Show your Trek Multitrack!
#1076
Deraill this!
Bikes: 18 Cdale Quick 1, 94 S-Works M2, 98 730 Multitrak, and a few others
Quoted: 145 Post(s)
Liked 444 Times
Hello from Belgium, I got this mean green hybrid machine last week for about 100 $, the paintwork and general condition suggested it was either not ridden a lot, or very cautiously. The grips had gone sticky and the original Oasis saddle was HUGE so I replaced them with new equivalents and added new SKS mudguards. The rear bike rack and the Ritchey stem (in favour of the adjustable stem) came from the parts bin. A quick final polish resulted into this classics-inspired commuter/weekender bike, very pleased with the ride and the looks. 👍🏻
#1077
https://www.sks-germany.com/en/produ...-silver-11816/
Likes For JayNed:
#1078
Deraill this!
Quoted: 145 Post(s)
Liked 444 Times
They're this silver/grey version of these 55 mm mudguards, the tires are currently 41mm, these mudguards will fit anything between 32-47 mm and are quite easy to fit.
#1079
Almost Finished with this old Multitrack
Counting the $30 I paid for the bike I'm in so far for just over $125 with more to come. New tires, tubes, and seatpost plus lots of hours in disassembly, assembly and cleaning. LOTS of cleaning! I think the previous owner just punched a hole in cans of motor oil and poured it over every component and most of the frame. Used rubbing alcohol on the frame, clayed it and ceramic coating applied. The chain seems to be okay after soaking in Liquid Wrench, cleaning and lubricating but it will be replaced in the immediate future. I just want to ride it some first. All brake and shifter cables are rusty so I'm going to get new cables and cable housing for those which is going to add up. I know I could have found a bike in much better shape for about what I'll finally have in it but this is something I enjoy doing now that I'm retired. Keeps me busy. Wow. Just saw a Trek 800 "Mountain Track" on FB Marketplace for $25. NOPE! This one is enough for now.
#1080
My rescue multitrack 700 continues
I think it is a 1992 model. 30.8 pounds!
Forgot to add a photo.
UPDATE: After all that work and $ I found a Trek 3500 aluminum frame mountain bike in great shape. Weighs 30.16 pounds even with front suspension. Sold the Multitrack.
#1081
Deraill this!
Quoted: 145 Post(s)
Liked 444 Times
Likes For Trav1s:
#1082
I had a 1990 Multitrack 750 (posted years back in this thread) that I unfortunately had to retire due to an ovalized head tube. The local MTB trails by my house were just a bit too much for it, apparently. Now I'm back four years later looking for another Multitrack, because there's not much else that is such a good combination of quality and value, especially the double-butted frames. I'd like to find another 21" lugged 750 or 790, and hopefully not ovalize the head tube this time.
#1083
#1084
Quoted: 576 Post(s)
Liked 1,004 Times
This was pretty common BITD when MTBs took off; much was writ in the past about it. Bontrager, Ritchey, and Breezer stuck to 1" high quality steel for many years with no issues. Others upsized to 1-1/8" as an easy fix. Fisher saw the writing on the wall and went straight to 1-1/4". Fast forward to today, and 1-1/8" is the new "standard"
#1085
Anyone ever try to do a lightweight Multitrack build? Still with gears, just with lightweight parts.
Under 22 lbs. would be sweet - feasible? Someone above posted their 1x drop bar conversion weighing 23.5 lbs, but it had fat tires and 1,800g wheels. Seems like sub 22 would be possible without going too crazy.
#1086
Quoted: 576 Post(s)
Liked 1,004 Times
I built my 21" '94 750 to 23lbs 5oz trying to not be heavy, not necessarily a lightweight build. 2x9, 1800g wheels, 38mm tires
Half a pound should be easy to take off.
Likes For DorkDisk:
#1087
Bikes: Trek 970, Bianchi Volpe,Casati
Quoted: 358 Post(s)
Liked 122 Times
Frame size , stand over
I'm looking at a 750 thats looks like a 23. I'm 6ft longish legs , wonder if right height . I think my inseam is 32. For some reason the dude never responded to my question to measurement. It's over an hour drive. Any one here have that frame , thanks . I already have vintage touring, vintage mountain, this could be my vintage gravel
#1088
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
I have a '97 750 in 21". I'm also 6' and wear 32 slacks. I prefer frames slightly small vs. slightly large, and I like the 21". I do like the ride to be more upright and comfortable...if you like speed and prefer stretched out some, then the 23" might be the right size. These have pretty long stems to begin with...even though I have the 21", I still shortened the effective reach quite a lot with a shorter stem with a fairly long quill.
#1089
Quoted: 358 Post(s)
Liked 122 Times
Thanks.
#1090
Liked 762 Times
#1091
Happy banana slug
Quoted: 1534 Post(s)
Liked 1,534 Times
How'd it go? Did you get the bike? 750 was top of the line for most years.
#1092
This 730 has bubbled to the surface here. A bit rough. The main issue is both brake mounts on the fork are broken off.
#1094
Quoted: 576 Post(s)
Liked 1,004 Times
All that damage seems to from the elements. I'd look hard at the inside of the frame before attempting any fork repair. Pull the seatpost, headset, and BB; and look for interior rust. If the seatpost doesn't even come out, I'd consider tossing it.
#1095
Quoted: 62 Post(s)
Liked 258 Times
Unless I found worrisome frame rust per DorkDisk, I would still consider this a good find and replace the fork with a Dimension steel unit, which are inexpensive and look very much like the OEM unit, albeit in black. Or I might be able to round up a good used replacement for even less at one of my area community bike shops. Repainting a fork with automotive touch up paint is easy peasy, but I don’t think having a black one is the end of the world either, maybe making it part of the color way with black hardware and accessories, which you already have a good start on.
#1096
Bikes: 2018 Jamis Renegade Exploit, 1996 Trek 930, mid-90's Dean El Diente, 2010 Scott Addict SL, 1998 Trek 730, Xtracycle EdgeRunner 30D, Xtracycle Swoop, 1992 Trek 790
Quoted: 87 Post(s)
Liked 107 Times
I've got exactly this frame. I bought it used, and one of the front brake studs had similarly broken and been fixed with a Problem Solvers Stud Repair Kit. It wasn't initially installed properly, but after re-tapping the threads in the fork it's held up great through daily use. I don't see the kit on the Problem Solvers website but it is widely available from bike shops. I'd give it a try before buying a new fork - it's inexpensive, and you could probably even assemble your own equivalent cheaper from hardware store parts.
#1097
Deraill this!
Quoted: 145 Post(s)
Liked 444 Times
#1099
Happy banana slug
Liked 1,534 Times
#1100
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1233 Post(s)
Liked 3,577 Times
Then again, I understand any misgivings about working with an unresponsive seller. Good news is these bikes are fairly common
There were 135 Confentes, but only one...Huffente!
