Finally getting some good use out of the Voyaguer
Quoted: 838 Post(s)
Liked 1,081 Times
The amazing weather is upon us in Arizona and I took the opportunity yesterday to do a day trip from my home in Downtown Phoenix to the base of Tonto National Forest, about 80 miles round trip. The entire route is bike lanes and path with some climbs towards the end. The voyageur is an extremely comfortable ride, although I'm not sure if I'm sold on the half step setup yet so that may change in the future. It often seemed like it was just a little too high or a little too low in every combination, but I''ve not been riding regularly and certainly haven't spent enough time with the setup, so we'll see! The thing really glides though and is so stable it sometimes feels easier to ride with no hands I'm guessing this doesn't change much the more heavily loaded it becomes. Anyways, some photos:
Likes For polymorphself:
Great scenery, nice looking bike!
Likes For daka:
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,700 Times
Totally beautiful scenery... sort of reminds me of when I used to live in El Paso.
The Voyageur is looking sweet as well. You mention feeling between gear space... are you using that half-step theory with that?
Commence to jigglin’ huh?!?!
Quoted: 838 Post(s)
Liked 1,081 Times
Thanks! And probably not. This is my first time using half step gearing. I can say that I spent time in every possible combination, but I'm not sure I'm getting the most out of the setup. I find that I've almost never used the largest ring and stay in the half step 90% of the time, but the space in between the rear cogs feels massive when shifting through them.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
Great scenery and good looking bike. I really miss the south west
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Liked 1,700 Times
So if you're in the little ring and it's too easy in the 24, but too hard in the 20- put it in the 24 and shift up into the big ring.
Liked 1,700 Times
It'll make sense- Especially if you're just shifting up and down in the rear- and only using the big ring as an 'overdrive.' Once you figure out you've got an 'in between' gear with the front derailleur- you'll get it.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,600 Times
Nice bike.
Likes For non-fixie:
Quoted: 1949 Post(s)
Liked 2,010 Times
That is a beauty. To explore that 1/2 step thing, I suggest the following: when you are in the "wrong" gear, look to shift the front first and if it is already where you wanted to go, then shift the rear and if it is too much leave it there and then shift the front. It really is a neat set up.
Likes For Classtime:
Quoted: 838 Post(s)
Liked 1,081 Times
If it never grows on me I’ve got the drivetrain from a 1988 Miyata 612 lying around and might try that (48/38/28, 14-28).
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,595 Times
Still a lovely bike!
Likes For cb400bill:
The way I see it, the logic behind half-step gearing is this: the ratios on the freewheel are widely spaced - say, 20% apart - and seldom feel like the right gear. The chainwheels on the other hand are narrowly spaced - about 10% apart so you can dial in the ratio to where it feels "right". However, half of the time it will require a double-shift to achieve that. For example, if you are on the big chainring and the middle cog and that gear is just a little too low, to get the adjacent ratio will require shifting to the next smaller cog on the freewheel (20% change up) and then ALSO changing to the smaller chainwheel which changes you 10% back down - a net change of 10%.
But things could be worse - back in the bike boom, a low to mid range 10 speed touring bike came with "Alpine" gearing, usually 40-52 in the front and 14-28 in the back. That arrangement has fairly well spaced ratios on paper but (counting 1-5 on the small chainring and 6-10 on the large) the ratios in sequence are 1, 2, 6, 3, 7, 4, 8, 5, 9,10. So, to change to most any adjacent ratio for fine tuning requires a double-shift - every time. Don't ask me why, but I still ride a couple bikes set up like this..... So with that in mind, now maybe half-step doesn't sound so bad?
Likes For daka:
Quoted: 838 Post(s)
Liked 1,081 Times
Plug your chainrings and rear gears into this handy calculator to find what you're missing!!! https://www.gear-calculator.com/
Likes For Cougrrcj:
