Campagnolo (or other) compact crankset
Anybody have a source for one of those square taper Campagnolo Centaur CT Compact cranksets, in 175mm length? I would love to get my hands on one, or something comparable for my 10s drivetrain. Definitely want a compact, and possibly thinking about putting together a 34-46 or 34-48 as I'm not sure 50 will clear my chainstays. I also like the Sugino XD2 double crank arms or similar, or maybe something else with a retro or vintage look. Found some nice new-old-stock Campagnolo crank arm sets in 175 on ebay, but finding compact size chainrings in 135 is proving difficult.
Any thoughts? Thanks.
SJS Cycles have a Stronglight Impact - they don't have it up to 175mm but I'd be surprised if it isn't available. I've got a Stronglight compact chainset on one of my bikes and it's doing very well.
Quoted: 668 Post(s)
Liked 529 Times
Modern Bike seems to have a good selection in stock
https://www.modernbike.com/cranksets...nk-lengthis175
Quoted: 576 Post(s)
Liked 1,003 Times
Good point about the 38t limit for 135bcd, I suppose it makes sense. Nonetheless, I think I found just what I was looking for, at what seems like a decent price.
Stronglight Impact Compact 34/48 175 in silver...
https://www.xxcycle.com/crankset-str...ompact,,en.php
Quoted: 645 Post(s)
Liked 797 Times
i has the devils own job finding a Campag square taper 172.5 compact crank (in silver) for my 10sp drivetrain. I repeatedly did the rounds of the usual sources of slightly older Campag stuff; ebay, CRC/Wiggle, Totalcycling etc. finally realized that it was a fruitless quest and I broadened the search to include external bearing BBs (PT and UT). I finally tracked one down at SprocketsUK, where a single crankset turned up out of the blue. I practically tripped over myself lunging for the “Buy” button
- Veloce 10sp shifters
- Veloce 10sp front derailleur
- Centaur 11sp medium cage rear derailleur
- FSA Gossamer Pro ABS bb386evo crankset 36/46/175
- FSA bb386 bsa bottom bracket cups
Likes For janthenat:
Received the Stronglight Impact Compact crankset, which has a simple classic appearance in silver, and put it all together with my Shimano un55 113mm bottom bracket. Turns out I needed to add a 1.5mm bottom bracket spacer on the drive side to get chainstay clearance for the 48t chainring. I wonder if a 115mm would have been about right without spacers. Then it took me far too long to reposition and adjust the front derailleur. That done and the rear derailleur tweaked, I'm finding, as expected, a bit more restriction in small chainring - to - smallest cogs and vice-versa. Seems like the previous 36/46 crankset allowed pretty free use of all the cogs in either chainring. Assuming that is just a function of the chainring size differences. One major improvement is a greater q-factor, which is 159 vs 144 for the FSA crankset. Plenty of chainstay clearance for the crank arms, and room for my pedal spindle cadence sensor magnet.
