Paint removal for welding
Quoted: 2700 Post(s)
Liked 486 Times
Sup guys, my bike died on the way to work. Found the issue and installed some zip ties, and I intend on trying to get it welded back together. I don’t intend on removing any components, and know I’ll need to strip the paint back. Anyone have advice? Angle grinder? Wire brush?
dont intend on doing any heat treatment of the metal afterwords. May add some epoxy. This is my fastest commuter, and newest bike. I would be very upset if I have to trash it. The cable tie array seems to help a lot.
Please help me save my bike
Likes For LarrySellerz:
Likes For icemilkcoffee:
Really Old Senior Member
The bike broke with the heat treatment intact. You expect it to hold up after you anneal/soften the joint?
I'm with the frame is toast crowd.
Likes For Bill Kapaun:
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,437 Times
IMO, there is no saving that bike. Save yourself and trash it.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
If the zip ties are working for you, just get bigger zip ties.
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 212 Post(s)
Liked 356 Times
Add more zip ties and maybe some of this metal strapping, be sure to use flat washers under the screw heads.
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Likes For Shadco:
Expired Member
Quoted: 3681 Post(s)
Liked 5,445 Times
Fashion a splint from a beer can, slather with epoxy then pop in a couple of rivets.
Quoted: 6199 Post(s)
Liked 4,816 Times
That's aluminum, isn't it? Not going to do any welding on it that isn't going to cost you more than the bike itself unless you have a friend that will do it for free. And that welder ise going to have to be one that is really good with the skills, knowledge and have the right type of equipment to make that particular weld on that thin tubing if you want it to last very long.
If you have to salvage it and make it work for a while, you might be better off taking off most of the stuff that'll be in your way and wrapping it with fiberglass cloth and epoxy resin. It'll be ugly, but who really cares.
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
How do you expect any of these fixes to hold up, without duct tape?
Likes For JohnDThompson:
Liked 486 Times
Luckily, my partner at work is a master welder. Ive read that the seat tube is the least critical of the tubes in the bike, but now that its gone what tube/joint is experiencing the most stress? Thats my biggest concern honestly, the bike flexes and eats up my power now but its not terrible, dont think it will crash like this.
Edit: buddy is saying take it to the shop and try to get a warranty from the manufacturer?
Quoted: 6973 Post(s)
Liked 10,975 Times
Quoted: 2026 Post(s)
Liked 1,096 Times
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,437 Times
Quoted: 4211 Post(s)
Liked 3,881 Times
Now much more stress is being placed on the rest of the joins, which one will fail next is less the question than what will happen when that next one fails. I would like to see the face of the break but I suspect it started at the weld's edge as undercutting is a well known stress riser.
I would ask Larry what about this bike makes it worth trying to fix. Sentimental value? I fully understand trying to do a repair to see if one can. But as others have pointed out the repair is one that often isn't a long term fix, has challenges to do well (even with all removed and access is not the problem) and does nothing for the remaining frame joins/tubes that have seen the added stresses that the crack's faces displacement shows has happened.
"You guys -- talking to Larry as if he'll ever follow sound advice. You crack me up." koyote
If some of us seem to be sounding like that I will apologize somewhat and defend that attitude with our having considered this type of question here so many times before, and watched those OPs seeming to want to only listen to the replies that agree with their initial belief. I don't think the discussion here has, as yet, descended down that path too much. Andy
AndrewRStewart
AndrewRStewart
Quoted: 1562 Post(s)
Liked 1,734 Times
This is the reason why Serotta and Ritchey started using seat tubes that flare out at the bottom where it meets the BB.
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
Good Choice: New frame
Risky Choice: Repair attempt. Any repair of the broken tube will be less structurally sound than the frame was originally, and the potential for a catastrophic disaster increases significantly.
Likes For Eric F:
Liked 486 Times
Frame is Scott and no longer under warranty. He thinks he can weld it back together, said it failed in the 'heat effected zone" at the base of the weld .He has me looking up heat treatment and said we can do it with a thermocouple and an oxyacetylene torch, but I am skeptical, I think doing a terrible job of heat treatment might be worse than no heat treatment.
The frame was complaining on the way to work, creaking sounds, its not looking good. The zip tie array isn't doing much anymore it flexes on every pedal stroke
Old fart
Liked 3,401 Times
Quoted: 2338 Post(s)
Liked 2,827 Times
as best i understand (talked to my brother who has lots of welding experience) Oxy-Acety can weld aluminum, but it is very dicey with thin wall tubing.....more likely to burn through the tubes. Lot different than say 1/4 in plate
Frame is toast, just accept that and move on, don't put your self at risk or others trying to fix it
Likes For squirtdad:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
some other weld-stressed joint will break, followed by your face hitting the pavement.
and whoever told you that one of the most common break points on a bike frame isn't critical should not be listened to.
it failed due to poor heat treating/ANNEALING, bad engineering, and the side-to-side loading of pedaling.
engineer at a factory...."It was fine until you rode it! I think YOU caused the break!"
i advise that you find a different, better, brand of bike frame and swap your parts onto it... or quit pedaling.
Liked 486 Times
I was able to drill and tap a 1/4-20 hole into the blue version of this epoxy previously so it’s pretty strong
Liked 4,816 Times
I hope you were able to get several layers of cloth in there. Cloth is what adds a lot of strength for tension and torsional loads, IIRC.
And you need to make sure that cloth is fully saturated with resin. Not just laying on top or bottom of the cloth.
It'll be interesting to see how long it does or don't last before you get a crack again.
Likes For Iride01:
Liked 2,827 Times
thanks! I ended up going this route. I didn’t know how to take off the cranks/chainring and it got kind of epoxied as well, but I wiped it pretty well and I guess I’ll see what happens tomorrow. Honestly I’m kind of disappointed in the quality of this repair, really should have taken the chainring off instead of working around it. Live and learn I guess.
wiped it of pretty well,. means it most likely will not adhere, which is critical
no compression of glass and resin means very little structural strength
just glomping on a ton of epoxy does not make it strong
frame is dead
