Peugeot bottom bracket?
peugeotphile
i have a peugeot bike converted to fixed gear and i need a new bottom bracket...i think my frame might be from '83...can anybody help with what kind of bottom bracket i need...ie. french, british,..etc
Peugeot usually had French threaded BB's. Once in a very blue moon you find french bikes with Swiss threads, but I think your Peugeot will have a french threaded BB
Quoted: 413 Post(s)
Liked 109 Times
More than likely its Swiss. First, determine your bikes year and model. If its post '80-'81-ish its more than likely Swiss, if its post '84-ish it may be BSA (British)
Peruse these links from my website to determine:
1. Year https://cyclespeugeot.com/SerialNumbers.html
2. Model based on year https://cyclespeugeot.com/Catalogs.html
3. Threading https://cyclespeugeot.com/Threading.html
Hopefully its BSA but if its Swiss a BSA may fit..
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
I concur with Jim. A 1980s Peugeot will not have French BB threading. One can force-install aluminum ISO (24 TPI) cups into a Swiss-threaded (25.4 TPI) BB shell (been there ... done that).
peugeotphile
i painted my bike but from the markings that i remember im pretty sure its either an '83 or an '85...where do i find serial numbers on the bike?
Oops! Sorry! I believe it is entirely possible it will have BSA treading, possibly Swiss. My experience is with older PX-10's and such, and mine had French. My Motobecane Grand Jubilee had Swiss, which is ream-able to Italian. I had mine converted to Italian to facilitate finding BB's.
Thanks miamijim for those links. My bike's S/N is 2300xxx
So I assume since it's 7 digits, and the first digit is a 2, that it's a 1972. From the catalogs, it appears to be a UE8: https://cyclespeugeot.com/images/1970...-early_UE8.jpg
So now I just need a new bottom bracket and would like a new crankset. Trying to build up a singlespeed. Any help on where I can get these is appreciated.
French threaded
Bikes: many
If it's mid 70s or earlier you need to ignore the serial number conventions IIRC.
but if it is mid to early 70s it would likely be french, 55mm X 1mm. It can be bored out to a more general BB but with a UE8 thats just going to be a singlespeed i would say its not worth the effort.
However if you are lucky you can find a French threaded BB and find a set of stronglight cranks to throw on it. Or you can get some paul cups and convert it.
Thanks for the quick replies.
Other than ebay, where might I find a french threaded bottom bracket? This is supposed to just be a singlespeed/beater, so I'd like to keep things on the cheap if I can.
FalconLvr
Bikes: 62 Falcon, 58 Raleigh Lenton Gran Prix, 74 Raleigh Pro, 75 Raleigh Int, 75 Raleigh Comp, 76 Colnago Super, 75 Crescent, 80 Peugeot PX10, plus others too numerous to mention!
Quoted: 51 Post(s)
Liked 112 Times
Should be some french thread sugino cups on ebay from time to time for not much money.
I didn't want to start a completely new topic, so thats why i ask my question here. i Have a peugeot iseran bike and i want to replace my bottom bracket, does anyone have an idea what kind of thread that bike has?
Search; "Velo Orange French BB"
Measure !.. and if you don't want to bother finding out for yourself * "VO threadless BB"
* as you see above, the blind guesses above are all over the map.
French=35mm 2 RH threaded cups; Swiss, the RH cup is LH thread ; british is 1.370" frame thread : RH left, LH right..
Still learning
If it has rainbow decals and Japanese cranks and components, the cups threading will likely be 1.375 X 24.
Bikes: Fuji Sportif 1.7C, Shogun Metro AT, Jamis Durango SX, Miyata Alumicross, Fuji Special Road Racer, Mongoose ATB, Fuji SST 1.0 Team, Gitane (?), Specialized Rockhopper SS, Univega Gran Turismo, Univega Supra Sport Mixte, Nishiki Tri-A, Diamondback Coil
Quoted: 82 Post(s)
Liked 141 Times
https://www.sheldonbrown.com/cribshe...mbrackets.html
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Only you will know for sure once you remove the bottom bracket. It’s one thing that makes french bikes from that era more challenging, particularly if you want to modify the bike. Keeping what’s on there now is not that challenging at all as the oddball stuff, as long as it is still in good condition, will continue to provide good service for many years to come.
feros ferio
Liked 1,325 Times
The original Swiss (left) threaded Stronglight fixed cup on my PKN-10 was gold colored, if that helps any. All of the French (right) threaded Stronglight fixed cups I have seen were silver/chrome colored.
Thrifty Bill
Liked 964 Times
I've got a box full of silver swiss BB. Like everything in the vintage bike world, it varied.
Quoted: 5 Post(s)
Ive tried a few Peugeot conversions from cotter pin to sugino b.b. But the cotter pinned bracket has rivets for the bearings spaced farther apart then most, if not all of my sugino brackets. I have done the force thread, and looked for thick cups, but mostly had success force threading a sealed b.b. in
there
there
