Gear changes - to pedal or not to pedal?
That is the question.
On my Townie cruiser, the manual states that I should not be pedalling whilst using the twist-shift to change gears. However, on a different type of bike that I have it says I must pedal whilst changing gears.
Why is this the case and how are people supposed to know unless they actively seek out this information? Also, what potential issues might arise if you don't follow the rules?
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
A Townie Cruiser is an electric bicycle isn't it?
On a non-electric road bicycle, for example, you won't shift gears if you don't pedal ... or at least not completely. You don't have to seek that information out, you'll know it the minute you try to shift.
Or are you comparing two electric bicycles?
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
In Real Life
Bikes: Lots
Liked 596 Times
So what happens when you don't pedal and try to shift?
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Is one a hub gear and one not? With hub gears (at least, the ones that I'm familiar with) you don't pedal when changing gear. With derailleur you have to.
Right, so it's dependant on the gear system used then. Took a bit of getting used to!
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
I don't have a lot of experience with IGH but what limited amount I do have I don't recall having to coast to shift.
Stuart Black
Stuart Black
There is the difference... derailleur, shift while turning the pedals without much force (use your momentum)
IGH , pause, I use a quick backpedal (hub without coaster brake, of course) while flicking the lever/turning the grip shifter.
allowing the mechs to work, without power input, for that brief moment..
Passista
Quoted: 866 Post(s)
Liked 721 Times
Even for a IGH, I find that a little odd. Are you supposed to coast every time you want to shift gears? That seems very inconvenient and kind of momentum killing. I can imagine slowly riding up a hill and really needing to downshift. Having to pause pedaling before shifting could lead you to slow too much to keep up speed and you have to stop.
@cyccommite: indeed, you have to very briefly stop pedalling on the cruiser when changing gears. However, the gear shift is so quick and precise that you can do it very easily. Going uphill takes a bit of practice.
I don’t know what would happen if I didn’t stop peddling during the gear shift though. Potential damage or extra wear and tear, I imagine.
Standard transmission, in a car or truck you use the clutch, when changing the gear , a pause is not that big a deal ..
I used a SRAM 3x7 for years, finally retiring it because I didn't need all the gears it produced. I could pedal lightly while shifting either the derailleur or the IGH. That's the way I think most users shifted: turning the pedals but no power being applied. A derailleur, of course, wont shift if you're not moving the chain.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
No, but you should ease off the pressure on the pedals to shift an IGH. You don't need to fully coast, otherwise an internally geared 3-speed fixed gear hub would be impossible to shift. These have a small amount of "lash" built into the mechanism to allow the shift to occur when pressure is taken off the pedals.
Old fart
Liked 3,400 Times
@cycthe gear shift is so quick and precise that you can do it very easily. Going uphill takes a bit of practice.
What exactly happens when you shift under tension within an IGH really depends... the exact mechanism of the shift can differ between gears within a given hub. Sometimes they won't start, or won't complete, a shift until the pedal force gets low enough.
(The middle-of-the-range shift on a Rohloff Speedhub is a very interesting example of this. The hub is essentially a 7-speed hub, used over two ranges via a 2-speed gear reducer of sorts. The shift in the middle of the range is thus an absolutely huge double-shift, both engaging or disengaging the reducer and sweeping all the way across the whole range of the 7-speed mechanism. For safety, Rohloff engineered the hub to always execute the upshift before the downshift, and it won't execute the downshift until you back off your pedaling force... so, if you try to pedal hard during that particular shift, you'll find yourself in the hub's highest ratio until you back off.)
But, not quite as awesome as having a derailleur drivetrain on a downtube-shifted bike ghost-shift to a higher gear right when you need it in a sprint. Everyone thinks you'll have to sit back down to upshift, and then BAM, you just controlled the rear mech telepathically. Or maybe it was frame flex, but who cares?
FWIW the new production has eliminated the old UK AW3 quirk that not quite engaging 3rd, could have your pedal disengaged.
Quoted: 980 Post(s)
Liked 582 Times
As noted by several ^^, a momentary (small fraction of a second) reduction in pedal pressure synchronized with the shift, while still pedaling, works fine. (My experience: S-A 3-speed, Shimano Nexus 7- and 8-speeds, and Alfine 11)
Steve
Steve
Quoted: 1062 Post(s)
Liked 665 Times
I have a couple of old S-A AW's, and what I've found is that you quickly develop a sense of how to shift it. It becomes something that you don't even notice, like shifting a manual transmission car.
I owned a small fleet of delivery trucks for over 25 years and only used the clutch when starting from a dead stop
My Saab 96 had a freewheel bearing in it.. also , only clutched from dead stop . coasted down hills at an idle , still in 4th..
Bike forum... left my derailleur bikes friction shifting and stopped being pushed my the industry & marketing at 7 speeds.
now prefer IGH .... never ride the C&V race bike.. though its pretty.
yadda yadda..
Liked 4,218 Times
taz777's post seems to suggest that the delay in IGH is more active and more noticeable than derailer systems.
Stuart Black
Stuart Black
Liked 4,218 Times
If you rode mountain bikes you tried to plan ahead. It didn't always work out.
Stuart Black
Stuart Black
