eBike conversion
eBike conversion
Old 03-27-21, 01:37 PM
kennyc23
eBike conversion
I am think to purchase Bafang 750W conversion kit and they come in different crank size in selection (42T, 44T, 46T, 52T). my question is which crank size should I buy for my bike which has (28/38/48 teeth) triple crank ?
kennyc23 is offline
Old 03-27-21, 01:49 PM
alo
Quoted: 529 Post(s)
Liked 255 Times in 185 Posts
I would go with the largest. With an electric motor you will probably go faster, and will probably want a larger one.
alo is offline
Old 03-27-21, 02:39 PM
2old
Quoted: 877 Post(s)
Liked 810 Times in 612 Posts
Sounds like you're interested in a mid-drive, and the appropriate chainring is a function of intended use, terrain, wind, your weight etc. I started with a 48 on my BBS02 bike, but now incorporate a 30 tooth since all my riding is off road in very steep territory.
2old is offline
Old 03-27-21, 03:25 PM
cat0020
Ride more, eat less
cat0020's Avatar
Quoted: 713 Post(s)
Liked 733 Times in 450 Posts
On or off-road?
What is the (pedestrian or motor vehicle) traffic pattern that you will be riding in?
Will you be carrying cargo or heavy items on your bike?
Do you use your current 48t chainring most of the time you ride?
cat0020 is offline
Old 03-27-21, 08:41 PM
kennyc23
Thanks for your inputs (things i need to considered). I use most of time on 48T and on bike lane or street traffic. i think i will buy 48T.
kennyc23 is offline
Old 03-27-21, 11:45 PM
Doc_Wui
Doc_Wui's Avatar
Quoted: 340 Post(s)
Liked 275 Times in 192 Posts
I think mine is a 46T and I kept the 14-28 7 speed freewheel on my bike. 26" tires. I just don't care to ride much over 18 mph so I could have gone down to 44T,
Doc_Wui is offline
Likes For Doc_Wui:
Old 03-29-21, 12:33 PM
Pop N Wood
Quoted: 667 Post(s)
Liked 529 Times in 355 Posts
You need to do a bit more research. If you are swapping in a mid drive you will lose your triple crank. 42 tooth cranks work extremely well with a Bafang middrive. They are by far the most popular choice as well.
You don't want the Bafang steel ring however.
Pop N Wood is offline
Likes For Pop N Wood:
Old 03-29-21, 01:34 PM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times in 335 Posts
Weight, speed, terrain & your desired cadence all make a difference. On my single speed road bike I use a 53t chainring (at 100rpm), but I'm kind of an oddball. Everyone's situation will be a little different.
chas58 is offline
Old 03-29-21, 07:56 PM
KPREN
Bikes: 2008 S Works Stumpjumper FSR Carbon, 2016 E Fat Titanium Bike Custom built by me.
Quoted: 135 Post(s)
Liked 203 Times in 118 Posts
Unless you get creative with the Bafang software you are going to top out at 45kph regardless of which chainring size you choose. 42 tooth is the best for chainline and speed. You can reach full speed on a 29" with 42 tooth up front and 13 tooth in the rear.
KPREN is offline
