Does the Mavic Ellipse Lockring Thread Normally?
Quoted: 73 Post(s)
i bought a Mavic Ellipse today (2nd hand) and i wanted to change the Cog cause its a 17 and i wanted to change it to a 15. I was just wondering if the lock ring of my Mavic Ellipse threads normally? When turning counter clockwise (Left) it Tightens, and when turning it Clockwise (Right) will loosen it? Because i don't know the "French Treading" but i know that you can only use the Mavic Lockring and you can use any brand of Cog
Thank you for the Answer!
Fresh Garbage
aire díthrub
Bikes: Raleigh Competition, Pashley Roadster Sovereign, Mercian Vincitore Speciale
Quoted: 259 Post(s)
Liked 55 Times
All track lock rings are LH threaded, precisely because track sprockets are RH threaded.
Clark W. Griswold
Quoted: 4356 Post(s)
Liked 3,994 Times
When you take that cog off make sure you clean and degrease, that is some nasty sludge.
By now for the export world market, the fixed/pista cog is British thread its the lockring that varies among hub makers .
. as wide as the lock ring thread is, I suspect they used Aluminum for the weight savings.. on that
Clark W. Griswold
Liked 3,994 Times
@seamuis: Tell that to my Swiss made Cilo's bottom bracket (which was not Swiss threaded as I thought and gathered from a little research). Also tell it to some old headsets and cranks and possibly some other stuff.
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
*Only* use mavic lockrings on ellipses. They use an uncommon 33x1mm "french" thread as mentioned above.
Avoid the most-common lockring threading of 1.29x24 TPI which is your Dura Ace, all-city, formula, etc.
Also avoid, the 1.32x24 TPI threading which is found on Philwood, Miche, and Campy.
"TPI" denotes imperial measurements. "mm" is metric.
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
i was taking the piss mate. I’m well aware of the different threadings. Lol, It’s literally visible in the photo above. Not surprised you would be the first to think you had an opportunity to pounce.
Quoted: 73 Post(s)
Thank God i asked, Thank you so much to all of you guys... and i heard that this is a great wheelset for criterium? Cause i was planning to race in a crit some time this year
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
Any decent wheelset with decent rims, hubs and spokes would be fine for a criterium race. But to more directly answer your question: yes. Just be aware that if you were to break a spoke, it’s likely going to cost you more to replace those flat-bladed straight-pull (or as mavic calls them: “ultra-bladed”) spokes. Ellipse wheels don’t have a reputation specifically, of doing that, that I’m aware of, but mavic wheels more generally, do. Ellipse wheels are pretty popular among criterium racers, so you will likely not be alone in your races, with these wheels. Good luck in your races, and cheers mate.
Quoted: 73 Post(s)
Quoted: 4806 Post(s)
Liked 3,929 Times
Ben
Liked 3,929 Times
Ben
Quoted: 73 Post(s)
