Sanding Carbon Fork?
Hey folks, recently upgraded the drive train and fork ($80 Chinese carbon special via eBay) on my old commuter bike. Everything is peachy, but the integrated disc brake mount on the fork is just a tad off so the disc rotor occasionally rubs against it.
Is it safe to sand down that area about 1mm to accommodate for the rotor?
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times
Let the shelling begin !
Any question regarding Ebay'ed Carbon results in "I WON'T USE THAT" replies
Heads-up.... incoming!
Quoted: 1034 Post(s)
Liked 1,289 Times
Likes For phughes:
Liked 2,946 Times
no. do what phughes posted.
-Oh Hey!
-Oh Hey!
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Are you sure the rotor is contacting the fork's brake mount? Maybe post a pic.
Quoted: 6178 Post(s)
Liked 4,795 Times
If your rotor is only occasionally bumping the fork, then the rotor is likely warped and that needs to be fixed first. Otherwise just leave the warped rotor alone and it'll make it's own custom fit grove in the fork after a few thousand miles.
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times
Late 2019 I had a rear-end collision (ran into the rear/side of racer in front of me as he was crashing out in a greasy corner) in lap 2 of 7 at a local CX race and bent my front rotor. It was bent enough to rub the inside of the fork leg but not so much that the wheel still rotated. I completed the remaining 5 laps to finish the race (+/- 5km) and when I looked at the fork the rotor had cut through the paint and put a -1mm deep groove in the carbon fork leg. So I managed to pry the rotor back to a straight-ish position, rode home from the race, cleaned up the bike, and touched up the damage with a few coats of nail polish.
Likes For bOsscO:
bOsscO
Quoted: 296 Post(s)
Liked 355 Times
All this to say it can take substantially less than a few thousand miles for a bent rotor to cut a custom fit groove in a carbon fork...but you should fix the rotor ASAP.
I had a recent issue with the rotor hitting the brake mount occasionally when I shifted weight to NDS. I assumed for some reason it hits the brake pads. but it turned out it hit the brake mount of the fork. I investigated the Shimano hub (100mm QR) and it seems the one one side spacer with the cone nut is wider. I swapped them so the wider one is on the NDS. that problem had existed a few years. i have no idea if my fix made it right, or if it came assembled wrongly from factory, or if I did it wrong when servicing the hub. I had built the wheel myself. that swap moved the rotor about 2mm inwards and resolved the occasional " ding". so i would check that. but with a knockoff fork, it also could be a weird fork issue.
Good luck. With a fork like that you will need it.
Likes For HerrKaLeun:
As I said, it's my commuter bike, 2017 Specialized Hardrock that I've basically ridden to the ground, and the stanchions on the crappy Suntour shocks have rusted into place, so wasn't looking to spend more than what I paid for the whole bike in replacing.
"Cheap" is probably a bad term, 'affordable' would be better, because cost does not always correlate with quality. I've been riding with it for almost 2 weeks now, inspecting it every couple of days and it seems to be holding up great. Only issue is the slight niggles with the fit, but otherwise I'm happy.
I do appreciate the insight on checking the rotor, so thanks all for that!
Randomhead
Liked 3,687 Times
You can't post pictures yet, but if you upload some pictures into an album in your gallery we can post them here for you. Or you could wait until you make two more posts. But I don't think anyone can make an informed opinion about this until we see what's going on.
Many bike shops have a tool to flatten brake mounts. That might be what needs to happen.
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
Anyone who makes fake posts just to up their post count instead of contributing to the forum should maybe reconsider checking the name of the website compared to the name of the website they were looking for and realize they are extremely different.
Google and BikeForums do share an "E" and an "O" but that is about it
If you are having rotor problems take it to a shop and see if they can try and help true the rotor for you. It sounds like your main issues are due to allowing your bike to get destroyed by leaving it outside in the elements or somewhere without some form of air conditioning or humidity regulation. That could cause issues with your carbon fork as well, sitting out in the sun and elements all the time which could potentially delaminate the carbon.
Anyone who makes a sarcastic response without reading the entire thread should maybe reconsider how clever they think they are.
Making assumptions about how I store my bike - indoors by the way - is not a great way to establish credibility.
unterhausen I have pics below.
EDIT: ugh, seeing that rotor zoomed in I probably need to replace those too.
EDIT 2: just measured the thickness, and the rotors are still at 1.75ish mm
Liked 2,946 Times
i cannot see what the pictures are suggesting. It's dark making it unclear.
-Oh Hey!
-Oh Hey!
While I’ve stored the bike indoors it’s entire life, I haven’t treated it as nicely as I should have in terms of maintenance, and I noticed the rubber covers on the axel is dry/cracked, so thinking that’s part of the issue as well. Appreciate the insight.
Thanks, I missed that rebuild part of your post. That was actually my first assumption, but this fork had an extremely tight fit when putting the front wheel back on. Had to flex it just a tad to fit the quick release into the dropouts. It seems to be better now than when I first installed, but will investigate putting a washer/spacer in.
I'm not sure I follow what you mean by you flexing... but I would consider getting a proper fork. If your chainstay breaks, you still can survive and stop the bike in most cases. surviving is what you want, in case i wasn't clear. If the fork brakes.... you may look into buying one of these bicycle airbags
Thanks for the clarification HerrKaLeun , and just to clarify myself, I guess I misspoke about adding width to the hub, and meant what you indicated: shifting the hub to the drive side to compensate.
Clark W. Griswold
Liked 3,958 Times
Making assumptions about how you store your bike? You said your stanchions RUSTED IN PLACE. That doesn't happen with proper indoor storage, things like that don't rust unless you have completely abused the bike in some way and every time I have seen rusty stanchions it is because the bike was left outside. If you don't want people to make those assumptions maybe don't tell us that they are "rusted in place". Bikes don't generally get damaged indoors unless near a leak or a radiator or something like that and if they are in such bad shape like that the bike needs to be maintained and hence why I mentioned taking it to a shop. Someone doing some basic maintenance at home wouldn't likely cause anything to rust in place or you would notice something before it gets that bad and would probably be asking questions before it got so bad you are replacing the fork already. I have seen people with forks from the 1990s that were still going (or needed some new seals or oil or elastomers) but weren't rusted in place or damaged in that way and certainly weren't babied.
Also I did read the thread and provided useful help even though you literally just post "post 1 and post 2" which is a clear sign you have ZERO interest in this forum and are using this as a place to google things rather than participate. People wouldn't make fake posts like that if they were interested in this forum, they would get that post count up by being a contributor to the forum like a normal person. You can be pouty and mad all you want but you made the posts not me not someone else. Now maybe you meant to use us like Ask Jeeves or Altavista or maybe Yahoo! Answers or something like that but the concept is the same.
Just looking at it, something seems misaligned. Is it possible the fork has the wrong spacing for that hub (e.g. a 110 fork on a 100 hub, or vice versa)?
HerrKaLeun I ended up taking off the cone nuts and servicing the bearings (which hadn't been done since I purchased in 2017). While my cone nuts were the same I adjusted them to give a bit more room on the NDS and now have more clearance, and readjusted the caliper on the mount as well.
Guest
Liked 3,270 Times
Looks like someone missed his nap again...
