Paint removal for welding
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
Another bad idea on Larry's Big Pile of Bad Ideas.
Quoted: 6974 Post(s)
Liked 10,975 Times
There are a couple people on this forum who need to learn the old adage "Buy once, cry once."
Larry apparently has a bunch of bikes, but they're all awful bikes -- don't fit him, break apart, etc. He buys used wheels that don't even fit any of his bikes. Stuff like that.
We have another poster who just started a thread in search of a comfy women's-specific saddle...She opened by explaining that she's tried a bunch of cheap saddles and none are comfortable. She also owns at least several old bikes, none of which seem to fit and perform perfectly. (Wow, what a surprise - cheap stuff isn't good.)
I'm not suggesting that a person has to always spend a pile of money to get something good...But I do wonder about people who buy bunches of cheap/nasty crap and then come here to share their problems.
Larry, you should probably throw all of your ****** bikes in the dumpster, save your money, and then walk into a store and buy One Good Bike.
Likes For Koyote:
Habitual User
Liked 8,100 Times
Liked 10,975 Times
That's not realistic advice for most of us, because we're just not smart enough. I mean, fixing up an old Huffy is sorta like splitting the atom.
Habitual User
Liked 8,100 Times
One takes a LOT more ingenuity and functioning brain cells than the other.
Likes For Eric F:
Quoted: 1562 Post(s)
Liked 1,735 Times
thanks! I ended up going this route. I didn’t know how to take off the cranks/chainring and it got kind of epoxied as well, but I wiped it pretty well and I guess I’ll see what happens tomorrow. Honestly I’m kind of disappointed in the quality of this repair, really should have taken the chainring off instead of working around it. Live and learn I guess.
Likes For icemilkcoffee:
Quoted: 2339 Post(s)
Liked 2,830 Times
Well...there is more than one way to fix up an old Huffy. https://www.bikeforums.net/classic-v...ispreloading=1
no low end frame will ever ride like a high end frame not matter what components you put on it.
I have seen the "frame is frame" "frame is something to hang parts on" thinking to much recently,
frame is the foundation to ride and handling
Likes For squirtdad:
Habitual User
Liked 8,100 Times
I like the huffy camp thread, but
The self-proclaimed Huffy genius, however, seems to be all about the illusion.
Quoted: 3515 Post(s)
Liked 2,928 Times
Likes For smd4:
Liked 10,975 Times
Quoted: 2700 Post(s)
Liked 486 Times
Koyote this is/was a fancy road racing bike, not a clunker. I only got one layer of cloth and there was so much epoxy I don’t think I got a nice clean wrap, but what’s done is done. The “wiping” I did was of the epoxy that got on the drivechain
as long as this joint fails before another weld I’m happy, I don’t think it will make me crash when it fails. Other welds, yeah can’t say that. So I guess in a since it’s good that the repair isn’t super robust, since it’s hard to say how much I’ve damaged the other welds in the 15 or so miles I’ve ridden it like this.
and yes there are 2 zip ties under the glue which are going to be structural/permanent, they are fancy weather/UV resistant ones. Or atleast I think they are
Habitual User
Liked 8,100 Times
Liked 2,928 Times
Most of what Larry writes suggest it, but if this phrase doesn’t indicate chain-yanking, I don’t know what does.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
and yes there are 2 zip ties under the glue which are going to be structural/permanent, they are fancy weather/UV resistant ones. Or at least I think they are
remember to do that the next time this crack opens up, ok?
Progress.. one baby step at a time.
if you make it thru one ride without that mess failing,.... go buy a lottery ticket on the next ride!
then you can quit ghetto-repairing bikes and break brand new ones.
chainstay-to-BB will be the next break.. probably... you experience a sudden sinking feeling....
Liked 2,928 Times
Habitual User
Liked 8,100 Times
Likes For Eric F:
Likes For Bald Paul:
Liked 486 Times
Darn I was thinking that I needed to sand it but totally forgot... and they are the fancy cable ties
https://www.mcmaster.com/product/70215K96
you can’t possibly tell that I forgot to sand it from the picture though lol. I even pumped out the epoxy, was being professional about it. the epoxy is probably about a thousand dollars, fancy stuff.
Liked 2,928 Times
Expired Member
Quoted: 3683 Post(s)
Liked 5,447 Times
I'm convinced Darwin has his hand on Larry's bare shoulder, guiding him in the direction most beneficial to the species.
Likes For shelbyfv:
Really Old Senior Member
Interesting your using Stycast 2850?
I used to use it years ago for encapsulating electronic parts in optical oceanographic instruments I built.
It was a highly thermo-conductive insulating epoxy we used because we wanted the electronics to respond quickly to temperature changes as they were being lowered to depth.
It basically, for lack of a better term, has lots of ground glass in it.
I'd find it difficult to believe that there aren't "stronger" products out there.
Liked 486 Times
Did you use the black stuff? The blue stuff 2850ft bl is for electrical insulation and I was hoping that the black stuff would be slightly stronger.
I chose it because it looked like the strongest stuff I had lying around.
the epoxy is a class two reproductive hazard, since we are bringing Darwin into this
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
More like that angel that watches over children and drunks.
Likes For ThermionicScott:
Liked 10,975 Times
