mechanical details on the movement of the Campagnolo 8sp rear derailleur
hi
suppose you have
suppose you have
- a Campagnolo 8 speed rear derailleur, say a Mirage short cage
- a Campagnolo 8 speed dx ErgoPower, say a Mirage one
- a Camapgnolo 8 speed sprockets cassette, 8 cogs of 1.9mm and 7 spacers of 3.1mm
- How many mm does the rear derailleur cable move each time you change gear with Ergopower?
- How much force (in Netwon unit) is needed to move the rear derailleur one click?
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
first things first... those are questions, not "doubts".
second thing.. WHY are you asking those two Questions?
I'm designing a gear shift control, in addition to that I have the following doubt:
from what I understand, what really matters for changing gear on the rear derailleur should only be the cog-to-cog distance (center to center), which in the 8speed case must be 5mm with tolerance +/- 0.1mm, but I am not sure if for an indexed level shifter or for an Ergopower what matters is the thickness of the spacer (between two cogs), which in the case of 8 speeds should be 3.1mm? with a tollerance of what?
From the measurements I made on my bicycle it seems that only the thickness of the spacers matters, because the cable moves exactly 3.1mm, but I doubt that this is correct, because something doesn't add up to me.
I need to find a way to make measurements on the force needed to move the derailleur from one sprocket to another in flat conditions.
I need both these two points to size the components well.
Quoted: 504 Post(s)
Liked 437 Times
Liked 739 Times
here's some basic info you NEED to consider before you waste another minute on your "project"...
https://bike.bikegremlin.com/1278/bi...20each%20click.
CampagnoloCampagnolo has two standards of rear shift ratio. Old 1.4 and new 1.5. Also, not every shifter pulls the same amount of cable with each click. With 10 speed for example, there is more cable pull for “slower” speeds, than there is for the others. 2.5 mm pull five times (from smallest 1st to the 6th sprocket), 3 mm for 7th and 8th, then 3.5 mm for 9th and 10th. 2.83 mm average cable pull per click. 🙂
Apart from that, as of 2014 (don’t take my word for the exact year), campagnolo introduces another 11 speed standard. Previous Revolution 11 and the newest Revolution 11+. They are not compatible.
Since Campagnolo cassettes sprocket spacing differs from other manufacturers’, it is hard to combine Campagnolo RDs with anything but the appropriate Campagnolo shifters and in most cases cassettes too.
Thanks!
Quoted: 4420 Post(s)
Liked 1,568 Times
The derailleur moves to put the pulley beneath the cog - 5mm. That 5mm is the sum of spacer and cog thickness.
That said, the derailleur is not moving the same amount per shift, because it is moving in an arc. So the shifts between the high gears (small cogs) take more cable to produce a 5mm lateral move than what is needed for the lower cogs on a different part of that arc.
And then you have the fact that the derailleur spring increases tension as you shift lower.
Liked 1,568 Times
Liked 1,568 Times
Liked 739 Times
have fun + good luck = i'm out
check my math if you wish.
here's a clue.. a TEN speed cassette is Not the Same as your 8 speed cassette.
here's another clue... a 3.1mm spacer is not all you need to "consider".
and finally... Study a modern Rear derailleur, then look up parallelograms... you just MIGHT discover a use for that trig. calculator.
you know.. i learned something in this thread... Campy cuts corners when designing their shifters.. hmmm... i think i'll continue avoiding Campy drivetrains.
Actually it seems so, as I have 8 measures for 8 clicks, all between 3.0 and 3.1 mm, so from what I measure, the cable seems to always move the same amount for each click. From cog 1 to cog8.
Perhaps the deviation you speak of is there, but it is on the order of half a millimeter or less.
These are measurements made on the frame by placing an index on the cable and a reference on the frame, and measuring with a ruler with notches of one mm or half a mm, so the measurements have an uncertainty of +/-0.5mm, and must be redone on the ground with a twentieth caliper.
I have to buy/get an ErgoPower dx, a weight to keep the cable tensioned, and then repeat all the measurements on the test bench, this time with the caliper; the max travel for all 8 clicks is less than 30mm, and I have a caliber long enough
You mentioned an arc for the rear derailleur, but you didn't mention any formula, and that's the doubt I had too, but what you say could be wrong. I don't know.
Is there any tecnical document about this?
Liked 1,568 Times
You're a troll.
I'm an electronic engineer, I have no experience with bicycle mechanics, if not the practical mechanical skills that have allowed me to carry out routine maintenance on my road bike (Litespeed Classic, 1997, Campagnolo Mirage 8sp) for the last ~30 years.
so what?
so what?
Liked 739 Times
etc.
i am now leaving my shop and getting some dinner. Thai food, fresh rolls with peanut sauce and special curry with chicken or prawns, haven't decided yet,.to be specific. Bye.
Liked 1,568 Times
I was telling you to ignore Maddog34 because he doesn't know what he's arguing about. You don't need trig to approximate the basic operation of a derailleur. You can even analyze it closely with a ruler and a compass on paper, if you account for all the angles.
But you don't even need to do that - all index derailleurs are friction derailleurs with a shifter that mimics a precise friction shift. Shimano waited until they could use Suntour's friction derailleur patent to launch modern index derailleurs - they didn't invent anything, just got the details right. Suntour and Campy followed by doing even less engineering, but getting their existing derailleurs to shift primarily by designing a shift lever. Suntour and first gen Campy index systems all work really well with later ramped cogs, because indexing is not that hard.
I don't know what you are up to, but the fact that mechanical index systems are still based on friction derailleurs is the primary problem with them. If you are doing something to address that - great. I have my own design, but the bike industry has moved on.
I could also buy/get Shimano parts.
I don't have anything made by Shimano.
I have a medium cage Sash/8sp rear derailleur, brand new, never used, which I was given as a gift. But I don't know how compatible it is with Campagnolo or Shimano, and I don't have any Sash shift stick.
