MTB without suspension ?
#51
Quoted: 2236 Post(s)
Liked 1,314 Times
Because they are made for flat bar postures. It's like complaining that you can't put 26" wheels on a 29r because the geometry makes the BB too low. Uh.. Yep. They don't make em to take 26" wheels and, for the most part, they don't make em to take drop bars.
#52
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Also, to say that a frame has excessive stack and reach for its size is a nonsensical statement. Stack and reach IS the size. It is like saying someone is tall for their height. If you find that all larges have a to big a stack and a reach, that means you should look at a medium.
What you are looking for is already out there you are just too set in your misinformation to know what to look for.
#53
It's funny, wanting the world to build all their bikes to suit ones momentary whimsy rather than just thoughtfully choosing the bike for you.
If one has unique and specific tastes, get a frame built. It's not rocket surgery and far less expensive than buying successive new bikes made for other purposes to be unhappy with.
I also don't believe riding rigid makes for more skilled riding.. it just feels that way because you have to commit 100% effort into doing sub optimal routes compared to what one can do with suspension. People are doing things now that would have been inconceivable when rigid mtb was "the" thing.
Yes, you can drive a 1960's Lotus around an F1 track but that doesn't mean you are keeping up with the 2000's McLarens.
#54
If you go rigid, go with one designed to be rigid.
If you want lightweight, the Giant Toughroad is really great. I have mine with 30mm rim and 2.15" tire on front and it is very smooth.
Or look at the Jones bike, the ultimate bike designed NOT for suspension. Fits 3.25" in rear and up to fattire in front if you want to be flexible.
#55
Quoted: 2975 Post(s)
Liked 1,182 Times
The manufacturers design and make bikes for the masses. Not just what one person thinks they want or need.
Here's a start. Prepare to lay down some $$$ and get put on the waiting list.
https://waltworks.com/
#56
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 131 Post(s)
Liked 141 Times
MTB frame design
The seat posts way out like Mr. Clem von Jones's Scott 29er make me cringe. The forces at work on that seatpost tube are magnified if the frame isn't triangulated by supporting seat stays near the top of the seatpost tube. This comment is for non suspended MTB's. Suspension helps to soften the forces at work on a long seat post out of a frame. I have seen rigid steel frames fail due to the seatpost loadings on the seatpost clamp or the tube itself. That said a MTB should have adequate clearance over the top bar to limit the frame from highsiding the rider on narrow trails with a steep side angle. If you get hung up on a top tube before your feet hit the ground you can fall. Tough choices but I like to see less seatpost extension out of frames. Having raced MTB's here in Northern California I saw all the early attempts to put drop bars on mountain bicycles and race them. For MTB racing the drop bars did not work out. Ease up on the harshness of the off roading and you get gravel roading and drop bars work great for that. I checked out the Jones website and that is a very cool bicycle. Big fat tires really don't need suspension unless you are racing and maybe not even then. I really like their ability to traverse sand, loose gravel, and other very hard to deal with riding surfaces and be comfortable at the same time.
#57
Advanced Slacker
Liked 2,537 Times
Maybe things were different back in the day, but the exposed seat on that bike is not unusual at all by modern mtb standards and is a non-issue. Even on a HT. With the move towards longer and longer dropper posts, that amount of extension is expected and planned for with modern bikes. You just have to make sure you have enough post insertion.
#58
Advanced Slacker
Liked 2,537 Times
Double post
#59
Quoted: 131 Post(s)
Liked 141 Times
Maybe thinks were different back in the day, but the exposed seat on that bike is not unusual at all by modern mtb standards and is a non-issue. With the move towards longer and longer dropper posts, that amount of extension is expected and planned for with modern bikes. You just have to make sure you have enough post insertion.
#60
Advanced Slacker
Liked 2,537 Times
I don't have experience with the modern style of MTB and these ultra long seatposts. I have broken a couple of steel frames with ultra long seatposts. The frames did not break where I expected but more toward the bottom bracket. The frames I broke were heavy duty and designed for longer seatposts. I've never broken a frame using short seatpost lengths. I'm over 220lbs and this may also explain why I worry about this type of design.
#61
What happened to your "bike store"?
#64
Liked 1,314 Times
That is fine, nothing wrong with wanting drops. Just realize that many of the 29rs are built for flats and that you have to do a little investigating to find or create the right geometry to convert (or find one with drops already). You can't get mad at the industry that the conversion isn't a default proposition. It's the same with 26"mtb drop bar conversions. Doable, but you have to think about it.
#65
Advanced Slacker
Liked 2,537 Times
Likes For Kapusta:
