Buying new frame and want to get more stretched out
Quoted: 276 Post(s)
Liked 6 Times
I am in the market for a new frameset mostly because I want to change from my cheap Alum to a nicer steel frame. While I'm at it, I feel like I could dial in my fit a little better. I think my fit is ok but I feel like I could be more stretched out. Longer top tube/stem seems to be an answer but then I was reading a fit article and they were talking about head tube height and it's importance on reach
My current bike is a Motobecane Super Strada from bikesdirect. It has a 543mm ETT and 150mm head tube. I am almost 5'11 (not that it matters) but doing the competitve cyclist online fit calc I am recommended to have a 545-550 ETT. I have also had bikes with 560mm and 565mm ETT in the past and honestly felt too stretched out and like my handling was not precise. I have been looking at some Lemond steel frames and trying to figure out if 53 or 55 would be a better fit.
The 53 has a 545mm ETT (basically same as I have now) but has a 116mm head tube as opposed to 150mm on my current bike and the 55 has a 565mm ETT and 133mm head tube but I hear the slacker seat tube on Lemond makes them feel smaller. In theory, would the 34mm shorter head tube on the 53 stretch me out noticeably more then my current bike with the same ETT or should I try the 55 with 565 ETT even though I have had a bike with a 565 ETT and felt like it was too big? Would the seat tube angle on the 55 make it seem smaller and therefore stretch me out just enough over my current bike?
Dilemmas! Sorry for my rant but I'm back in neurotic new bike/frame hell.
Quoted: 276 Post(s)
Liked 6 Times
Adding a couple of photos to try and illustrate my current fit. Not perfect since I don't have a trainer but I'm mostly concerned with my upper body. How does my reach look?
Quoted: 2498 Post(s)
Liked 741 Times
I'm starting to tire of these over analytic obsessive compulsive public ditherings in the Bike Fit forum. I, personally don't see a rider that needs to be anymore stretched out than presently, but, ... I'm not on the bike. If it were me, and I felt that I needed to be more stretched on a bike... welll... for one thing I would not really rely much on a slight difference in head tube length to accomplish it. I would not expect a 1* difference in seat tube angle to accomplish it either. A longer stem and/or a more rearward seat position will directly affect reach and either option are cheaper and easier to accomplish than getting a new frame or bike. FWIW.
H
H
Quoted: 276 Post(s)
Liked 6 Times
H
H
D'oh ! Stick a longer stem on it and that will stretch you out. , as you get older , you will want the stretch less then you get a shorter one
and one, perhaps with more Up Angle.
Glendale, in Metro LA region .. I assume you can find a high end bike shop to pay to get the whole professional fitting thing done .
they will match all that obsession with fit details with a fee structure .
they will be able to suggest a frame size if what you bring in is not right , since the analysis is something you pay for,
if you want to bargain hunt online you will have a top tube seat tube frame angle range to shop for.
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
I don't see why the shorter head tube is a problem. You can use spacers under the stem, or a positive rise stem, to raise the handlebars to the same height as on the frame with a longer head tube. Alternatively, the shorter head tube allows a lower bar if you wish.
Your current upper body fit looks fine to me, as much as a photo shows. If you feel like you want more room, a longer stem will do that too.
So I'd lean toward the smaller LeMond.
Here is an idea, though. You have full geometry info on the choices? Why not draw the bikes (graph paper, protractor, ruler) and see where the touch points end up (saddle, bar, pedals) and where the wheelbase is.
Quoted: 392 Post(s)
Liked 49 Times
Or heck, use this tool
Bicycle Calculator - compare frame sizes and calculate head angle
You can take a tape to your existing bike; hopefully there are full specs available for the LeMond? If this is a vintage LeMond, there are catalogs online.
Trek, Fisher, Klein, Lemond bike catalogs, bicycle brochures
Quoted: 276 Post(s)
Liked 6 Times
So for the record, I ended up buying a used Cannondale CAAD9 frame set over the weekend in size 54. I should have it built up by the end of the week and until then I'll be in suspense to see how it fits. Geometry is pretty similar to my current road bike so it should be good. I considered a few CAAD 56 frames but I thought it would be too big.
My scientific study went like this: CAAD 56 has 560mm ETT. My fixie has a 560mm ETT. I ride the fixie with riser bars in a more upright comfort position and it's fine. I threw a set of drops on it for a couple of days with brake hoods and immediately had discomfort in my arms on the hoods and felt way to stretched in the drops.
Liked 741 Times
H
