Any recent experience with Bike Friday Tikit stem fix?
I recently bought a used BF Tikit, fully aware of the recall that was issued for the handlebar stem. Seller said he didn't know if it had been fixed, as he had bought it used himself. Since I live fairly close to BF HQ I figured I could take it in to be fixed if necessary. After a call to BF, seems like it might be (they won't know for sure until I take it in, as I couldn't find the serial #). I was prepared for that, so OK.
What I did NOT know was that BF no longer has the machinery to repair the existing stem; rather, they need to replace it with something different. They said the stem wouldn't fold the same way. I got the impression that the new stem would be similar to the Pakit -- removable but not foldable. Bummer, since it would change the Tikit's "gestalt".
Wondering if anyone here has this newer version of the replacement stem and can comment on it (or share a pic). Thanks in advance for any feedback.
Quoted: 380 Post(s)
Liked 106 Times
Call BF on their 800 number and they will help will help. BF keeps all the info on all the bikes they have built. PS because you live in Portland just go see them. Roger
Palmer
Quoted: 1670 Post(s)
Liked 1,825 Times
As if we needed another example, no, most posters don't listen, and read what's been posted up thread only to the point it agrees with their thoughts.
My tikit doesn't have a serial number. When I inquired, BikeFriday informed me they built some unknown number of tikits during some undocumented production period without serial numbers. I was shocked - even the BSOs at Walmart have serial numbers.
Even though I bought the tikit direct from BikeFriday, they claimed to have no record of ever having done business with me or have any record of the unserialized bike I had purchased from them.
After nine months I did eventually get a replacement stem from BikeFriday on the recall. I swapped it out myself and kept the old one so I'd be able to prove the bike had been repaired if I ever sold it - pretty much the only way, since without records and without a serial number there was no traceability.
Well, that would suck. Here's hoping your new-to-you tikit did make it through the recall.
My replacement tikit stem has a red dot on it (and no headbadge).
The original stem did not have that red dot (but did have a headbadge):
HTH
HTH
Hello
I purchased a used Tikit from the second owner (making me the third).
I live cross continent from Bike Friday, a replacement stem was shipped at no cost.
I installed it myself with help from their you tube videos.
Its been a few years now, but I do recall not any difference in the stem fold.
Interesting, zebede. Maybe there's hope the stem can stay the same style. How long ago did you replace yours? Things may have changed since, who knows.
[QUOTE
[/QUOTE]
Thanks for this, TCS. Very helpful, if a bit discouraging. My stem doesn't have a red dot :-( My Tikit has the SRAM dual drive so was not part of the first couple of production years (per the Tikit Wiki at https://cs.gmu.edu/~sean/stuff/tikit/wiki/models/). And it sounds maybe (?) the issue had been addressed in later production runs, based on a discussion here (https://www.bikeforums.net/folding-b...tem-issue.html). It would be nice if the stem were deemed OK and did not have to be replaced, though the BF recall communication seemed quite all-encompassing, no doubt for CYA reasons that are understandable.
[/QUOTE]
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
BF's page says the repaired/replaced stems ALL have the red dot. If yours does not, chances are not good that the work was done. It's been so many years that BF may no longer have sources/setup to make the appropriate matching stem; they've moved on with many different models none of which have folding stems. The pakiT stem is detachable, not folding. Hopefully if you go to their shop they can figure out some acceptable way for you to continue using the bike. Good luck!
Likes For linberl:
Hello
Quoted: 800 Post(s)
Liked 247 Times
Bike Friday is a small company that made many different models of bikes and for each model several versions.
Its almost impossible for them to stock spare parts for all those models/versions of bikes.
It would have been better to have a small amount of models regularly improved instead of each time develop a new bike completely different from its predecessors and completely stop to sell the previous models.
We often complain against Brompton to be too conservative, but for Bike Friday, its the opposite !
Palmer
Liked 1,825 Times
So how would a seller prove a tikit had the repair stem? Anybody can paint a red dot.
Liked 374 Times
I'd say this news pretty much decimates the used value of any unrepaired Hyperfold tikits. Caveat emptor.
https://youtu.be/fQscBxx7wLE
Quoted: 800 Post(s)
Liked 247 Times
Palmer
Liked 1,825 Times
Your experience, linberl, and that's great, very happy for you; my experience (as I related in post 3) is BF sold me an unserialized bike. When the stem recall came around and I inquired why they hadn't contacted me, they said they had no record of ever having sold me a bike.
tikit owners - to protect your resale value, contact BF ASAP and attempt to get a letter from them that your bike was repaired under (up to three) recall campaigns.
Palmer
Liked 1,825 Times
Liked 374 Times
Palmer
Liked 1,825 Times
Not trying to play semantic games and generous allowance is made because not every poster on Bike Forums has English as a first language, but I don't have the serial number of the bike because it doesn't have a serial number.
Example: a person is interested in buying a tikit. The bike has a serial number, but it is unknown to the prospective purchaser. That person can't inquire about records because they don't have the serial number. Now imagine that person is considering buying my tikit or one other of some unknown number that also were not serialized by BikeFriday. The prospective purchaser can't inquire about records because the tikit doesn't have a serial number.
HTH
Certainly, no argument with you there - BikeFriday screwed some of their customers.
HTH
If you don't then you're screwed.
Liked 374 Times
HTH
HTH
