A Garmin-Strava question
Quoted: 1743 Post(s)
Liked 1,281 Times
I've been using Garmin computers for many years. Recently I bought an Edge 830 and linked it with my Varia radar. After a ride I upload the data to Garmin connect and it sends the data to Strava. Although Strava seems to take all the data directly from Garmin Connect, it adds anywhere from 20-30 second to the ride time and, of course, it gives me a different average speed. All other data is the same. Why? I'm just curious.
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
I've been using Garmin computers for many years. Recently I bought an Edge 830 and linked it with my Varia radar. After a ride I upload the data to Garmin connect and it sends the data to Strava. Although Strava seems to take all the date directly from Garmin Connect, it adds anywhere from 20-30 second to the ride time and, of course, it gives me a different average speed. All other data is the same. Why? I'm just curious.
Alternatively, Garmin unit may take distance from hardware speed sensor calculations, while Strava is using map distances.
Quoted: 222 Post(s)
Liked 304 Times
In the past, I've tried to sort out the small differences between Strava and Garmin. Seems odd since they are using the same data. But neither explain details of their calculations. I believe many of the differences come down to smoothing filters and other details of exactly how they process the data. Doesn't make one correct and one wrong, just slightly different.
Maybe someone will have the explanation for your specific question, but you might just have to go on living without ever knowing.
Likes For Mtracer:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,644 Times
On my ride today using all of the OPs hard/software, I concluded the ride with an average speed of 15 MPH per Garmin within the last 2 minutes. Looking at Strava later after the data was uploaded, it showed 14.9. This has happened numerous times by degrading the average speed by a tenth usually after just getting the average speed up. To me it is no big deal but find a bit irritating after working to boost the average into a whole number. It’s just the way it is.
I believe Mtracer has it right.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Liked 1,281 Times
It's a guess, but do you have Garmin 830 setting for AutoPause of recording when below a certain speed? While strava might instead just look at total time and distance?
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
TrainingPeaks is also slightly different, and also does not tell you why. Or didn't tell me back when I asked them the same question.
Liked 1,281 Times
When I first posted this it was after a ride in which my Strava time was 20 seconds more than the Garmin Connect time. On the next ride the times were exactly the same. Today the Strava time was 10 second LESS than Garmin Connect. Coincidentally this is on the same course. I'm stumped and just have to let it go.
Quoted: 222 Post(s)
Liked 304 Times
I suspect we are a bit similar on this type of thing. It doesn't really matter, but since it should be the same, we want to get to the bottom of it.
Likes For Mtracer:
The higher speed one is clearly the correct one. : ) But seriously, I've noticed this too...Garmin reads higher than Strava for average speed. I figure Garmin potentially has access to lower level data and is potentially more accurate, though it's perhaps wishful thinking on my part.
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 569 Post(s)
Liked 772 Times
My speeds/times are usually pretty much spot on between the two, but the power numbers can be way off. Strava can say 160w average, but the Garmin shows 180 average, 205 normalized.
Did sprints and gassers last night, so power was all over the place. Strava power numbers 148 avg/189 weighted. Garmin 175/215 weighted. Time and distance were within a second of each other.
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
It happens on my Wahoo often too. I always ''correct distance'' on Strava after every ride to compare. Sometimes it's the same, sometimes my Wahoo calculated distance and time are longer than Strava, but they have never been shorter. On my end, I think it may be related to occasional loss of satellite signal, but I am not 100% sure. I want to buy the new Roam V2 with the dual band GPS this year and I am wondering if it will help. We'll see!
