A bit annoyed with how my LBS wrapped my wife’s bars…
Likes For Calsun:
Quoted: 6972 Post(s)
Liked 10,968 Times
Thanks for the inputs! I'll likely just leave it as is. I just learned something new about this shop. The shop that services my bike would never have wrapped this way, but it's about high time I give it a go.
My wife's bike also has some secondary brake levers on the bars just to the left and right of the stem. I had asked them to remove these when they were re-cabling the bike. They put this information in the work order notes, but then when I picked up the bike they didn't do it. My combined ire of them wrapping the bars this way and then not executing on the details of the work order brought me on here to vent.
Quoted: 242 Post(s)
Liked 455 Times
I'd have asked why the work was done incorrectly and how much of a refund I was going to get for the incorrect work.
I work in a bike shop as a wrench and if we screwed up like this we'd have accepted the fault and made it right immediately with a profound apology. We have screwed up in the past and will likely do so in the future...that is why we take responsibility and make it right.
If it's the only shop around that sucks...learn how to do it yourself it is far more satisfying...
Quoted: 28 Post(s)
Liked 33 Times
Now that is plain wrong and incompetent of the shop and its employees.
TeeOhPea 2tha DeeOhGee
You guys are tough. I don't know I ever would have notice that. Still not even 100% sure what the issue is.
With that said, I'm a guy who spent last season with black electrical tape I did myself. Sinful as it was on Zipp carbon bars on a Merckx 525.
Had my guy re-do it with Lizzard Skin medium thick. Liking it, but if I had to do over I'd go with their thickest. After 20 years riding, I've learned I have big hands and am happiest with chunky vibration dampening tape that I can nicely hold loose tight.
Klaatu..Verata..Necktie?
Quoted: 10435 Post(s)
Liked 11,912 Times
Firm but gentle
I've been wrapping bars since 1976, and boy are my hands tired. (JK) I would only use electrical tape as a last resort, even the best tends to slide a little. But if you must, use whatever finishing tape the manufacturer included over electrical tape. If there are no little bits for under the lever hood, just cut some small pieces off before taping.
Calvin, for the love of Merckx, just use an ink pen and leave the razor knife for cutting linoleum floors or hydraulic lines. I have never had an issue wrapping the lower part in the same direction as the upper, nor have I ever seen it an issue. That is to say, keep the direction of the upper wrap like Calvin says. Folks tend to twist the upper flat part of the bars (next to the stem) like someone trying to accelerate a motorcycle throttle, while they ride.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Hmmm. The last time I had the Velofix mechanic over to work on my bikes, he saw my new box of tape in the garage and asked if he could re-wrap my bars for me just because he loved doing it. I was going to do it myself, but I figured he could save me some time and aggravation. He did it for free and much better than I would have. I wrapped my gravel bars soon after. It came out pretty well -- but not as perfect as the Velofix guy.
It's like riding a bicycle
Likes For urbanknight:
Quoted: 242 Post(s)
Liked 455 Times
That's awesome, especially since he did it better than you would have. I am extremely picky doing my bars, wanting both sides to overlap the same amount and end at exactly the right spot with the tapered cut to line up at the same point around the bars... with a small bulge in the drops where my palm rests and more overlap (thicker padding) on the tops... and a over/under criss-cross pattern to cover the brifter clamp. Of course, that takes me about an hour with a many times I end up backing up and rewrapping. I don't know if a shop would be that thorough, but it doesn't matter because I actually enjoy the process.
Likes For Kai Winters:
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
Some bar tapes comes with two 2-3'' long pieces of material made specifically to cover those two area of the handlebar that are hard to wrap, some don't. I always put one around each levers before taping my bars to prevent this from happening.
Your LBS should be able to correct the problem. Bar tape can be unwrapped and re-wrapped.
Likes For eduskator:
Quoted: 1400 Post(s)
Liked 1,883 Times
it was a heckuva lot easier to do a great job wrapping bars before needing to deal with shifter cables and (especially) hydraulic brake lines
Liked 1,883 Times
some method / methods apparently will leave the small void (bare exposed ‘V’ shaped spot)
Liked 1,883 Times
I’m fortunate to get one side completed in an hour
when shift cables and hydraulic brake lines (and related) are added it can become a PITA ...
obviously would go quicker if you did a number of them
Liked 10,968 Times
I don't understand how shift cables and brake lines make it more time-consuming. They're generally taped to the handlebar and the wrap goes right over them.
Likes For Koyote:
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 461 Times
And never worried about covering the rear of the clamp, which my paws never touch.
I wonder if I will ever experience the day of bringing my bikes to a shop and let them have at it.
Likes For roadcrankr:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
FWIW my cables and lines are scotch taped in place and that generally stays put when I rewrap the bars.
Liked 1,883 Times
Liked 10,968 Times
Liked 1,883 Times
hydraulic brake / shifter assemblies are larger / occupy more space behind the clamp - and the irregular shape of the rear-most portion protrudes away from the bar (especially the brake hose fitting area)
some of the protruding part of the brake / shifter assembly / brake hose must be covered - or unwrapped portions will be visible ... however - due to the shape of the rear-most portion, when wrapped the wrap will be pulled away from the handlebar slightly ... and also gotta be careful how much of the assembly is covered by the wrap because the hoods have ‘nubs’ that sit inside recesses on the assembly ... if the wrap covers the recesses - the hood might not fit into place neatly
there ... clear as mud
Quoted: 1279 Post(s)
Liked 1,393 Times
i must be doing it REALLY wrong, it only took 15 minutes or so, with zero experience. there must be some nuance i'm missing.
Quoted: 800 Post(s)
Liked 512 Times
That's too bad about you not being happy with the bar tape. What did the LBS say when you asked them to redo the work?
Liked 1,883 Times
Liked 10,968 Times
'Course, on my hydro disc brake bike, I use Brooks Cambium Rubber bar tape, which is its own special hell as it has no stretch. So I wouldn't notice any difficulty with the brake hoses.
Liked 1,393 Times
ignoring the obvious attempt to make it look complicated by posting an exploded diagram rather than two comparable photos … how is this harder? it attaches to the bar in the same way and is a similar shape at the wrapping interface, just a little thicker.
