Are metal tyre levers necessary for my tyre?
I'm riding a foldable, 16inch Schwalbe Marathons. I realised the LBS who installed it for me used metal tyre levers. Say I had a puncture on the road, is it necessary I get metal tyre levers just in case or will plastic ones be fine ?
Likes For rhenning:
Plastic ones can work but need to be sturdy. Schwalbe Marathon tires are notorious hard to get on and off the rim. I have them on most of my bikes and I use Pedro's plastic tire levers. They are sturdy but I have managed to snap one while trying to get a Marathon off the rim. But you need more than 2. At least 3. I found it best to use at least 3 tire levers at the same time to pry a tire off the rim.
Quoted: 6196 Post(s)
Liked 4,811 Times
If you break or bend the plastic levers you have, then you'll either need a stronger plastic lever or a metal one. But even metal levers can be just as lousy as plastic levers. It all depends on the type of metal or plastic or used to make them and their design.
Some plastic is pretty stout stuff and will take blows from a hammer without denting or fracturing.
Quoted: 839 Post(s)
Liked 1,064 Times
"Steel Core" tire levers have plastic on the outside to protect the rim but still very strong. Here's just one example but there are other brands available. Super B TB-5566 Bike Tire Lever Set 880009 (homedepot.com)
The few times I've used plastic levers I've managed to snap them. I stick to the metal levers that came my way 30-40 years ago. That said, I prefer to not use levers at all. Even my Schwalbe Marathons that I just put on my 26" wheels I can get on and off without them. The trick is to not do the last bit opposite the valve but at 90 degrees to it, and have the opposite side as far into the middle groove as possible to give you just a little more length to get over the rim, and that goes for taking off or putting on. The valve prevents the tire's bead from going into the center groove.
On the left is the correct way, with the blue tire all the way in the groove and slightly stretched, on the right the tire is in the bead and can't stretch over the rim. Green is outer rim, red is the bead channel and the black is the inner groove. And the stem is at 90 degrees on the left. Not all rims are like this though.
Likes For zacster:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
+1. Always best to practice in the comfort of your home, and then you will be much more prepared for the road.
Half way there
Quoted: 987 Post(s)
Liked 880 Times
Thanks for the hint.
So you are saying that doing the last part 90 deg to the stem gives you a bit more slack to finish? Makes sense. I'll try it that way next time I mount a tire. I've always done the last bit 180 deg from the valve and have only rarely had to resort to my VAR tire jack so I've either been lucky with tire/rim combo or I have strong thumbs. Nevertheless, I look forward to encountering a difficult mount so I can try your method. I volunteer at our local bike co-op and typically do a couple of mountings each week.
Quoted: 3514 Post(s)
Liked 2,927 Times
I'd avoid using levers at all, if at all possible.
Probably won't use the 90 degree trick, since I've had no problem with rolling the bead over at 180.
Palmer
Quoted: 1671 Post(s)
Liked 1,825 Times
Ah, a Schwalbe Marathon on a 16" rim - the big wheel guys just won't understand!
Here's a video on how to mount one without tools:
Cool! Of course, you'll note she kneaded and massaged and fussed with that thing for over two minutes to get it to pop on, while seated comfortably in pleasant weather.
I talc my tubes and use three coated steel levers for removal and a VAR tire jack for reinstall and make flats my #^%$*@.
Liked 2,927 Times
A seasoned mechanic would have that tire installed in 30 seconds. A work bench to lean against would have helped her, but kudos to her for doing it seated.
Palmer
Liked 1,825 Times
I don't know where the conventional cycling technique of always starting at the valve came from, but it's bogus.
Liked 2,927 Times
Liked 2,927 Times
Nope, it isn't bogus. You can get more space to work by manipulating the valve stem in or out to get more "slack" to work with. But hey, whatever works for you.
Palmer
Liked 1,825 Times
You do realize that's the Schwalbe One Tan Wall she's talking about at that point, not the OP's Marathon, right?
Well, at least the nice lady in the video didn't need tire levers to remove the tire.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I like KMC Missing Link Levers. They are stouter than most plastic levers, and they turn into a chain quick-link breaker that really does work.
That's why 90 degrees works. The valve is now out of the picture whether you start or end there.
