7 Times
Thats great to hear. Yes, instead of pedal extenders just one longer piece which is light also.. titanium and cut to the correct size. Added bonus feature - quick release.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
I have no need for them but those are freakin' cool! Keep up the good work.
Quoted: 10238 Post(s)
Liked 5,185 Times
Any size really now
Any size really now
This would be dope for my Ritchey Breakaway. One less took that I need to bring. Currently use garmin rally pedals though, would need to get a different power meter and these pedals.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
Two unrelated thoughts:
1. How much weight can these quick release ("QR") pedal spindles withstand?
2. Ultegra R8000 pedals are now available with +4 mm spindles, but I bet there is a still a market for custom spindle lengths (with or without QR feature).
Achtung!
Bikes: 60.1, Marvel
Quoted: 515 Post(s)
Liked 268 Times
That’s pretty cool. Nice work! Can you kick them into position when getting ready to ride or do you have to kneel down and use your hands? I’m thinking about my triathlons and the gobs of bikes in the corral having a slightly slimmer profile at the pedal level might be helpful.
People always know where their handlebars are, obviously, but I’ve snagged/tangled my pedals against other bikes/bags/etc when transitioning in from the swim to start the bike segment and when coming back to start the run. We’re not talking about oodles of time (especially for me since I do it for the social aspects - not trying to be an age group winner or qualify for St. George or Kona/Nice!) but it would be one less thing to think about.
Quoted: 11 Post(s)
Liked 7 Times
Thanks for the questions.. Yes I need to test this
1. How much weight of the rider can the quick release axle/adapter withstand,,, Good idea to test this.
2. How do people know their custom length? I was told 53mm was the standard and 59mm for MTB to be a little wider out. But wahoo makes the speedplay custom if you call them in 53, 55, 59, 65 they told me. How do people know which one is right for them?
These are being stored on the frame, to make the bike slim, and then you use your hands to release it and move the pedal to the crank arm. Then install with the QR adapter
Likes For brommiephillip:
Quoted: 11 Post(s)
Liked 7 Times
Just did another revision to make it fit tighter. If 53mm is the standard default length for pedal Q factor... how do people know if they are a 55mm or 59mm or etc?
Liked 1,471 Times
Why We Like Longer Pedal Spindles - Slowtwitch.com
A few years ago, I had tried regular Shimano 105 SPD-SL pedals and could not get enough toe out. With the recent release of the + 4 mm Ultegra version, I have finally started to ride clipless. I guess I have big hips.
New, longer Shimano pedal spindles widen your stance on Dura-Ace & Ultegra - Bikerumor
Liked 1,471 Times
The standard distance from pedal center to crank arm surface is 53 mm for Speedplay and 52 mm for Shimano. The articles I linked to suggest that more people than previously thought would benefit from longer pedal spindles/axles and the resulting wider stance width. This makes sense given that many road cycling specifications were developed for pro cyclists, most of whom have slimmer but much more muscular builds than regular cyclists, for whom the next longer version of 56 mm may serve as a better standard.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Rinko pedals for Speedplay/Wahoo. Nice work! 👍
Quoted: 11 Post(s)
Liked 7 Times
Hey guys, just to revisit this and show the latest version... I was working hard to make sure its considered a direct replacement from stock.
And the Q factor is preserved.
To do this, the Wahoo pedal must have the washer installed with it (comes in the original package). And my axle goes on without washer, then the Q is the same.
Is that close enough now to consider it the same length?
Pics below
Pics below
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
Doesn’t an 8mm Allen wrench and about 10 seconds effort accomplish the same thing?
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
That's pretty cool. I use the 65mm spindles in steel. Another nice use is that if you store the bike inside the vehicle for long drives, the lower-profile can be much easier to load/unload. My pedals alway get caught on the rubber mat too.
I have a TERN VERGE X11 and I use Speedplay Zero pedals (pre-wahoo). This looks promising to me.
Sr Member on Sr bikes
Perhaps you should copyright this creation.
Dan
Dan
Quoted: 11 Post(s)
Liked 7 Times
Hey guys -- If you know any friends who might be interested in demo’ing the free Speedplay kit I developed. Let me know! You can forward them this link I put together with pics and video of how it works. Im doing it for free for now to get the word out, if ppl want to try it. An easy way to go from flat pedals(commuter) to clipless (road/exercise) and keep the bike skinny with no pedals sticking out https://switchboxcontrol.com/speedplay
Liked 1,471 Times
1. Inventions are protected by patents, not copyrights.
2. JohnDThompson cited a prior art reference above, so brommiephillip would have to cite and distinguish that.
Quoted: 11 Post(s)
Liked 7 Times
I used two existing interfaces. MKS as cited above and Wahoo/Speedplay on the clear side. I merged them together with a titanium axle that has features from both existing platforms
Quoted: 11 Post(s)
Liked 7 Times
So many responses were received for the free demo kits and definitely dont have available so many free systems! But our first kits were randomly chosen and testing now. Each rider is testing for about 3 weeks to use it for free and then ship it out to the next user.
If you want to test it out this summer for free, let us know! Happy to help. phillip@switchboxcontrol.com
Also figured out some nice colors with anodizing here
